samwise Samba Member
Joined: May 04, 2010 Posts: 611 Location: North Salt Lake, Utah
Tcash Samba Member
Posted: Mon Apr 06, 2015 1:59 pm Post subject: Third Brake Light |
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2345 Location: Bristol, Tennessee
Posted: Mon Apr 06, 2015 5:51 pm Post subject: Re: Third Brake Light |
My only concern is, without a gasket, the light will reflect off of the rear glass and light up the interior of the vehicle every time you apply the brakes. That's what has stopped me from mounting a third brake light on the rear of the head-banger. _________________
busdaddy wrote: |
...and try a few chubby ones until you find one you like.
1977 Westfalia P27
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon Apr 06, 2015 6:11 pm Post subject: Re: Third Brake Light |
1977_L63H_P27 wrote: |
My only concern is, without a gasket, the light will reflect off of the rear glass and light up the interior of the vehicle every time you apply the brakes. That's what has stopped me from mounting a third brake light on the rear of the head-banger. |
Interesting thought.
The GoWesty one is one of the best purchases I've made for my bus. Installs clean, it's cheap, and it noticeably increased following distance of those behind me. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Apr 06, 2015 7:15 pm Post subject: Re: Third Brake Light |
asiab3 wrote: |
The GoWesty one is one of the best purchases I've made for my bus. Installs clean, it's cheap, and it noticeably increased following distance of those behind me. |
Well, then you'd easily know if your brake light switches were working! _________________ Dave Cook
1973 Wild Westerner
My Thing |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Mon Apr 06, 2015 7:16 pm Post subject: Re: Third Brake Light |
So why not a gasket? If the light is within 1/2" of the glass.....
The gasket can be on the inside of the glass, not on the light. Nice thick foam weatherstripping ought to do. it can pass by the light rather than hitting it.
I'd prefer a light on the glass. Then I don't bang it when I'm carrying material or crawling in and out the back. |
Tcash Samba Member
72camper Samba Member
Posted: Sun Feb 21, 2016 7:11 am Post subject: Re: Third Brake light |
Here is what I ended up using...
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Sun Feb 21, 2016 11:02 pm Post subject: Re: Third Brake light |
Nice STOP light..where did you purchase it? _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Tue Jan 09, 2018 1:33 pm Post subject: |
dwill49965 wrote: |
obnoxiousblue wrote: |
Do you have any photos of yours mounted on your bus? |
Yes - took some today. Had to use a piece of cardboard to shield the sunlight to reduce glare and reflections. This light has been on my bus now for about 5 or 6 years. Its hard to see in these pics, but I would estimate the angle of the light lens is about 1 or 2 degrees below horizontal. The combination of the very slight "rake" of the rear VW hatch window (2 or 3 degrees? from vertical) offsets some of the angle of the lens in the Hella light. There's a couple more pics in my gallery of the light that I didn't post here.
I really like the overall look of this. I've gotten rear-ended TWICE in the last few months by distracted drivers. City life!! "Luckily" I was in my daily driver and not the bus but now I'm paranoid about getting hit in the bus come spring time
Is Daniel Stern still selling these lights? If he is, I'm assuming the one above is model is #38 on his website? _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Thu Jul 07, 2022 8:52 am Post subject: Re: Third Brake light |
I had found a vintage cats-eye brand light on eBay and modified it a bit to mount up on my rack. Ran the wire down into the engine vent on the drivers side to a terminal block for easy removal if the rack ever comes off. Had to test the wires at the master cylinder to see which one to tap off of. I had tried tapping into the wires at the rear of the bus a couple years ago and got the flashing issue with the signals on.
Works great, but I might end up chroming the ring that goes around the lense for a cleaner look. Maybe even add a "STOP" lense if I can find one cheap enough.
