sethpat Samba Member
Posted: Wed Jan 10, 2018 12:21 pm Post subject: Sink Drain Options (No cutting) |
Long story short, I'm too chicken shit to cut a giant hole in my new cargo floor to accommodate the stock floor drain. I'm thinking about running the drain pipe to a small piece of PVC and connecting to a length of flexible tubing that fits into a removable collection tank. Has anyone done something like this? I'm thinking that I wouldn't need anything larger that 2-3 gallons so long as it's easy enough to remove and dump out.
Cheers,
Seth _________________ Unnamed 1986 Syncro
Frankenbus (sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=674133&highlight=
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Cam 264* .402 lift |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Jan 10, 2018 1:37 pm Post subject: Re: Sink Drain Options (No cutting) |
How often do you use the sink? My favorite solution was an easily removable stainless steel dog bowl used as a sink, so you just fill it gradually and dump it outside as needed. Easier to remove for transporting large cargo, too.
www.airschooled.com |
Posted: Wed Jan 10, 2018 3:43 pm Post subject: Re: Sink Drain Options (No cutting) |
asiab3 wrote: |
Robbie |
To be honest, I've never used it besides to test the pump. I just got the bus back together and on the road. Figure I'll just use it every once in awhile
Cheers,
Frankenbus (sold)
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Jan 10, 2018 4:17 pm Post subject: Re: Sink Drain Options (No cutting) |
The sink in my '69 camper doesn't have a drain. I find it very handy for loose change and temporary storage of small items. It's easily removed and I use it occasionally for bathing.
Aloha
tp |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Wed Jan 10, 2018 6:07 pm Post subject: Re: Sink Drain Options (No cutting) |
The sink in our 79 is connected to a plastic jug under the water container via flexible hose. The jug holds more than the supply tank, and can be removed by unscewing the hose clamp. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Thu Jan 11, 2018 10:22 pm Post subject: Re: Sink Drain Options (No cutting) |
I got rid of the dumb black 1 1/2" pipe and went with a standard RV P-trap like the Vanagon Westfalia has
http://www.gowesty.com/product/faucets-plumbing/2424/p-trap-sink-drain-kit-?v= _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy
Posted: Thu Jan 11, 2018 10:41 pm Post subject: Re: Sink Drain Options (No cutting) |
Thanks for the replies everyone. Otiswesty, what do you have the P trap running to ? , _________________ Unnamed 1986 Syncro
Frankenbus (sold)
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Fri Jan 12, 2018 12:12 am Post subject: Re: Sink Drain Options (No cutting) |
I have a collapsible 5 gallon water tank and flex hose. Rarely gets used. Tank is collapsed when empty with bottled water on top of it so amount of water is smaller than tank. There is a removable shelf between tank and water bottles. As the tank expands the shelf comes out. My 1970 has the stove/sink/fridge set up out of a 78 Westphalia. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
Posted: Fri Jan 12, 2018 10:33 am Post subject: Re: Sink Drain Options (No cutting) |
sethpat wrote: |
Thanks for the replies everyone. Otiswesty, what do you have the P trap running to ? , |
The P-trap just runs down to the adaptor out the floor like before. Increased my sink cabinet shelf size into the back left corner.
I made a new plate for under the floor out of stainless 16ga sheet, but with a smaller hole
Just a regular guy |
Posted: Sat Jan 13, 2018 11:33 am Post subject: Re: Sink Drain Options (No cutting) |
otiswesty wrote: |
sethpat wrote: |
Right on, I like this solution a lot, still have to drill a hole, but very small compared to the original. It's also nice and cheap which is a big plus
Thanks for the input everyone ! _________________ Unnamed 1986 Syncro
Frankenbus (sold)
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
