Good quality pressure plate
blue72beetle
blue72beetle is offline
PostPosted: Sat Jan 13, 2018 2:42 pm    Post subject: Good quality pressure plate Reply with quote
I ordered a crank and flywheel from CB Performance awhile back. I asked them to balance them before they sent them out. They said they would only balance it if I ordered a pressure plate too.
"Ok, I'll buy your stock pressure plate"
"Oh, we don't balance the Brazilian pressure plates, they never balance well"
I don't need a fancy stage 13 clutch, so who sells a good STOCK pressure plate?
-Andy-
-1970 Ghia-
-1971 Bus-
aeromech
aeromech is offline
PostPosted: Sat Jan 13, 2018 3:54 pm    Post subject: Re: Good quality pressure plate Reply with quote
I have the rotating parts being balanced right now for a new build. That includes a new Sachs pressure plate.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Amskeptic
Amskeptic is offline
PostPosted: Sat Jan 13, 2018 4:47 pm    Post subject: Re: Good quality pressure plate Reply with quote
NOBODY.
But, here's what you do. Look for a Sachs pressure plate with a Croatia country of origin. It will have a full radius perimeter unlike those abominable cheap Brazilian ones with the tiny little "index" tabs to center it in the flywheel.
Ask the balancer to drill out the pressure plate itself, not the stamped steel cover. It can be done.
I just slapped on a used three arm dinosaur from 1969 on my bus, and I couldn't be happier. Intrinsically balanced, imagine that.
Colin
www.itinerant-air-cooled.com
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Sun Jan 14, 2018 10:33 am    Post subject: Re: Good quality pressure plate Reply with quote
Dang! CB Performance wouldn't sell me a stock camshaft either last week! What is it with suppliers not wanting us to go slow and economically for millions of miles???
Wolfsburg West and JBugs both sell the Croatian pressure plates for about $100. They will be marked "German" on the website, and "Made in Croatia" on the packaging and part itself.
The exact plates were made in Germany up until last year, when the production was shifted. As far as I can tell, the manufacturing equipment is identical, so it's probably still a great part.
But yeah, NYCnthia is building her new engine soon, and we scored a 1970 German plate at the swap for $10.
Such is life, I suppose.
Robbie
www.airschooled.com
blue72beetle
PostPosted: Sun Jan 14, 2018 6:43 pm    Post subject: Re: Good quality pressure plate Reply with quote
Thanks for letting me know about Wolfsburg West. I had previously checked their site, but I only saw the Brazilian one. Found the Slovak one and ordered it.
I'm probably going to get a stock cam and lifters from Web Cam.
-Andy-
-1970 Ghia-
-1971 Bus-
Gumboguy
Gumboguy is offline
PostPosted: Mon Mar 05, 2018 12:38 pm    Post subject: Re: Good quality pressure plate Reply with quote
If a pressure plate goes bad, what are the symptoms?
Does the clutch slip like when they wear out out? High-low revs?
Wildthings
Wildthings is offline
PostPosted: Mon Mar 05, 2018 1:52 pm    Post subject: Re: Good quality pressure plate Reply with quote
The surface will begin to show excess checking and maybe be discolored. Once things have been hot enough that the springs loose their temper the pressure plate is shot. An abused pressure plate can go bad in minutes, say the adjustment is off and the clutch begins slipping on a hill or if someone gets stuck and just abuses the clutch trying to get it out. You can also lay a straight edge across the wear face of the pressure plate and see how much of a cone shape it has developed over time. Don't have a good quantitative limit here, maybe .020", don't know for sure.
Pretty much if you have allowed the clutch to begin slipping in normal use the remaining life of the pressure plate is going to be used up in hours or even minutes. You can't see it with the tranny mounted to the engine (maybe drill a hole in the bellhousing and use a boroscope?), but once the disc has worn to the point that the release fingers begin to rest against the cover then slippage is imminent with wear accelerating with heat wrecking everything.
If you change you disc out preemptively before the fingers begin resting against the cover you can very often reuse the cover. Pretty much if my discs have 40-50K or more miles on them, they get replaced if and when I have easy access.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Mar 05, 2018 1:57 pm    Post subject: Re: Good quality pressure plate Reply with quote
the diaphragm will crack or lose its temper and the tension on the driven disk will go away. It will feel really soft when you step on the clutch or make noise. If it has individual springs one or more may go soft and cause lots of chatter and vibration when engaging it.
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
1971 (sold)
1977
Gumboguy
Gumboguy is offline
Thanks.
So in your opinion if the pressure plate is shot, the clutch pedal will feel really soft when depressed and it won't disengage the clutch mechanism?
Manfred58sc
Manfred58sc is offline
PostPosted: Mon Mar 05, 2018 2:03 pm    Post subject: Re: Good quality pressure plate Reply with quote
I just received a new "Sachs" clutch that was a total disaster. The Box says "made in Germany" and the part says "made for Sachs"...no country listed. I no longer trust that brand. Mexican parts seem about the best these days.
Drivin' a split and a fat chick!!
Wildthings
Thanks.
Yes the spring tension will go down and not enough pressure will be available against the disc, even a new one, to prevent slipping. Clutch chatter may or may not be caused by a pressure plate that has gotten hot or worn unevenly. If the clutch is chattering then even if the various pieces of the clutch look fine, then changing them all out may well be warranted.
Gumboguy
Gumboguy is offline
PostPosted: Mon Mar 05, 2018 2:16 pm    Post subject: Re: Good quality pressure plate Reply with quote
That totally makes sense.
Thank you. Smile
quote="Wildthings"]
Thanks.
Yes the spring tension will go down and not enough pressure will be available against the disc, even a new one, to prevent slipping. Clutch chatter may or may not be caused by a pressure plate that has gotten hot or worn unevenly. If the clutch is chattering then even if the various pieces of the clutch look fine, then changing them all out may well be warranted.[/quote]
SGKent is offline
PostPosted: Mon Mar 05, 2018 7:17 pm    Post subject: Re: Good quality pressure plate Reply with quote
as a general rule I figure an original quality clutch pressure plate on a street car should be good for 100,000 - 150,000 miles. If they get oily and get hot spotted then you can try sanding them to get a cross hatch back .If someone is abusive then they can last a week. The racing plates don't last nearly as long. Driven disk should last 40,000 - 60,000 miles unless they get oily. I believe LUK was an original manufacturer. Maybe they might be better these days, I don't know. The quality of steel being used seems to be falling in many areas.
1971 (sold)
1977
