1958 De Luxe Beetle from Morocco
Page: Previous  1, 2, 3 ... 9, 10, 11, 12, 13, 14  Next
flyboy161
flyboy161 is offline
PostPosted: Sun Dec 24, 2017 9:41 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Meanwhile on Christmas Eve, while waiting on Santa, the Moroccan turned her best side to me.
I’ve never seen that V channel before.
There’s one on each side
I’m guessing it’s for stiffness of the luggage tray. I’ll have crawl underneath the Diamond and see.
Pretty clean up under there
And here is the next project
Somebody had the brilliant idea of accessing the fan nut, so they cut this jagged lazy “V” in firewall. I never ceased to be amazed at the cleverness that some people display Wink
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483
Pruneman99
Pruneman99 is offline
PostPosted: Sun Dec 24, 2017 10:56 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
I have about 4 or 5 different "access ports" cut into different parts of my parcel tray as well. It seems the PO never wanted to actually get under the car to work on anything and elected to cut holes instead. Rolling Eyes
So I'll be making these same repairs next summer.
flyboy161
PostPosted: Mon Dec 25, 2017 12:07 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
My Dad’s bug had the entire floor of the parcel tray cut out for “access to adjust the clutch and change the starter.” It was replaced with a flimsy piece of steel.
flyboy161
PostPosted: Mon Dec 25, 2017 7:30 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 8...Christmas day...
Time to tackle the big lazy "V"
It's ugly, with curled edges, but it's all there.
First order of business is pull it through in order to straighten the edges
Time to knock out some of the dents and start on the pressing on the right. The "V" is just a tad too long because it's been flattened out.
The metal is very flimsy with this cut but I was able to secure the first two clamps and pick up the press shape. More tomorrow
flyboy161
PostPosted: Tue Dec 26, 2017 3:48 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 9: the lazy V
Full day today.
Ugh
Rome
Rome is offline
PostPosted: Tue Dec 26, 2017 4:35 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Stitching the war wounds back together! Were you able to reach down with your arm at the rear window bottom edge to carefully hammer the rib shapes back while holding the dolly against the metal with your other hand?
flyboy161
PostPosted: Tue Dec 26, 2017 6:00 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Yes, that is exactly what I did. At one point I was sitting on the parcel shelf reaching over to hold my copper backer while stitching.
flyboy161
PostPosted: Wed Dec 27, 2017 10:39 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 10: Lazy V, the light at the end of the tunnel
I ground down the spattered seagull poop I call welding and filled some more areas I missed and ground those down as well. Then I covered the entire area far side
and near with an epoxy resin.
This has to cure at least 12 hours before sanding smooth.
I also removed the rear quarter glass and the passenger door components as well as chrome trim
flyboy161
PostPosted: Thu Dec 28, 2017 10:09 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 11: back to the front. Today I decided to start really working the front by replacing the lower front quarter panels
Used a donor front clip and removed the right quarter panel off of it
After the final cut on my quarter panel I did a rough patch from the donor. It needed several trims until it fit in place
The spare tire well in place
Test fit the front apron and then removed it. Ready to start welding tomorrow
flyboy161
PostPosted: Fri Dec 29, 2017 5:24 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 12: passenger's front quarter panel
It was a very good day.
It's welded in, what a chore. But once I removed all the paint, the welding went a lot smoother.
Now for the driver's side
flyboy161
PostPosted: Fri Dec 29, 2017 7:35 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Spare tire well is installed
flyboy161
PostPosted: Sat Dec 30, 2017 8:25 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 13: finished the passenger side quarter panel and moved on to the drivers side.
Drivers side taped and ready to cut
New panel first cut
Second cut done. Just need to cut the backside and bottom. I’m done for today.
Pruneman99
PostPosted: Sat Dec 30, 2017 8:33 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
It's coming along nicely. Great work and thanks for taking the time to post so we can follow along.
flyboy161
PostPosted: Sat Dec 30, 2017 8:37 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
The forum has given me a lot of confidence and hope. I am happy to give back
Dake
Dake is offline
PostPosted: Sat Dec 30, 2017 8:40 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Looks like your doing a great job . What kind of fill are you useing on the welds. I was useing all-metal filer
flyboy161
PostPosted: Sat Dec 30, 2017 8:55 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
That’s just glazing putty
TheDon
TheDon is offline
PostPosted: Sat Dec 30, 2017 9:03 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Glad to see someone replacing the spare tire well. I’ve got that job on my list to do as well.
lawn ninja wrote:
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone.
flyboy161
PostPosted: Sat Dec 30, 2017 9:15 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
It’s not that bad Don. Just a lot of spot welds!!
flyboy161
PostPosted: Sun Dec 31, 2017 6:11 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 14: front driver's quarter panel and wrapping up some details
Went to Harbor Freight today and picked up some sanding discs and an angle grinder.
Remember the Lazy V?
I'm happy
Mounted the Jack retaining bracket
Driver's side front quarter stitched in. Need to clean that up, but it's in.
And test fit the front apron. So far, so good.
flyboy161
PostPosted: Mon Jan 01, 2018 2:58 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Day 15: stick a fork in me!
Today was my last day of leave, so, what better way than to grind and weld my life away!
Got the welds ground smooth on the driver's side and mounted the horn bracket
Spare tire well is welded in
Front apron is welded in on the driver's side and tacked and clecoed in on the passenger side. I ran out of wire. Crying or Very sad
The whole thing is hit with self etching primer, as I don't know when I'll be able to get back on it. Plus, it's 35 degrees outside and 55 in the garage. It's gonna take a while to dry
Page 10 of 14
