Koeppler Samba Member
Joined: April 21, 2011 Posts: 481 Location: Aging gracefully
Posted: Fri Jan 05, 2018 7:19 am Post subject: Re: The Stupid Question Thread |
My stupid question is: What can lead to excessive endplay in a motor with under 3k miles?
For the sake of this question assume the motor was set up correctly and endplay was verified by several people with a dial indicator to .004" but that within 3k miles it has increased to .008". It's a stock dual port 1600 with everything balanced and a new Brazilian case using Silverline bearings. |
Posted: Fri Jan 05, 2018 7:57 am Post subject: Re: The Stupid Question Thread |
Koeppler wrote: |
I am going to guess you had some crude between the shims that effected the initial endplay and once the crud worked its way out, the endplay jumped up by several thousandths. |
Posted: Fri Jan 05, 2018 9:25 am Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
Koeppler wrote: |
Maybe so! I hadn't thought of that.
So other than an assembly or measurement error, a bad bearing, or an imperfect case, there's not really anything else that causes endplay to grow?
If it matters the measurement is slightly different at different points in the rotation of the crank. .008" is the largest measurement and .006" is the smallest. |
Posted: Fri Jan 05, 2018 10:22 am Post subject: Re: The Stupid Question Thread |
Koeppler wrote: |
I would say that that is odd. Don't think I have ever checked the endplay by setting the crank in different positions though, so that may be something that I have just missed noticing. I would recommend not trying to tighten down on the endplay and getting it below spec at any point of rotation of the crankshaft. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Fri Jan 05, 2018 12:59 pm Post subject: Re: The Stupid Question Thread |
I found the answer to my stupid question from yesterday. And it turned out to be a bone-headed answer...
When I disconnected the positive lead from the battery to the starter, I neglected to re-install one of the other wires at the starter.
So put it back on, and all is well.
BBB, here we come! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Jan 05, 2018 1:24 pm Post subject: Re: The Stupid Question Thread |
KentPS wrote: |
BBB, here we come! |
Whoop Whoop! Have fun! Post some pictures for us bussless people (for the winter) up in the great white north. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Sun Jan 07, 2018 3:19 am Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
Double check the plug on your voltage regulator after that bozo in the boot pulled it out last week. Make sure it’s seated all the way in, and give it a careful unplug then plug for good measure. (Usually that can clean the contacts just enough to be useful.)
Bozo |
Thought you meant me!
Sure wish I could have driven out - I could be there too! Photos Please!
Way to troubleshoot, Kent! _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy" |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Sun Jan 07, 2018 3:43 pm Post subject: Re: The Stupid Question Thread |
Is there anything that locks the hinge pin that is hold the gas pedal to the floor?
I cant seem to push our the pin holding the hinge together. I tried WD40, a screwdriver and a hammer and it wont budge.
Anyone have any tips on a stuck pin most likely due to rust? Thanks. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jan 07, 2018 4:07 pm Post subject: Re: The Stupid Question Thread |
Terminatez wrote: |
Anyone have any tips on a stuck pin most likely due to rust? Thanks. |
You have to lift the spring out of the groove in the middle of the pin to release it, but if yours isn't even wiggling it's likely fused in by rust. More PB blaster, hammering, etc.... _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jan 07, 2018 4:56 pm Post subject: Re: The Stupid Question Thread |
The spring turned to dust already. So I guess I'll just let it sit on penetrating oil. Thanks _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Posted: Sun Jan 07, 2018 5:02 pm Post subject: Re: The Stupid Question Thread |
Terminatez wrote: |
The spring turned to dust already. So I guess I'll just let it sit on penetrating oil. Thanks |
If you can lay the pedal back for access you can drill a few small shallow holes along the top of the hinge to get the penetrating oil into the middle where it'll do some good. You can also try squishing the hinge slightly with large vice grips to flex it and break the rust bond.
WD-40 is good for keeping your missile dry, not so good for severly rusted joints, PB Blaster or LPS-1 is a better choice, even 50/50 Acetone and ATF seems to work better than WD. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jan 07, 2018 5:15 pm Post subject: Re: The Stupid Question Thread |
Got it thanks.
I think I'm going to drill a small hole on each side instead of the vice grip method.
Right, it's just what I had laying around. Going to bring from PB Blaster tomorrow.
First I'm going to let it sit with PB instead though, if I cant get that done I'll drill.
Btw, anyone have any experience using,
AcceleratorMod from Rusties Autowerkstatt
https://www.thesamba.com/vw/classifieds/detail.php?id=2099025
vs
Buttybits
https://www.thesamba.com/vw/classifieds/detail.php?id=1943615
I see a lot of info on the Buttybits ones, both are within my budget. Trying to see what the difference between them in terms of quality. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Posted: Sun Jan 07, 2018 5:25 pm Post subject: Re: The Stupid Question Thread |
Haven't seen that one before, but it looks like it'll do everything you need it to for quite a while. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jan 07, 2018 5:56 pm Post subject: Re: The Stupid Question Thread |
Whats... lowlight?
I see on his website it states "Lowlight AcceleratorMod" and a different one just called "AcceleratorMod".
Is this a common term I should know, or is this just different models for his product?
Edit:
Nvm, I should have searched first.
https://www.thesamba.com/vw/forum/archive/index.php/o-t--t-464588--start-0--index.html _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Convoy Samba Member
Joined: March 17, 2011 Posts: 312 Location: San Clemente
Posted: Tue Jan 09, 2018 4:29 pm Post subject: Re: The Stupid Question Thread |
I picked up the oversized 8mm CSP fuel tank outlet kit which includes the sealing washer, spigot and nut. Found here
http://www2.cip1.com/ProductDetails.asp?ProductCode=C31-298-221-113A
I'm revisiting this question again I had as I have reservations to what side the reddish color washer goes on. I'm not using a mesh filter like picture below as it wasn't included, unless I need it to properly seal.
The reddish washer resides either on the tank side or nut side as follows;
1. Tank + red washer + metal spigot flange + nut
2. Tank + metal spigot flange + red washer + nut
Wildthings I believe you mentioned its No. 1, though CSP emailed back with an old diagram illustrating the following.
It didn't come with a mesh filter, so if i install the spigot according to CSP the metal flange would mate up to the tank. So I ask what side does the red washer go onto? as this could be a deadly situation if not properly sealed.
UPDATE:
I may of figured it out though please correct if I'm wrong.
I need to pick up another sealing washer so the Spigot flange is sandwiched.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111209139 |
Posted: Tue Jan 09, 2018 5:41 pm Post subject: Re: The Stupid Question Thread |
If you are deleting the screen you'll need some sort of alternative soft item in that joint to act as a seal, the red washer may suffice, but it's really just supplied as more of a bearing between the nut and spigot to make torquing smooth, how fuel resistant it may be is something I doubt even the manufacturer will admit they know. A soft copper or aluminum washer will work best between the spigot and tank, or poke some holes in the screen and use it if you are bent on no screen. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
67ctbug Samba Member
Posted: Tue Jan 09, 2018 8:21 pm Post subject: Re: The Stupid Question Thread |
https://kalamazoo.craigslist.org/cto/d/68-vwbus-project/6408024859.html
Stupid question: Could you really order a bus with no slider? Seems a bit stupid to me... _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Tue Jan 09, 2018 8:49 pm Post subject: Re: The Stupid Question Thread |
No, that one has been discussed here before, too much beer and bondo as well as time on someone's hands. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jan 09, 2018 8:55 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
No, that one has been discussed here before, too much beer and bondo as well as time on someone's hands. |
LOL busdaddy thanks for the answer! _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
