Installing aftermarket turn signal switch
Page: Previous  1, 2
Tom Powell
Tom Powell is offline
PostPosted: Fri Oct 25, 2013 9:33 pm    Post subject: Reply with quote
Gary:
Hope this will be an inspiration to get the job finished.
Aloha
tp
aeromech
aeromech is offline
PostPosted: Sat Oct 26, 2013 5:30 pm    Post subject: Reply with quote
Tom, I'm not sure what I'm seeing there.
So to close out this thread let me first say a big "thank you" to Telford Dorr who walked me through some testing over the phone. The switch is now installed and everything is working correctly. Two important points I need to make. 6 of the wires matched the bus color code. The other two were somewhat different. The grey/black wire hooks up to the purple/black in the bus and the other was the green/black/white wire which really looked more like a green/white. It's hard to see.
Another important point is I found the half moon retainer would hit the circuit board when tightened down to the column. I had to bend it some so it would clear. Not positive but this could have been part of my problem.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SBL74
SBL74 is offline
PostPosted: Fri Jan 05, 2018 5:16 pm    Post subject: Re: Installing aftermarket turn signal switch Reply with quote
For a 1973 Type 2 Campmobile, is there supposed to be a signal cancelling mechanism after you turn? My turn signals work fine but do not cancel. I am not sure it is worth the trouble to go through all this just for cancelling.
steve
asiab3
asiab3 is offline
PostPosted: Fri Jan 05, 2018 5:50 pm    Post subject: Re: Installing aftermarket turn signal switch Reply with quote
steve
Hi Steve,
All year bay buses should cancel their turn signals. Can you confirm that your steering wheel to switch gap is about 1mm? That seems to be a large problem I find on othersí cars. Next, can you peek between the wheel and switch and see the metal cancelling tab that rotates with the steering wheel? When the wheels are pointed straight, is the tab on the left or right side of the steering wheel?
Robbie
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
alman72
alman72 is offline
PostPosted: Sat Jan 06, 2018 10:02 am    Post subject: Re: Installing aftermarket turn signal switch Reply with quote
on the 73 the plastic that holds the cancel tab mech likes to crack. usually in the middle. pic showing a crack, not in the middle.
SBL74
SBL74 is offline
PostPosted: Tue Jan 09, 2018 9:28 am    Post subject: Re: Installing aftermarket turn signal switch Reply with quote
Thank you, I will look.
steve
gitchesum
gitchesum is offline
PostPosted: Tue Jan 09, 2018 10:58 pm    Post subject: Re: Installing aftermarket turn signal switch Reply with quote
My problem was the canceling cam didnít reach the switch dogs. I bent the corners out slightly and works fine now. I can post a pic if needed.
Looking for SP Kadron manifolds...please !!
57 SC
61SC
68DC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go...
61 BUS Premium Member
61 BUS is offline
PostPosted: Sat Jan 13, 2018 4:43 pm    Post subject: Re: Installing aftermarket turn signal switch Reply with quote
I tried one of the aftermarket switches for my '71 about 3 years ago. Lasted less than a year before it started giving me problems. I took it out and bought a NOS switch which was way more expensive but has worked flawlessly since then. If you can, look for a NOS switch and only cry once.
61 Bus, 66 Fastback, 71 Bus, 76 Beetle, 2012 Fiat 500
Page: Previous  1, 2
Page 2 of 2
