Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Jan 13, 2018 2:27 pm Post subject: Re: Loose alternator bolt? |
The bolt that anchors to this nut? (Photo credit: hazetguy)... or the lower bolt that is underneath the engine? Neither should have any movement in my opinion.
Last edited by Wasted youth on Sat Jan 13, 2018 2:30 pm; edited 2 times in total |
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Sat Jan 13, 2018 2:28 pm Post subject: Re: Loose alternator bolt? |
It should be tight. I believe I used a carriage bolt when I put mine together. So that hexbolt should be tight. |
timvw7476 Samba Member
Everything is supposed to be tight, as in the slider bolt arrangement
& the carriage bolt, (it's indexed by the alternator tin, nut is near the sump
fill tube) |
Posted: Sat Jan 13, 2018 2:29 pm Post subject: Re: Loose alternator bolt? |
You are referring to the lower bolt? And not the bolt that adjust the fan belt. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Jan 13, 2018 5:24 pm Post subject: Re: Loose alternator bolt? |
Globespotter wrote: |
The bolt accessed in the engine compartment behind the oval plastic cover. |
That bolt should be secure. The nut that holds the bracket to the fan housing above that bolt is also supposed to be secure. The carriage bolt that holds the bottom of the alternator to the fan housing via a stamped metal bracket is supposed to be secure via 13mm nut accessible from underneath. The two 13mm bolts that hold that alternator pivot bracket to the fan housing need to be secure.
I am running into some real issues with these poor engines getting killed by cracks through all of the above, plus the alternator face tin, when they loosen or when people run an obviously imbalanced engine. These parts are drying up. We have to keep them happy.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Sun Jan 14, 2018 5:50 pm Post subject: Re: Loose alternator bolt? |
If the pivot bolt has been loose for long, there is a good chance the holes will have wallowed out by now and the alternator pulley no longer lining up well with the pulley on the crank. |
SGKent Samba Member
Posted: Mon Jan 15, 2018 12:42 pm Post subject: Re: Loose alternator bolt? |
the bottom U-bracket cracks then the shroud wears where it wiggles and destroys the mount point. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Feb 19, 2018 2:50 pm Post subject: Re: Loose alternator bolt? |
The nut and bolt are pretty basic, unless the bolt is too long and has an unthreaded section I can see how it could not tighten sufficiently. Maybe all you would need to do is add a couple of extra washers under the head? |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Mon Feb 19, 2018 6:01 pm Post subject: Re: Loose alternator bolt? |
Would it be possible that the adjusting arm that special nut rides in has worn thinner then the portion of the nut that sits in the slot so when you clamp it down tight it just bottoms on the nut and not the arm,allowing it to move. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Mon Feb 19, 2018 7:57 pm Post subject: Re: Loose alternator bolt? |
There are two bolts holding the lower pivot point as well,
if the sliding upper adjustment is left loose/incorrect for long, that lower
mount does get beaten loose from the blower shroud.
Time to check all mounting points, six total. |
SGodinho Samba Member
Joined: August 30, 2019 Posts: 25 Location: Longview WA
Posted: Sun Nov 17, 2019 7:50 pm Post subject: Re: Loose alternator bolt? |
I'm looking for the bolt that is #19 in the diagram. Anyone know what size it is? I can't find it for the life of me. |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sun Nov 17, 2019 10:22 pm Post subject: Re: Loose alternator bolt? |
SGodinho wrote: |
021903243a
***edit
It looks like I can’t read:( you are asking about the bolt not the nut. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
