ATTN: Check Your Power Steering Switch Wiring!!!
Page: 1, 2, 3, 4  Next
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Thu Jan 04, 2018 2:38 pm    Post subject: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
so i edited the title of this thread to reflect what i found (or you might say, i was lead to). if you find damage like this, it was most likely caused by a similar situation. check the tightness of the connections on your power steering switch, make sure they are insulated and install an inline fuse near the power lug in the engine junction box.
Moderator Edit: and..... FUSE your EFI /Fuel Pump feed!!
driving highway speed, all good, smell electrical. shut down & coast to stop. checking out the usual suspects around the dash, i notice smoke from the rear vent. frantically disconnect the battery and open the engine lid to find this:
so i know a guy (me) whos good with wiring and a guy (me) who has a replacement engine harness and im really not too worried about making the needed repairs. my question to those more knowledgeable than me is: what caused this? i dont want to make the repairs and end up with this same result.
obviously, a dead short caused this, but where? fuel pump relay? ECU failure? alternator? or is it simply some chafed wires that finally wore too thin?
there is evidence of heat inside the loom about halfway across the engine to about the throttle cable and everything is normal, as it should be.
i have some driving lights wired into the fuel pump + lead, but it just powers a relay which gets its power direct from the fuse box. also, this relay was not hot, nor damaged. coincidence? im guessing not. also, there is no evidence of damage or heat where the relay splices into the fuel pump. i will be investigating as you read this.
71 Ghia - 88 Van - 87 Syncro Projecturewagon - 05 Passat Wagon TDI
E1
E1 is offline
PostPosted: Thu Jan 04, 2018 2:41 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
Was the relay out like that, or did you pull it afterwards?
1984 Westy-Ferrari firing at 33% capacity
I drive by the seat of my pants but then get behind on my steering
Thank You Bob Lazier, Forever Golden
djkeev Premium Member
djkeev is offline
PostPosted: Thu Jan 04, 2018 2:44 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
Unfused fuel injection / fuel pump wiring.
Member dhaavers had similar problems tgat stemmed from the Power Steering idle switch wires,
As a result of his experience I (and hopefully others) put a fuse in the circuit.
Dave
Ghia
Vanagon
Beetle
borninabus
Samba R&D Dept.
PostPosted: Thu Jan 04, 2018 2:56 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
i pulled it out. thanks
borninabus
Samba R&D Dept.
PostPosted: Thu Jan 04, 2018 3:00 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
Dave
you dont say?
crazyvwvanman
crazyvwvanman is offline
Check the power steering pump pressure switch wiring. That is the usual cause of cooking that fuel injection harness power wire so look at it carefully.
Mark
borninabus
Samba R&D Dept.
PostPosted: Thu Jan 04, 2018 3:04 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
so, where does the fuse go?
funny stuff. Laughing
you guys are good, thanks a ton!
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Jan 04, 2018 3:09 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
its interesting to see which wire in the black box failed.
I redid one of your images.
Likely not related but are the wires arrows point to damaged?
edit: I see the image of PS connector now.
Neil.
1981 Westy air cooled to 15 ABA swap: http://tinyurl.com/y9n4xob8
50 ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
borninabus
Samba R&D Dept.
PostPosted: Thu Jan 04, 2018 3:10 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
ill put the fuse close to the lug in the (already crowded) junction box and edit this thread title to serve as warning to future vanagon owners.
guess i should have used insulated spades, huh.
live and learn Rolling Eyes
borninabus
Samba R&D Dept.
PostPosted: Thu Jan 04, 2018 3:12 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
the left arrow is the same smoked wire and the right arrow is just dusty with a clean spot where i was handling it.
borninabus
Samba R&D Dept.
PostPosted: Thu Jan 04, 2018 3:16 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
on the plus side (get it Laughing) i should be back in action by tomorrow.
djkeev is offline
PostPosted: Thu Jan 04, 2018 3:42 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
Here is the thread about Dave's wiring woes........ the fix and the fuse installation.......
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
Dave
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Thu Jan 04, 2018 4:35 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
check your wiring loom on the passenger side by the tail light also.... mine had melted there because the PS switch is tied into the idle stabilizer relay.
-dan
djkeev is offline
PostPosted: Thu Jan 04, 2018 4:45 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
-dan
Yeah, if you look at Dave's posts in the linked thread, he had to rebuild his harness.
Dave
Ghia
Vanagon
Beetle
dhaavers
dhaavers is offline
PostPosted: Thu Jan 04, 2018 5:41 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Wow...seeing this post brought back a WHOLE lot of memories...& frustrations...Evil or Very Mad Rolling Eyes Wink
OP, good on you for making a clear, insistent post title.
This issue NEEDS to be consistently mentioned in the same breath as fuel lines!!!
But for some aware rear seat passengers, my situation could've gone on for another
several minutes & I could've easily been just another guy with a burned van...a statistic.
DON'T WAIT...DO THIS, PEOPLE!!! Evil or Very Mad Evil or Very Mad Evil or Very Mad
BARE MINIMUM: Insulate your (unfused) power steering pressure switch connectors.
SUPER SAFE: Add a (7.5a - 10a) fuse in the black connector box for the entire FI harness.
- Dave
86 White Westy Weekender
"The WonderVan"
dhaavers
dhaavers is offline
PostPosted: Thu Jan 04, 2018 7:15 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
PS/FWIW...related previous posts:
https://www.thesamba.com/vw/forum/viewtopic.php?t=647443
https://www.thesamba.com/vw/forum/viewtopic.php?t=592438
- Dave
"The WonderVan"
Vanagon Nut
PostPosted: Thu Jan 04, 2018 9:30 pm    Post subject: Re: Electrical Meltdown! What Happened? Reply with quote
Ok. Thanks.
Pure "dumb luck" on my part but upon list advice, one of the first things I did after buying my '88 was fuse that B+ wire.
Assuming the PS wire was causing the short, I have to wonder why that PS wire didn't fail first?
Neil.
VE7TBN
mikemtnbike
mikemtnbike is offline
PostPosted: Fri Jan 05, 2018 5:46 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I already replaced my PS switch ends with weatherproof connectors a while ago because mine looked like such garbage...but I'd really appreciate a photo of where the inline fuse should go. I went through dhaavers linked thread and it still wasn't clear to me, mostly because I hate wiring diagrams I guess.
Thanks!
1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie"
In an abundance of water, the fool is thirsty.
dobryan
dobryan is offline
PostPosted: Fri Jan 05, 2018 5:51 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Thanks!
Others are more expert than me but seeing this pic would make me put the fuse right on this burnt wire at the connection to the hot stud.Typically you want the fuse as close to the power source as you can.
Dave O
Join the Vanagon Rescue Squad on the VanAlert app.
http://vanalert.com/
Building a bus for travel in Europe
borninabus
Samba R&D Dept.
PostPosted: Fri Jan 05, 2018 8:44 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
i will post one once installed.
repairs are under way!
indeed, this is where it will be.
Page 1 of 4
