TravelingInAFriedOutKombi Samba Member
Joined: December 28, 2017 Posts: 20 Location: Salt Lake City, UT
Posted: Tue Jan 02, 2018 12:26 pm Post subject: SOS |
Is my fuel pump toast?
Drove her a couple hundred miles, then noticed the oil pressure light would flicker when on any sort of incline, downhill or uphill. And, if I didn't give it some gas, she would stall.
Now after a couple days of this, after I parked her, I could here a ticking sound coming from underneath the rear drivers side panel, where the fuel pump is. Even after hours of her turned off and parked, this sound persisted. Went to start her this morning, battery is completely dead. And when I jump her and start her up, she shuts off if I'm not constantly giving it gas.
So, I'm assuming the fuel pump died, and for some reason wouldn't turn off, draining my battery dry. Am I accurate on this?
I am running the stock FI 1970cc engine. |
SGKent Samba Member
Posted: Tue Jan 02, 2018 12:40 pm Post subject: Re: SOS |
sounds to me you are (were) low on oil, maybe gas tooso the pump was sucking air. True FI tanks have baffles in them to stop that sort of thing. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Maybe your AFM door is stuck open? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Jan 02, 2018 1:25 pm Post subject: Re: SOS |
SGKent wrote: |
sounds to me you are (were) low on oil, maybe gas tooso the pump was sucking air. True FI tanks have baffles in them to stop that sort of thing. |
Oddly enough, I have too much oil, according to my dipstick. PO must have overfilled it. Could that be my issue? |
Posted: Tue Jan 02, 2018 1:27 pm Post subject: Re: SOS |
aeromech wrote: |
Maybe your AFM door is stuck open? |
AFM? Sorry....VERY new to this. I am no mechanic, but thought I could replace my fuel pump on my own with some online help. |
Posted: Tue Jan 02, 2018 1:52 pm Post subject: Re: SOS |
Sorry,
From what you described.... the ticking sound always being on and the battery going dead, I'd guess your fuel isn't shutting off like it should. I'm guessing that a stuck AFM (Airflow Meter) door might cause that. I could be wrong and the ignition switch might prevent the pump from running even with the door open. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Tue Jan 02, 2018 2:03 pm Post subject: Re: SOS |
I think you'd need to have a leaky injector along with a fuel pump that doesn't turn off in order to dilute the crankcase oil.
Pull the dip stick and smell it for fuel _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Tue Jan 02, 2018 2:24 pm Post subject: Re: SOS |
regardless - welcome, and 9 ft lbs max on the oil strainer nut if you remove it or engine damage will occur. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Tue Jan 02, 2018 2:50 pm Post subject: Re: SOS |
while we'd all love to help you diagnoses this over the internet..
you have some GREAT VW resources in the SLC area that you should get familiar with.
I don't know any of them personally or by reputation so you'll have to do a little feeling them out..
tell them your story, and don't cheap out on their advice or expertise..
but
Bob's VW parts.. https://goo.gl/maps/hDCeaawdJXD2
Wayne's VW repair. https://goo.gl/maps/kJ2tncUWjWu _________________
Abscate wrote: |
Posted: Tue Jan 02, 2018 11:35 pm Post subject: Re: SOS |
Thank you all for your detailed replies- I truly appreciate it! Since I have no idea what the hell I'm doing, I think it's wise to let a local expert have a peek at what's going on.
@danfromsyr- Thursday I'll be towing her to a shop in Orem. UT (Vintage German Motors) that all the local guys seem to rave about. I'll be sure to update the post when I find out the diagnosis.
Thanks again! |
SGKent Samba Member
Posted: Wed Jan 03, 2018 8:06 am Post subject: Re: SOS |
tow rear wheels first or disconnect the axles. or flat bed. More than one person here has had an engine destroyed when the trans slipped into 1st at 55 mph. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jan 03, 2018 4:32 pm Post subject: Re: SOS |
SGKent wrote: |
tow rear wheels first or disconnect the axles. or flat bed. More than one person here has had an engine destroyed when the trans slipped into 1st at 55 mph. |
Yikes! I'm just going to play it safe and flat bed her. |
SGKent Samba Member
Posted: Wed Jan 03, 2018 4:36 pm Post subject: Re: SOS |
TravelingInAFriedOutKombi wrote: |
SGKent wrote: |
best way. no low overhangs _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 04, 2018 2:44 pm Post subject: Re: SOS |
aeromech wrote: |
Pull the dip stick and smell it for fuel |
The dipstick smelled like I had pulled it directly out of gasoline. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Jan 04, 2018 2:50 pm Post subject: Re: SOS |
aeromech wrote: |
Change your oil. Check your float. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Jan 04, 2018 3:04 pm Post subject: Re: SOS |
Spike0180 wrote: |
aeromech wrote: |
Change your oil. Check your float. |
That's the strange part. It doesn't have a float, it's fuel injected. Injectors are powered open so even with the fuel pump running somehow, the injectors should keep the fuel from flooding the crank case. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu Jan 04, 2018 3:08 pm Post subject: Re: SOS |
aeromech wrote: |
Spike0180 wrote: |
aeromech wrote: |
That's the strange part. It doesn't have a float, it's fuel injected. Injectors are powered open so even with the fuel pump running somehow, the injectors should keep the fuel from flooding the crank case. |
Sorry, missed that (kinda just jumped in on this)
If an injector is stuck open (debris?) then it would leak down the pressure in the system into the cylinder/case. (that rail stays pressurized for some time after the engine is shut off.) _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Thu Jan 04, 2018 3:19 pm Post subject: Re: SOS |
Yep, a leaky injector would cause a lot of problems. Running problems as well as flooding problems. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
