sd73vdub Samba Member
Joined: January 10, 2018 Posts: 13 Location: San Diego, CA
Posted: Thu Jan 11, 2018 1:06 am Post subject: Re: What to do w my 1973 Bay window type 2? |
Abscate wrote: |
On the positives you are in Bus heaven, so you can find a dry Bus with a bad engine and get a driver together cheap, without traveling too far , where you are! This is the place to get help on sorting the engine and mechanicals out.
Good luck and dont forget pictures. We don't have enough Bays with Huskies in them. |
I like it all! Sounds good, thanks Abs:) |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Jan 11, 2018 4:36 am Post subject: Re: What to do w my 1973 Bay window type 2? |
I think that the Wild Westerner guys on here would like to get some numbers off that bus...... |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Jan 11, 2018 7:00 am Post subject: Re: What to do w my 1973 Bay window type 2? |
If the under carriage and mechanics are as good as you say, I personally, don't see why you couldn't do a cheap at home sand, osphoro, and paint. You wouldn't have to take anything out of the inside. You would need new window seals though. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
danfromsyr Samba Member
Posted: Thu Jan 11, 2018 7:47 am Post subject: Re: What to do w my 1973 Bay window type 2? |
crawl under with your camera and take some good clear pics of the front beam & beam to frame mounting.
then in the back, the crosstube just ahead of the rear wheels that the rear suspension hangs off from..
if the frame and frame to suspension connections are tight.. roll it as it is..
F'ugly but sound(ish).
and relish in that you won't have to have the 'chat' at every gas station or worry in a grocery store parking lot that the guys with pristine Bus need to.
the view looks the same from the windshield & sliding door no matter the C'rust. _________________
Abscate wrote: |
Posted: Thu Jan 11, 2018 9:37 am Post subject: Re: What to do w my 1973 Bay window type 2? |
alman72 wrote: |
What kind of numbers alman? Not understanding. Thanks! |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Jan 11, 2018 9:43 am Post subject: Re: What to do w my 1973 Bay window type 2? |
sd73vdub wrote: |
alman72 wrote: |
Its a Wild Westerner Bus - which has its own thread on this special version - search on it, ill post a link once I get rid of this lawyer. Does anyone have a spare 55 gallon drum...'The Counselor"
https://www.thesamba.com/vw/forum/viewtopic.php?t=527392&highlight=wild+westerner _________________ .ssS! |
Posted: Thu Jan 11, 2018 11:41 am Post subject: Re: What to do w my 1973 Bay window type 2? |
Spike0180 wrote: |
If the under carriage and mechanics are as good as you say, I personally, don't see why you couldn't do a cheap at home sand, osphoro, and paint. You wouldn't have to take anything out of the inside. You would need new window seals though. |
Hey Spike. Yeah, it's pretty minimal underneath considering, and it runs pretty damn solid. It's not a daily driver and i'm wouldn't really take it on an extended trip (partly cause i'm paranoid and not mechanically inclined enough to fix certain items that may go awry, although as previously mentioned the prior owners went to other countries w it, but again I believe the husband was very mech inclined). It runs and sounds like a normal VW bus!
I like your suggestion and appreciate yours and all others input here. Thank you! It DEFINITELY can use new seals even already btw. Thanks! |
Posted: Thu Jan 11, 2018 12:08 pm Post subject: Re: What to do w my 1973 Bay window type 2? |
Abscate wrote: |
sd73vdub wrote: |
alman72 wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?t=527392&highlight=wild+westerner |
WoW, Abs, thats super cool!! Amazing that thread has 120 pages! Thanks for the post and info:) |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Jan 11, 2018 12:11 pm Post subject: Re: What to do w my 1973 Bay window type 2? |
I was in your same spot last year- bought a 78 bus with out looking close enough at the roof line-- turns out the under and rockers were great- with new trans and rebuilt motor--- drove excellent- the bad news was- like yours it had sat exposed to the Santa Cruz salt air for way to long- the entire cab roof and gutters (hidden by Riviera top )were toast.
Heart broken- not to mention the cost- I lucked out big time with a scrapped body having all the bits I needed--AND neighbor John took an interest in fitting an entire roof on the bus. Total cost $1200 to replace almost all the rust- SO- even if your gutters and front are toast- the "spirit of samba " to the rescue.
[img][/img]
[img]
[/img] _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Jan 11, 2018 2:09 pm Post subject: Re: What to do w my 1973 Bay window type 2? |
williamM wrote: |
[img][/img]
[img]
[/img] |
$1,200?! Wow thats awesome, and mighty nice of John the neighbor to help obviously:) |
Posted: Thu Jan 11, 2018 3:09 pm Post subject: Re: What to do w my 1973 Bay window type 2? |
I would roll that thing topless in a heartbeat...
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu Jan 11, 2018 3:42 pm Post subject: Re: What to do w my 1973 Bay window type 2? |
Abscate wrote: |
We ain't interested in seeing your man boobs.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Jan 11, 2018 4:37 pm Post subject: Re: What to do w my 1973 Bay window type 2? |
TDCTDI wrote: |
Abscate wrote: |
https://goo.gl/images/jQVR9i |
I got a bad furniture problem. My chest fell into my drawers _________________ .ssS! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Thu Jan 11, 2018 7:26 pm Post subject: Re: What to do w my 1973 Bay window type 2? |
vwwestyman wrote: |
As I said in the Wild Westerner thread, I really like those high-roof Westerners! There seems to have been a few made. I'd like to have one, some time. |
Try checking the San Diego Craigslist... _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Fri Jan 12, 2018 7:00 am Post subject: Re: What to do w my 1973 Bay window type 2? |
Ha ha, I also said that I didn't have the spare cash at the moment in that thread. So I'll have to make due with the "boring" passenger WW and ordinary Westy I've got at the moment! I have to admit that I don't NEED a 3rd Bus right now!
There was a non-running but less rusty (though it may have had some kind of other body damage, I don't recall for sure) high roof WW that sort of languished on ebay for several months a couple years ago. Sometimes I wish I had gone after it back then. _________________ Dave Cook
1973 Wild Westerner
My Thing |
