Need Help with VIN/Chassis Numbers
CNSRANCH
CNSRANCH is offline
PostPosted: Tue Dec 19, 2017 9:10 am    Post subject: Need Help with VIN/Chassis Numbers Reply with quote
Don't know if I'm in trouble or not.
Bought my buggy in May. A new VIN was never issued when the bug was converted to a buggy, so original VW VIN is still on title. Lived in Oklahoma all it's life.
To make matters worse, I bought the buggy in Oklahoma and I live in Kansas.
So, when I went to get it inspected, KS DOT informed me I had to get it cleaned up before they'd transfer it.
Fortunately I bought it from a dealer, so he's been working to get a new VIN.
He's gotten a new VIN issued by the State, (OK0828506112) but I'm likely going back to OK to match the vehicle to the original VIN before they issue a new title.
Here's my issue\problem\question........
1. No VIN plate anywhere on the buggy (at least anywhere I can find one).
2. Titled as a 1973 VW, Classic, exempt.
3. VIN number on title (OK title) - 1132826707
4. Chassis number on tunnel - 116587111
5. Engine number - AK 101045
So, I have a 10 digit VIN and a 9 digit chassis number........
Now what do I do?
BL3Manx
BL3Manx is offline
PostPosted: Tue Dec 19, 2017 9:37 am    Post subject: Re: Need Help with VIN/Chassis Numbers Reply with quote
You should have this conversation with the dealer.
It sounds like he has been able to get the state to issue a new VIN number. Not sure of your particular state but that's fairly normal on a buggy.
In California when you build a buggy as a Special Construction vehicle, they issue you a new VIN number which the CHP attaches on a tag to the body
They only look at the old chassis number to make sure the number isn't in the system as a stolen vehicle.
CNSRANCH
CNSRANCH is offline
PostPosted: Tue Dec 19, 2017 9:41 am    Post subject: Re: Need Help with VIN/Chassis Numbers Reply with quote
Thanks.......my concern's been matching the title to the buggy. With no existing VIN plate and nothing to tie the chassis number to the title, I've been worried.
Dealer's telling me that OK does not stamp a new VIN plate/frame, etc. Hoping that the final paperwork will make Kansas happy.
Dale M.
Dale M. is offline
PostPosted: Tue Dec 19, 2017 3:45 pm    Post subject: Re: Need Help with VIN/Chassis Numbers Reply with quote
Might want to bounce information at this site against what dealer is telling you....
http://www.semasan.com/page.asp?content=tag_title_toolbox&g=SEMAGA
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Tue Dec 19, 2017 6:05 pm    Post subject: Re: Need Help with VIN/Chassis Numbers Reply with quote
So I'm confused - The 17 digit VIN wasn't mandatory until 1981. VW used the 7 digit Chassis number up thru 1980. A '74 T1 pan would have a VW chassis number 114xxxxx - where the 3rd digit is the year of manf. That 114xxxxx should be the one stamped in the tunnel (and dash plate and under trunk plate if supplied). Both my dune buggy and Speedster kit car use the original VW chassis number as a "VIN" on the title. Usually a state assigned VIN starts with the 2 alpha state code. The AK motor was used in 1973. Some state allow rebodied vehicles to title vehicles using the OEM VW chassis id number - others (since it doesn't look like a VW T1 Bug) require state assigned VINs.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
CNSRANCH
CNSRANCH is offline
PostPosted: Tue Dec 19, 2017 7:44 pm    Post subject: Re: Need Help with VIN/Chassis Numbers Reply with quote
You're not alone being confused. I'm not sure I'm in posession of the original donor vehicle. A 116XXX IS 1976, NOT '73.
I can't figure out what specifically ties the buggy to the title.......hopefully the Court order from OK will clear it up.......although today is the first day I took the carpet up enough to expose the chassis number.
rugblaster
rugblaster is offline
PostPosted: Tue Dec 19, 2017 10:25 pm    Post subject: Re: Need Help with VIN/Chassis Numbers Reply with quote
I would "find" a number tag (1132826707) on the chassis and dummy up about it.
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.23 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '10 MB E350, '65 Plymouth Valiant convertible and a '14 Ford F150 King Ranch
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
