Rotisserie Question?
ilustr8tor
ilustr8tor is offline
PostPosted: Mon Oct 09, 2017 3:16 pm    Post subject: Rotisserie Question? Reply with quote
I have gained access to a rotisserie to use when I paint my 65 resto. It is a factory made rotisserie, not sure brand but really nice unit with hydraulic lift feature. But I am going to have to fabricate the adapters to marry up to the body. The rotisserie has 2 - 2.5 in sq. steel tubes on each stand to attach to.
I have done some drawings of what I will build which utilizes 4 mounting points, the front and rear bumper brackets and the front and rear body mounts.
My question is do I really need all four mounting points or can I get away with just the bumper brackets? All fenders, doors and lids have been removed so just the shell.
Here are the drawings I have for the brackets.
I love this analog addition to my over digitzed life.
CiderGuy
CiderGuy is offline
PostPosted: Tue Oct 10, 2017 2:11 am    Post subject: Re: Rotisserie Question? Reply with quote
Save yourself some money and use two engine stands instead.
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything
ilustr8tor
PostPosted: Tue Oct 10, 2017 4:44 am    Post subject: Re: Rotisserie Question? Reply with quote
I have free use of the rotisserie and either way I would have to make a jig to match up to the bug. Still looking for and answer to my question.
crocksvw
crocksvw is offline
PostPosted: Tue Oct 10, 2017 5:38 am    Post subject: Re: Rotisserie Question? Reply with quote
Ciderguy how do you use two engine stands?
ilustr8tor
PostPosted: Tue Oct 10, 2017 7:02 am    Post subject: Re: Rotisserie Question? Reply with quote
here is a video on making a rotisserie out of engine stands:
https://www.youtube.com/watch?v=_i309EZDYZ4
still hoping to get an answer to my question headed to steel yard tomorrow need to know how much to get.
ilustr8tor
PostPosted: Tue Oct 10, 2017 7:24 am    Post subject: Re: Rotisserie Question? Reply with quote
this guy only used the bumper brackets, would make fabrication of adapter much easier.... any feelings? Are the bumper brackets good enough?
crocksvw
crocksvw is offline
PostPosted: Tue Oct 10, 2017 11:07 am    Post subject: Re: Rotisserie Question? Reply with quote
I don't see why they wouldn't. The body isn't that heavy when stripped down like that.
ilustr8tor
PostPosted: Tue Oct 10, 2017 4:25 pm    Post subject: Re: Rotisserie Question? Reply with quote
OK modified my design/drawings for the brackets using the bumper mounts only, this will make the fab much easier.
ilustr8tor
PostPosted: Wed Oct 25, 2017 7:22 am    Post subject: Re: Rotisserie Question? Reply with quote
All set
CiderGuy
CiderGuy is offline
PostPosted: Thu Oct 26, 2017 4:14 am    Post subject: Re: Rotisserie Question? Reply with quote
Without a brace along the bottom of the stand between the two ends, is it stable ?
56reddy
56reddy is offline
PostPosted: Sun Nov 05, 2017 7:05 am    Post subject: Re: Rotisserie Question? Reply with quote
I've never liked the idea of supporting the body from the bumper brackets. My rotisserie uses a frame that mounts to the heater channels. Look at the rotisseries that Cooker Restoration and Wrenn Metalworks use. They are very experienced.
1953 Zwitter 3 fold ragtop.
CiderGuy
CiderGuy is offline
PostPosted: Tue Nov 07, 2017 6:51 am    Post subject: Re: Rotisserie Question? Reply with quote
That works as long as you're not replacing the heater channels, or working on the bottom of the body where most of the rust is.
Seems to me that bracing it on the heater channels would be limiting.
ilustr8tor
PostPosted: Mon Nov 13, 2017 1:03 pm    Post subject: Re: Rotisserie Question? Reply with quote
this worked out very well, heater channels were replaced before I mounted it on rotisserie. Final paint next weekend. I will post photos.
robbiecanter
robbiecanter is offline
PostPosted: Mon Nov 20, 2017 10:19 am    Post subject: Re: Rotisserie Question? Reply with quote
This is how I built mine.
Any car will bolt to it with their own bumper bars.
52' Split
64' Bug-turbo
68' Notch
84' westfalia
87' 4runner
91' 2.9 vr6 coupe
13' s4
17' alltrack
ilustr8tor
PostPosted: Mon Dec 04, 2017 6:16 pm    Post subject: Re: Rotisserie Question? Reply with quote
In color now baby"
ilustr8tor
PostPosted: Mon Dec 04, 2017 7:03 pm    Post subject: Re: Rotisserie Question? Reply with quote
going to shoot tinted Raptor Liner inside fenders, firewall and behind rear seat area.
pbenn
pbenn is offline
PostPosted: Tue Jan 09, 2018 2:40 pm    Post subject: Re: Rotisserie Question? Reply with quote
What color is that? It's nice.
ilustr8tor
PostPosted: Tue Jan 09, 2018 7:33 pm    Post subject: Re: Rotisserie Question? Reply with quote
VW L313 Reed Green
