Found my lost cat
Page: Previous  1, 2, 3
Petfisheric
Petfisheric is offline
PostPosted: Fri Jan 05, 2018 6:38 pm    Post subject: Re: Found my lost cat Reply with quote
It was supposed to be plastic but after looking over the work I think they may have used sand because the surface is pretty rough. I have a lot of work to do getting it ready for paint.
whozawhat
whozawhat is offline
PostPosted: Sat Jan 06, 2018 10:16 am    Post subject: Re: Found my lost cat Reply with quote
When mine was blasted it opened up the surface like a sponge, was very porous and required a lot of work to fill and smooth out. Mine was also done with soda and I had to rinse and neutralize a few times until I was happy there was no residue. It made me wonder if just spending the time with a DA would have been better. Luckily yours has the removable bumper extensions and you don't need to deal with the corrugated area that mine has, what a pain.
Petfisheric
PostPosted: Sun Jan 07, 2018 6:18 pm    Post subject: Re: Found my lost cat Reply with quote
Opened it up like a sponge is a good description. I tried the DA sander and it just clogged up after about 15 seconds, Heat gun was effective but slow and paint stripper was also slow not to mention messy. So the blasting was probably to best was to go. As I have looked over the car I found several more spots to repair that I wasn't aware of, so I will have so work to do over the next couple of weeks.
finster
finster is offline
PostPosted: Wed Jul 25, 2018 7:15 am    Post subject: Re: Found my lost cat Reply with quote
are there any problems with bonded-in steel on the puma bodywork?
how's this project coming on?
oprn
oprn is offline
PostPosted: Mon Aug 06, 2018 5:39 am    Post subject: Re: Found my lost cat Reply with quote
I just found this thread, too late now but personally I would have wet sanded that body with say 80 grit until it got down to the primer coat. The water cools the paint and prevents the melting and sand paper plugging you were experiencing.
Back 25 years ago we used a product call Feather Fill on fiberglass bodies to prep them for paint. It is a high build polyester resin based sprayable primer/surfacer that is very compatible in temperature expansion rates to fiberglass and helps prevent future alligator cracking of the finish coat.
All this is no doubt too late but update us anyway please. Nice car!
Petfisheric
PostPosted: Wed Aug 08, 2018 6:54 pm    Post subject: Re: Found my lost cat Reply with quote
The steel is fine. The project is kind of on hold temporarily while I rebuild an Airstream for the wife.
Petfisheric
PostPosted: Wed Aug 08, 2018 7:06 pm    Post subject: Re: Found my lost cat Reply with quote
[quote="oprn"]I just found this thread, too late now but personally I would have wet sanded that body with say 80 grit until it got down to the primer coat. The water cools the paint and prevents the melting and sand paper plugging you were experiencing.
I tried the wet sanding and it still was a problem unless I hand sanded. The acrylic lacquer paint was on extremely thick which was part of the problem it would take an hour to get a square foot sanded.
whozawhat
PostPosted: Sun Aug 12, 2018 8:32 am    Post subject: Re: Found my lost cat Reply with quote
I used a high build polyester primer from Duratec on my Puma and I liked the product filled well and sanded ok.
Petfisheric
PostPosted: Fri Aug 17, 2018 7:04 pm    Post subject: Re: Found my lost cat Reply with quote
I plan on using the same product, once I get to that stage.
Page 3 of 3
