Would you? Gas line replacement
Page: 1, 2, 3  Next
markeaton
markeaton is offline
PostPosted: Sat Jan 13, 2018 11:31 am    Post subject: Would you? Gas line replacement Reply with quote
Hello-
The rubber gas line that is already in seems to look good. I ran a smooth electrical snake thru and no obstruction. Not sure how long it has been in there.
I do have a new 5MM ID FUEL HOSE. CLOTH COVERED that I can replace with. I did notice that the current rubber fuel line in, has a little bit bigger diameter.
So I guess I'm wondering what others would do ... keep it or replace?
Thanks,
Mark
Q-Dog
Q-Dog is offline
PostPosted: Sat Jan 13, 2018 11:46 am    Post subject: Re: Would you? Gas line replacement Reply with quote
I replace all fuel lines every 2-3 years.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Cusser
Cusser is offline
PostPosted: Sat Jan 13, 2018 11:47 am    Post subject: Re: Would you? Gas line replacement Reply with quote
You state that the existing hose is a little large. So just for that reason I would replace.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
markeaton
PostPosted: Sat Jan 13, 2018 11:53 am    Post subject: Re: Would you? Gas line replacement Reply with quote
Thanks Q dog
Cusser ... just curious why you would replace with a slightly smaller diameter?
Cusser
Cusser is offline
PostPosted: Sat Jan 13, 2018 12:15 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
I would replace with the CORRECT inner diameter braided fuel hose if mine. I bought the replacement fuel hose from JBugs.com. 5mm i.d. http://www.jbugs.com/product/N203551.html
In fact, I did this last year on my 1970 when I resurrected it (on mine the fuel line from tank to pan was still the original, and maybe also for the pan back to the metal line through the tin).
VW_Jimbo
VW_Jimbo is offline
PostPosted: Sat Jan 13, 2018 12:17 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
I change out my fuel hoses, every 7 years, with the correct hose, bought fresh. Do not use a larger hose or old hose. Rubber starts deteriorating as soon as it hits the air. It has a shelf life of no more than 12 good years under perfect conditions. Any impact (smog) accelerated the hose greatly. So, every 7 for me with quality 5mm braided hose.
Jimbo
ASE Master Technician 1990 - 2001
1955 Bug with Semaphores (Sold), 1968 Bug (Sold), 1972 Squareback (Sold), 1973 Super Beetle (Freeway accident - totaled), 1979 Rabbit (Sold), 1970 Bug Cal style (Sold), current project is a 1970 Bug
markeaton
Gotcha ... so I guess I need to research if the 5MM is a correct diameter for 74 beetle
markeaton
PostPosted: Sat Jan 13, 2018 12:19 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
This is the one I purchased:
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111209185
Cusser
Cusser is offline
PostPosted: Sat Jan 13, 2018 12:21 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
"Product Description: This VW Braided Fuel Hose is German made. The inside diameter is 5 millimeters and it is sold by the foot. This is the size of fuel hose to be used from the gas tank to the metal fuel line and in the engine copartment from metal lines to fuel pump and to the carburetor. This is for use with engines with carburetors only- not for fuel injection. "
1974 Beetle is carbureted.
markeaton
PostPosted: Sat Jan 13, 2018 12:44 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
Thanks Cusser ... looks like the one I bought at WWest is the same...
Thanks for the feedback
Buggeee
Buggeee is offline
PostPosted: Sat Jan 13, 2018 12:51 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
Um.... Dudes....
Doesn't that picture look like the rubber line is entering the tunnel?
Mark - Has the metal line through the tunnel been replaced with a rubber one?
Maybe I just need glasses, I don`t even know if it's possible to do what I just described anyway. Well it's cold outside and it was a good excuse to say hello to everybody so hello everybody.
Rebuilt Salvage
The Bug http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
The Bug House http://www.fiberglassrv.com/forums/f56/buggeees-1973-playpac-build-thread-80903.html
The Minion's Bug https://www.thesamba.com/vw/forum/viewtopic.php?t=690801
markeaton
PostPosted: Sat Jan 13, 2018 12:58 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
Hi Buggeee
Yes ... the entire length from where it starts under where the gas tank would go, into the tunnel, all the way thru the tunnel and then out from the read driver side "fork"; and then from there it would attached to the carb.
markeaton
PostPosted: Sat Jan 13, 2018 1:06 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sat Jan 13, 2018 1:09 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
Oh the things you’ll see when working on old cars. I’d run a new metal line it’s not that big a deal.
Q-Dog
Q-Dog is offline
PostPosted: Sat Jan 13, 2018 1:21 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
So would I. I didn't realize the metal line was gone. I don't like to run a rubber line where I can't see it, like inside the tunnel.
Brian
'69 Dune Buggy
'70 Beetle
markeaton
PostPosted: Sat Jan 13, 2018 1:34 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
So Zundfolge1432 and Q Dog ....
I guess I didn't realize one could run a metal line from the tank to carb.
Is it run along the tunnel inside the car (buggy)? Is there a diagram you might know where I might put my fingers on?
The run inside he tunnel seems like that is how is was designed originally.
I guess I need to ponder both ideas (original and metal line) before I commit.
Thank you.
joey1320
joey1320 is offline
PostPosted: Sat Jan 13, 2018 1:56 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
You can run a metal line inside the car.
VW had a service bulletin on it.
**1971 Super Project
**My VW YouTube Channel - AirCooled-Tech
https://www.youtube.com/channel/UCcaFyFZRSq6BrR8_MO6va8Q
dirtkeeper
dirtkeeper is offline
PostPosted: Sat Jan 13, 2018 2:20 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
Thank you.
I thought the metal gas line inside the tunnel was standard all years. I believe the rubber you have was done by the PO and is not original. I have replaced mine sometIme in the last 10 years during engine or tranny replacement while I was “ there”. But non of thE 20 year old stuff I had pulled out was “was about to break” or so dried and cracked that it was on its deathbed. I agree that the fuel lines should be Inspected regularly. But I think it is excessive to replace every 2 years unless you use really crappy line or it is all exposed to direct sunlight
Cusser
Cusser is offline
PostPosted: Sat Jan 13, 2018 2:27 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
So would I. I didn't realize the metal line was gone. I don't like to run a rubber line where I can't see it, like inside the tunnel.[/quote]
That was a good catch on the rubber line being INSIDE the tunnel, I didn't notice that.
Yes, I'd replace with new steel line inside the tunnel.
markeaton
PostPosted: Sat Jan 13, 2018 4:59 pm    Post subject: Re: Would you? Gas line replacement Reply with quote
Thank you all for your responses AND diagrams....
So from what I am reading a metal line seems to be the popular choice... which begs the question: why do places sell non-metal fuel lines if not a good idea ... or is it more of a personal preference from you gents?
So if I do replace with a metal line, I am thinking of going inside the tunnel as it seems unsafe to have a metal line riding along the "outside" of the tunnel which is exposed to me or a rider kicking it (it's a dune buggy).
I'll post what I do end up doing.
Thanks !
Page: 1, 2, 3  Next
