Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Jan 02, 2018 5:52 pm Post subject: Need Ideas |
I decided that I want to make the dune buggy a semi permanent two seater so I moved the tank to the area behind the seats. Unfortunately I now have some holes that need to somehow be covered. I had considered cutting a piece of sandpaper tread and putting it over the area but then started thinking a third brake light would be nice if I could find one but enough to cover the area. I tried searching by size but can’t seem to find any sold by size. Does anyone know of a third brake light that is this large? Approx 12x5”.
Any other ideas are welcome.
* please no lectures about putting the tank up front. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jan 02, 2018 9:04 pm Post subject: Re: Need Ideas |
Not sure about big hole but the 4 small ones could be filled with "button head" screws to look like it supported something under body...
jspbtown Samba Member
Posted: Tue Jan 02, 2018 9:16 pm Post subject: Re: Need Ideas |
I would stroll through a wrecking yard. many trucks have roof mounted lights. Some mini-vans as well I think. |
Posted: Tue Jan 02, 2018 9:46 pm Post subject: Re: Need Ideas |
jspbtown wrote: |
This is kind of what I was thinking. Problem is a lot of the junk yards around here won’t let you wander around them for insurance reasons. I may keep a tape measure on me and stroll through a used truck lot to see if anything measures up. I had also thought about mounting a scoop over the holes and putting an LED bar inside. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Jan 03, 2018 8:00 am Post subject: Re: Need Ideas |
Fiberglass is VERY easy to work with.
You can take a couple of cans of expanding foam, spray it in a heap on some cardboard and then shape it when it dries. Lay some glass over the foam and when the glass dries scrape out and place the light of your choosing in it. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Wed Jan 03, 2018 8:38 am Post subject: Re: Need Ideas |
I like the scoop idea - I'd add LED back up lights along with a 3rd brake light. How about an VW bug engine lid license plate light? Or at least use that to mold one in fiberglass.
https://www.ebay.com/itm/Vintage-VW-Bug-Deck-Lid-E...0005.m1851 _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
vponder Samba Member
Posted: Wed Jan 03, 2018 10:42 am Post subject: Re: Need Ideas |
If its flat there (cant tell) might get a piece of diamond plate to cover and use some nice bolts like Dale showed. But sometime diamond plate is over done on things . |
Posted: Wed Jan 03, 2018 11:10 am Post subject: Re: Need Ideas |
vponder wrote: |
It’s pretty curvy and not really a diamond plate fan. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
TSFR Samba Member
Joined: May 14, 2013 Posts: 365 Location: Columbia, SC
Posted: Wed Jan 03, 2018 11:12 am Post subject: Re: Need Ideas |
What was there before? _________________
Thanks,
Jeff
Manxter 2+2 #160 |
Posted: Wed Jan 03, 2018 11:15 am Post subject: Re: Need Ideas |
TSFR wrote: |
What was there before? |
The fuel tank. Small holes were for the straps, large was for the fitting to go through. PO work, not mine.
1967 Ghia
TSFR Samba Member
Posted: Wed Jan 03, 2018 11:21 am Post subject: Re: Need Ideas |
That makes sense now. Maybe if you can fab up some kind of stainless steel polished spoiler/lip that follows the existing tail? Or a new license plate bracket. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
Posted: Wed Jan 03, 2018 11:27 am Post subject: Re: Need Ideas |
TSFR wrote: |
That makes sense now. Maybe if you can fab up some kind of stainless steel polished spoiler/lip that follows the existing tail? Or a new license plate bracket. |
I had thought about a piece of stainless or aluminum as an “accent” piece. Eventual plan will be to glass it in and repaint but I’m not there and don’t like driving around with crappy looking holes in the body. Maybe I could practice my glassing skills and spray the area in a silver stripe of some sort.... _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Jan 03, 2018 11:43 am Post subject: Re: Need Ideas |
Sharp64 wrote: |
TSFR wrote: |
I had thought about a piece of stainless or aluminum as an “accent” piece. Eventual plan will be to glass it in and repaint but I’m not there and don’t like driving around with crappy looking holes in the body. Maybe I could practice my glassing skills and spray the area in a silver stripe of some sort.... |
That would work.... Its far enough away from flames in front so even close match of paint would be ok....
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Wed Jan 03, 2018 12:38 pm Post subject: Re: Need Ideas |
Great place for a third brake light.....get a motorcycle turn signal and you can get various color LED bulbs.....Also look at "big Rig" lighting..... _________________ D-Dubya Manx clone - 63 Short pan,1914.
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Wed Jan 03, 2018 1:06 pm Post subject: Re: Need Ideas |
That's a nice looking buggy, I can't believe someone mounted the tank all the way in the back like that. Why not put a VW style tank under the hood where it belongs? _________________ 1963 Ragtop Bug |
GS guy Samba Member
Joined: December 03, 2007 Posts: 968 Location: Maryland
Posted: Wed Jan 03, 2018 2:26 pm Post subject: Re: Need Ideas |
Might also try to carefully 'glass in the holes, sand smooth/flush on top then cover the upper surface of the "spoiler" with a vinyl wrap material like an accent panel - carbon fiber? wood-grain?? semi-flat black?
You'd have to get the finish near "paint ready", but would avoid having to match the existing color.
Jeff _________________ 70's vintage Deserter GS buggy - undergoing transformation to Super GS! |
Posted: Wed Jan 03, 2018 4:08 pm Post subject: Re: Need Ideas |
EMPIImp69 wrote: |
That's a nice looking buggy, I can't believe someone mounted the tank all the way in the back like that. Why not put a VW style tank under the hood where it belongs? |
Thanks. I’ll post up some better pics soon. I’ve made some “upgrades” since these pics. As for the tank, someone glassed it in. Cutting it open would mean bodywork, paint etc. Maybe after. Year or so of having it I’ll take it off the road and redo the bodywork and paint. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Jan 03, 2018 4:25 pm Post subject: Re: Need Ideas |
GS guy wrote: |
Jeff |
Yeah a possibility. Some form of silver or carbon fiber would be cool. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
cbeck Samba Member
Posted: Wed Jan 03, 2018 7:40 pm Post subject: Re: Need Ideas |
Made my roof panels out of lexan. You can heat, bend, glue, sand, and paint. I also bought 4 12"led strips off of fleabay delivered for $6. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Wed Jan 03, 2018 8:28 pm Post subject: Re: Need Ideas |
Repair the holes properly, then carry the hood flames back over the spoiler. Anything else will look like an attempt to hide an ugly hole on an otherwise very nice buggy. |
