AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Mon Jan 01, 2018 6:27 pm Post subject: What's your van-plan for 2018? |
Not a resolution, just some goals.
Im planning to
1. over haul the front suspension w all new bushings.
2. brake job (pedal pulsates when slowing from high speeds)
3. get a 2" trailer hitch mounted to carry mine and my families bikes.
4. reupholster rear seats and bed cushions to match front seats
5. all camping equip working w fridge out and shelving in place.
This is actually a pretty easy list considering the goals Ive set in past years.
Id like to get all this done by July and If I do....Well then I can enjoy the van for the second 6 mos and just deal w the surprises.
Anyone else care to set some goals for the new year? _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9778 Location: Mt Lemmon, AZ
Posted: Mon Jan 01, 2018 6:44 pm Post subject: Re: Whats your van-plan for 2018 |
1. Drive 'til something breaks.
2. Fix it.
3. GoTo 1. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12105 Location: Port Manteau
Posted: Mon Jan 01, 2018 8:09 pm Post subject: Re: Whats your van-plan for 2018 |
1. Complete TDI swap (weld intake manifold)
2. Fog light install
3. Install double DIN stereo
4. Fabricate new AC lines for ALH compressor.
5. Fabricate mount for cruise actuator
6. Fabricate shock absorber mounts to accommodate increased ride height. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Jan 01, 2018 8:42 pm Post subject: Re: Whats your van-plan for 2018 |
Four-step van action plan:
a) finish all the things I never have...
b) start a few things I already should have...
c) road trip to Utah & back...
d) camp more nights than last year.
Happy New Year!!!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3787 Location: VA/TN
Posted: Mon Jan 01, 2018 9:20 pm Post subject: Re: Whats your van-plan for 2018 |
-Put on my Yakima 1A towers (need to buy shocks/struts)
-Solar panel on top
-12v Fridge
-New Radiator + coolant lines
-New gas tank
-hitch bumper (I think GoWesty) _________________ Brandon
Instagram @joannthevan |
jimf909 Samba Member
Posted: Mon Jan 01, 2018 9:21 pm Post subject: Re: Whats your van-plan for 2018 |
- High-top roof rack to increase solar panal capacity from 75 watts to 200 watts and to add boat/board carrying capacity
- Swing-away rear rack to carry two bikes and a box for gear and a water heater
- Complete or ignore a dozen or so minor enhancements that I put on the to-do list at some time because they sounded brilliant at the time
- Turn the brand new tires into rubbish _________________ - Jim
Abscate wrote: |
designer Samba Member
Joined: November 05, 2009 Posts: 484 Location: Idaho-but just the tip
Posted: Mon Jan 01, 2018 9:24 pm Post subject: Re: Whats your van-plan for 2018 |
2.5 Suby Swap via RMW
Fab F/R Bumpers with my boys
Swing aways
Drive More miles
See more places
Camp more _________________ __________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013. |
kamzcab86 Samba Moderator
Posted: Mon Jan 01, 2018 9:29 pm Post subject: Re: Whats your van-plan for 2018 |
Provided it passes its upcoming emissions test ( ), not a darn thing except go road-trippin' (and perhaps recover the rear seat to match the new fronts... edit: and paint the drab grilles). Being ignored for most of 2017, my poor little Cabriolet will be receiving the bulk of my repair-based attention this year. _________________ ~Kamz
2016 Golf GTI S
Mike760 Samba Member
Joined: November 19, 2015 Posts: 43 Location: Oceanside, CA
Posted: Mon Jan 01, 2018 10:30 pm Post subject: Re: Whats your van-plan for 2018 |
1. New Pop-Top Canvas
2. Propex -- need to decide on if I want to mount under van or get the one for inside
3. Small Solar Setup _________________ 1984 Westfalia |
jacob. Samba Member
Posted: Mon Jan 01, 2018 10:56 pm Post subject: Re: Whats your van-plan for 2018 |
I've got some body work to do. Both foot wells like in the picture, the lip on both bottom corners of the wind shield, as well as the lip on the driverside middle window.
I've also got to get my speed sensor on for my RMW subaru conversion. I've put 10,000 miles on the engine without it. I'm not sure how critical the VSS is, but i have a feeling it needs to be done.
I need to put on my steering rack powerflex bushings to finish out my front end rebuild.
I've got one final rubber brake line in the rear to finish out the complete brake overhaul.
Then I'm going to finish building my custom interior with birch ply. Building a galley cabinet that sits behind the front seats. This way I can take out my westy cabinets and have a full width bed. I'm going to build the bed raised up so I can have some drawers over the engine hatch. Pics below are my inspiration.
RCB wrote: |
jacob gets razzed a lot cause he has the only GEX engine thats lasted longer than half an oil change. |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 806 Location: Seattle
Posted: Mon Jan 01, 2018 11:30 pm Post subject: Re: Whats your van-plan for 2018 |
1. Re-install headliner
2. Re-cover German army issue olive drab fabric rear seat to something more grey.
3. Mount Hylift jack somewhere.
4. See if the Syncro system is actually working.
5. Fix 2 annoying noises. One rattling when the RPMs are at 3k and another while light braking at a slow speed.
After that, I just might have to call it finished and wrap up my build thread.
ELO78 Samba Member
Joined: September 18, 2015 Posts: 167 Location: Oak Park, IL
Posted: Tue Jan 02, 2018 8:36 am Post subject: Re: Whats your van-plan for 2018 |
I gotta get the air conditioning blowing cold. The kids can't handle the summer heat, and the windows down is too windy for them at their young age.
Beyond that, I want to use the van for way more fun, local day-adventures with the family, and a couple short camping trips. As the kids grow older, I hope the camping trips will increase in frequency, length, and distance.
I will continue to stew on the idea of selling or trading my Multivan for a tintop Syncro. _________________ Eric
1990 Westy Multivan, 2.1 L WBX, 4-speed - SOLD
2003 EuroVan Westy Weekender |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16476 Location: Brookeville, MD
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2312 Location: Adobe Jungle USA
Posted: Tue Jan 02, 2018 9:26 am Post subject: Re: Whats your van-plan for 2018 |
Yes, I plan to pay off the credit card from all the cool upgrades I did last year! _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
WestleyTheWesty Samba Member
Joined: October 07, 2015 Posts: 128 Location: Portland, OR
Posted: Tue Jan 02, 2018 10:07 am Post subject: Re: Whats your van-plan for 2018 |
Hmmm...
1) Finish building the drawer that will go above the Truckfridge (will have matching laminate and latch, should look stock-ish)
2) If it's in the budget get a T3 anti-sway bar and HD endlinks
3) Install a new luggage rack seal (and clean up under there)
4) Get new insurance
5) Camp somewhere new, like Joshua Tree or somewhere in the Southwest =) _________________ 1990 Westy, started stock, not anymore! |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6798 Location: Fort Lauderdale, Fl.
Posted: Tue Jan 02, 2018 10:29 am Post subject: Re: Whats your van-plan for 2018 |
dhaavers wrote: |
Happy New Year!!!
- Dave |
👍👍👍😆 _________________ This free advice is worth exactly what you paid for it.
Fiddlestyx Samba Member
Posted: Tue Jan 02, 2018 10:49 am Post subject: Re: Whats your van-plan for 2018 |
Get it out of retirement and back on the road. _________________ 1983 Vanagon Westfalia Air-cooled
1973 Super Beetle |
E1 Samba Member
Joined: January 21, 2013 Posts: 6388 Location: Westfalia, Earth
Posted: Tue Jan 02, 2018 11:16 am Post subject: Re: Whats your van-plan for 2018 |
1). Camp 365 nights again (Oh, the Horror)
2). All interior panels, likely in wood (including floor)
3). Redo upholstery if right vendor/situation presents itself
4). Find solution to sagging lifter springs dealer/installer got so wrong
5). Repair damage from idiot backing maneuver, and then deer buck impact
6). Add to ever-growing bus campmates list
7). Camp 365 nights again (Oh, the Horror) _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32437 Location: Reading Pennsylvania
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Tue Jan 02, 2018 12:59 pm Post subject: Re: Whats your van-plan for 2018 |
1. Fix leaking valve guide seals in the Subaru engine.
2. Replace rear quarter panel.
3. Prep and paint van.
4. Finish rear headliner repair.
5. Front air conditioning?
6. More Solar capacity/compressor fridge?
.?? On the last two, as we all know life gets in the way of projects, or, put another way, we are often more optimistic than reality.... _________________ Rich |
