childofthewind Samba Member
Joined: October 19, 2010 Posts: 763 Location: Eastern Sierra
Posted: Tue Dec 19, 2017 5:31 pm Post subject: Windshield Seal - Always Replace, or... ? |
Is it advised, when getting a windshield replacement, to also replace the seal, even if the glass place says it doesn't need to be replaced? I've read conflicting things about this (as in, you should ALWAYS replace the seal in conjunction with the new glass).
Much appreciated! _________________ 1987.5 wolfsburg hardtop; 2.1
“As for me, I am tormented with an everlasting itch for things remote." - Melville |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Tue Dec 19, 2017 6:12 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
I haven't replaced my windshield yet so haven't much advise on how well the rubber stands up to uninstalling and reinstalling - but - is it original? If so, it's 30 years old give or take a month or two, how long much longer will it keep the wet out? And will you know if it isn't?
Mark (of the rust paranoia....) _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Posted: Tue Dec 19, 2017 6:16 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
It's not original, it was replaced around 6 years ago and still looks good. _________________ 1987.5 wolfsburg hardtop; 2.1
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Tue Dec 19, 2017 8:59 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
Rubber components like window seals can take a 'set,' assuming a unique shape to suit the variables of their particular installation. No two installations end up precisely the same, so when re-used with a new piece of glass your used window seal may have tight spots (and worse) gaps, causing water leaks.
Better to spend the extra few dollars and use a new seal when installing new glass.
Good luck! _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Posted: Wed Dec 20, 2017 1:30 am Post subject: Re: Windshield Seal - Always Replace, or... ? |
Just popped up in the classifieds...
https://www.thesamba.com/vw/classifieds/detail.php?id=2128310
Not German but new. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Wed Dec 20, 2017 5:24 am Post subject: Re: Windshield Seal - Always Replace, or... ? |
When I replaced the OEM German seal in my '74 it was 16 years old, hard as a rock, and badly cracked. The American made seal it got replaced with is now 29 years old and quite soft still. I doubt that I will ever put the '74 back on the road, but I might risk rerunning the seal if I did, I could always use some polyurethane to seal it if need be, had to do that with brand new seals at times anyway. What I am saying is that replacing the seal is a judgement call, does the old one have a reasonable amount of life remaining and is the new one made from quality materials so it won't die an early death? In the old days, at least, German made was not a sign of quality when it came to rubber products. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Dec 20, 2017 8:43 am Post subject: Re: Windshield Seal - Always Replace, or... ? |
I don't know what the right answer is but I usually reuse them and normally go with whatever the glass place says. |
Posted: Mon Dec 25, 2017 12:58 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
Yep - lesson learned... always replace the seal while you're doing the windshield - even if it looks good!! _________________ 1987.5 wolfsburg hardtop; 2.1
Posted: Mon Dec 25, 2017 1:17 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
Why, what happened, did it leak? |
Posted: Mon Dec 25, 2017 1:51 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
davevickery wrote: |
It sure did! Real bad, too. New one in and no leaks. _________________ 1987.5 wolfsburg hardtop; 2.1
Posted: Mon Dec 25, 2017 2:01 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
Jeffrey Lee wrote: |
Good luck! |
YES, MOS DEF TRUE!! _________________ 1987.5 wolfsburg hardtop; 2.1
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Dec 25, 2017 3:35 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
All I can say is results vary.
I have long ago lost count how many windshields I have had in the past 30 years but the seal is the original, still pliable, still looks good and still seals.
The van has enjoyed indoor parking its whole life which probably helps... plus the original German seal may be superior to replacements offered through the years. |
Posted: Mon Dec 25, 2017 3:45 pm Post subject: Re: Windshield Seal - Always Replace, or... ? |
Ahwahnee wrote: |
well yeah, with indoor parking I'd reckon your results are a bit different.. _________________ 1987.5 wolfsburg hardtop; 2.1
