Extending Front and Rear Track Width
Mark Lewalski
Mark Lewalski is offline
PostPosted: Wed Dec 13, 2017 8:36 am    Post subject: Extending Front and Rear Track Width Reply with quote
Looking for any information on getting a wider track on the Thing.
I'm investigating the possibility of getting the front tires and rear tires clear of the wheel wells with the fenders off. If these "mods" can be returned to original configuration, then that's preferable.
I tried a search but either there isn't any info out there or I didn't use appropriate search terms.
Thanks,
Mark
'89 Vanagon Bluestar
'87 Vanagon Weekender
'74 Thing
Hot Rod Harp
Hot Rod Harp is offline
PostPosted: Wed Dec 13, 2017 10:03 am    Post subject: Re: Extending Front and Rear Track Width Reply with quote
Wheel spacers
74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
Arkansauced
Arkansauced is offline
PostPosted: Sat Dec 16, 2017 6:19 pm    Post subject: Re: Extending Front and Rear Track Width Reply with quote
The off road guys often widen the front beam. You can buy them built that way so you donít have to chop up the stock beam.
Havenít seen it done in the rear without some pretty major suspension changes, aside from spacers as mentioned above.
Metal Twister
Metal Twister is offline
PostPosted: Sat Dec 16, 2017 7:22 pm    Post subject: Re: Extending Front and Rear Track Width Reply with quote
Im playing with fabing up some tube fenders. This should fix everything as far as wheel clearence in the front as well as not having the arguments with CHP Popo about not having fenders. Been down that road to many times with the 32 and Model A. Everything gets fenders now. Will be adding spacers in the front as well.
Change is Opportunity!
Instagram=metaltwister
It's a play thing
It's a play thing is offline
PostPosted: Sun Dec 17, 2017 7:01 pm    Post subject: Re: Extending Front and Rear Track Width Reply with quote
To widen the car will cost $ arms, axles, fender, the list goes on. they work well stock. if set up correctly they will go all kinds of places
It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it...
