Loose alternator bolt?
Globespotter
Globespotter is offline
PostPosted: Sat Jan 13, 2018 12:09 pm    Post subject: Loose alternator bolt? Reply with quote
Running my 77 Westy with Type 4 today - mid winter warm up, and I noticed the hex bolt holding on the alternator bracket was moving slightly back and forth. Is it supposed to do that, or is it supposed to be tight?
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
Wasted youth
Wasted youth is offline
PostPosted: Sat Jan 13, 2018 2:27 pm    Post subject: Re: Loose alternator bolt? Reply with quote
The bolt that anchors to this nut? (Photo credit: hazetguy)... or the lower bolt that is underneath the engine? Neither should have any movement in my opinion.
rottenkid
rottenkid is offline
PostPosted: Sat Jan 13, 2018 2:28 pm    Post subject: Re: Loose alternator bolt? Reply with quote
It should be tight. I believe I used a carriage bolt when I put mine together. So that hexbolt should be tight.
timvw7476
timvw7476 is offline
Everything is supposed to be tight, as in the slider bolt arrangement
& the carriage bolt, (it's indexed by the alternator tin, nut is near the sump
fill tube)
rottenkid
PostPosted: Sat Jan 13, 2018 2:29 pm    Post subject: Re: Loose alternator bolt? Reply with quote
You are referring to the lower bolt? And not the bolt that adjust the fan belt.
Globespotter
PostPosted: Sat Jan 13, 2018 4:56 pm    Post subject: Re: Loose alternator bolt? Reply with quote
The bolt accessed in the engine compartment behind the oval plastic cover.
Amskeptic
Amskeptic is offline
PostPosted: Sat Jan 13, 2018 5:24 pm    Post subject: Re: Loose alternator bolt? Reply with quote
That bolt should be secure. The nut that holds the bracket to the fan housing above that bolt is also supposed to be secure. The carriage bolt that holds the bottom of the alternator to the fan housing via a stamped metal bracket is supposed to be secure via 13mm nut accessible from underneath. The two 13mm bolts that hold that alternator pivot bracket to the fan housing need to be secure.
I am running into some real issues with these poor engines getting killed by cracks through all of the above, plus the alternator face tin, when they loosen or when people run an obviously imbalanced engine. These parts are drying up. We have to keep them happy.
Colin
www.itinerant-air-cooled.com
Globespotter
PostPosted: Sat Jan 13, 2018 5:28 pm    Post subject: Re: Loose alternator bolt? Reply with quote
Thanks Colin. I figured it should not be moving. Just noticed it when I was doing a mid winter start and warm up.
Wildthings
Wildthings is offline
PostPosted: Sun Jan 14, 2018 5:50 pm    Post subject: Re: Loose alternator bolt? Reply with quote
If the pivot bolt has been loose for long, there is a good chance the holes will have wallowed out by now and the alternator pulley no longer lining up well with the pulley on the crank.
Globespotter
PostPosted: Mon Jan 15, 2018 12:15 am    Post subject: Re: Loose alternator bolt? Reply with quote
Not an issue. Right now it's barely moving. Thanks.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jan 15, 2018 12:42 pm    Post subject: Re: Loose alternator bolt? Reply with quote
the bottom U-bracket cracks then the shroud wears where it wiggles and destroys the mount point.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Globespotter
PostPosted: Mon Feb 19, 2018 1:36 pm    Post subject: Re: Loose alternator bolt? Reply with quote
I got a chance to get under the bus today and check things out. The lower bolt was completely missing. I replaced it and of course now the bracket is nice and firm, however when I tighten the hex bolt, I can't get it tight enough. I think I will need to replace the hex bolt/nut. It is tight, but there is still some movement. Hopefully I can find those parts - 2, 3 & 4 in this pic:
Wildthings
PostPosted: Mon Feb 19, 2018 2:50 pm    Post subject: Re: Loose alternator bolt? Reply with quote
The nut and bolt are pretty basic, unless the bolt is too long and has an unthreaded section I can see how it could not tighten sufficiently. Maybe all you would need to do is add a couple of extra washers under the head?
lil-jinx
lil-jinx is offline
PostPosted: Mon Feb 19, 2018 6:01 pm    Post subject: Re: Loose alternator bolt? Reply with quote
Would it be possible that the adjusting arm that special nut rides in has worn thinner then the portion of the nut that sits in the slot so when you clamp it down tight it just bottoms on the nut and not the arm,allowing it to move.
1968 Dune Buggy
1974 parts bus
timvw7476
PostPosted: Mon Feb 19, 2018 7:57 pm    Post subject: Re: Loose alternator bolt? Reply with quote
There are two bolts holding the lower pivot point as well,
if the sliding upper adjustment is left loose/incorrect for long, that lower
mount does get beaten loose from the blower shroud.
Time to check all mounting points, six total.
Globespotter
PostPosted: Mon Feb 19, 2018 8:12 pm    Post subject: Re: Loose alternator bolt? Reply with quote
It's got to be something like that. I may try to add a washer or two and see if I can tighten it up.
Thanks,
lil-jinx
lil-jinx is offline
PostPosted: Tue Feb 20, 2018 6:11 am    Post subject: Re: Loose alternator bolt? Reply with quote
Or shave down the nut a little so it don't protrude thru the bracket slot.
1968 Dune Buggy
1974 parts bus
Globespotter
PostPosted: Sat Feb 24, 2018 12:15 pm    Post subject: Re: Loose alternator bolt? Reply with quote
Great tip.
Today I did just that plus added a washer. It tightened up beautifully!
Appreciate the responses. That's why I love The Samba!
SGodinho
SGodinho is offline
PostPosted: Sun Nov 17, 2019 7:50 pm    Post subject: Re: Loose alternator bolt? Reply with quote
I'm looking for the bolt that is #19 in the diagram. Anyone know what size it is? I can't find it for the life of me.
ivwshane
ivwshane is offline
PostPosted: Sun Nov 17, 2019 10:22 pm    Post subject: Re: Loose alternator bolt? Reply with quote
021903243a
***edit
It looks like I can’t read:( you are asking about the bolt not the nut.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
