ConcreteAce's '51 build
belairman
belairman is offline
PostPosted: Fri Jan 12, 2018 9:53 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
joel55bug wrote:
Ethan when you are ready to tackle your interior troubles check this guy out: https://www.thesamba.com/vw/classifieds/detail.php?id=2122847
I know that fabric is for a Zwitter and it's only an example of what he's capable of. He is who I buy all of my period correct fabric from, his stuff seems to be spot on and he's very knowledgeable.
His material is spot on. I have ordered his material for several splits I have restored and have not been disappointed. Currently finishing a black 52 with his material. He is very easy to deal with.
ConcreteAce
ConcreteAce is offline
PostPosted: Sun Jan 14, 2018 8:25 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Well today I started to pull the beam apart to clean, grease and paint. Holy Hell what a chore. I don't think the link pins have been removed in years. Looks like I have a very leaky steering box. I will have to sort out what to do with that in the next few days. What has me worried is that the tie rods were pretty much glued to the pitman arm, I had to use a pickle fork to break them loose. In doing so I damaged these little washers.
I also noticed that the long tie rod is adjustable but the short rod seems that the ends are crimped on (second and third picture)
So my question, Is there a source for the washers out there? What do most people do with the tie rods when replacing them? These ends seem to be in good condition other than they have not been maintained in a very long time. I don't believe I can use them without the proper washers. I did a search for split tie rod ends in the classified but no results.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build
sled
sled is offline
PostPosted: Sun Jan 14, 2018 10:04 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
well...in the future there is a much better tool for removing tie rods which may have saved your original washers.
as far as replacing the cover washers goes..
https://www.thesamba.com/vw/classifieds/detail.php?id=1619955
drive your split.
ConcreteAce
PostPosted: Sun Jan 14, 2018 10:09 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Thanks for the link.! I guess my search criteria was not on point.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
ConcreteAce
PostPosted: Sat Feb 24, 2018 3:55 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Well a little progress has been made, this is getting expensive making it a driver.
I had the steering box rebuilt by a Samba member (OMT) he did a wonderful job. I ordered new washers for the tie rods. Front end is done. I installed new German kings & Links. cleaned all the rust and dirt off and gave it a fresh coat of paint.and new shocks
Also cleaned up an extra trans , I bought the Fast Fab mount so that I do not have to alter the car.
Also had Apple Hydraulics rebuild the rear lever shocks.
I got a few goodies in for the motor, like I said before this is just to get her back on the road. The spare 36er I had ended up being a pile of jung. bad cylinders , and parts of the case had been patched with JB weld. A buddy hooked me up with a better case. So now everything is just about new.
WW Kit
This is the look I am shooting for ( borrowed pic motor built by Joe Ruiz AKA Mr.Okrasa )
I started by cleaning the case the best I could. And I stripped the tins at the same time.
Got the motor buttoned up
and started fitting the tins and cutting them for the intakes
my assembly line;
Here soon I hope to have them primed and ready for paint. I sent my 019 off to Glenn for him to work his magic. I am also waiting to hear back from John on my harness. He was missing a few things he has on order from Germany. I also have all new brake parts except the MC I am not sure what to get yet, I even started a thread asking about it. But I have all new shoes,hard lines, soft lines , wheel cylinders and hubs.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
Erik G
Erik G is offline
PostPosted: Sun Feb 25, 2018 11:21 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
Ha! that's a lot of work. Great progress
joel55bug
joel55bug is offline
PostPosted: Sun Feb 25, 2018 3:54 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
What's your deadline for your driver version of this build?
543fold
543fold is offline
PostPosted: Sun Feb 25, 2018 4:06 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
After the Ghia is done.
https://www.instagram.com/w.a.r._wills.auto.restoration/
______________________
....even the rust has rust!
How "NICE" do you wanna spend?
W.A.R.
Will's Auto Restoration
ConcreteAce
PostPosted: Sun Feb 25, 2018 5:47 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
I was hoping to have it driving by the Texas Classic, but the harness may not be ready before then, and the car can not be driven with the state of the current wires. and as Will said I won't be doing a full blown resto until after the ghia is finished. I would have to get a divorce for the Split to get in front of the ghia...lol
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
Two Glove Boxes
Two Glove Boxes is offline
PostPosted: Sun Feb 25, 2018 8:10 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Thats sick! Will you be making your 25 hp to a 36 hp?
ConcreteAce
PostPosted: Sun Feb 25, 2018 8:20 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
No the 36er I have built is a total separate motor. I currently have my 25hp disassembled, cleaned and packed away awaiting the BC and the decision on what to do. If the motor is the original motor , which there is a good possibility since the numbers are 3/51 and the car is a 3/51, I will probably wait until I am ready to restore the car to rebuild it. If it comes back and it is not numbers matching I will probably just stick with the 36er.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
joel55bug
PostPosted: Mon Feb 26, 2018 6:36 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
I was hoping you were going to say by the time of the classic, hopefully it works out. It's funny you say that cause mine almost caused a divorce as well.
ConcreteAce
PostPosted: Tue Feb 27, 2018 8:19 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Well a little more progress, running gear is back on and she is close to being a roller. I got the trans, front and rear brakes installed, lever shocks and new hard and soft lines. I am waiting on the master cylinder to come so that I can finish up the brakes.
A few things stumped me and it took way longer than I thought to install the trans with the fast Fab nose cone mount. I decided not to por 15 the pans. I figured since it will not see rain unless i get caught out in it. and will be kept in a climate controlled garage that would be just one more thing
strip off once I blow it apart.
I know wrong backing plates but it is what was on the car and what I have to work with at this point in time.
Glenn rebuilt the 019 for the motor.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
ConcreteAce
PostPosted: Fri Mar 02, 2018 6:55 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Well a little more progress.
Brakes are ready. and if I had tires she would be a roller again. Started cutting up the tin to fit the WW Okrasa kit. I also got the tins in primer. I plan on painting the tins this weekend at a friends house. (he has a booth) I also got the NOS tank primed. Talked to John H and he is sending out the main harness so I can get started on it. I sent my generator out to be rebuilt. Hopefully that will be in soon.
enjoy the photos
I know wrong trans but at least I cut off the shock mount and installed one piece boots.
The 356 MC fit without me having to alter the reservoir
nice having the running gear back on feels like I am getting somewhere
Started fitting the tin
and my backyard spray booth. I know hillbilly style but I will be spraying them in a booth this sunday
Well on another note does anyone have a lead on a trunkliner. I emailed Wolfgang Gips and he said that they are no longer available. but he did send me a picture of the one I need, but I can not find any other source.
Any help would be great if you know of a source.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
johnshenry Premium Member
johnshenry is offline
PostPosted: Fri Mar 02, 2018 7:54 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Dude, you are setting a pace for a restoration that is embarrassing us all. Surprised (happy to be part of it! Will ship your harness tomorrow!!!)
John Henry
'57 Deluxe
'56 Single Cab
sled
sled is offline
PostPosted: Fri Mar 02, 2018 8:28 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
[quote="ConcreteAce"]
awesome progress!!
I am wondering why the conical washers are not seated against the body of the tie rod end? they should be tight, holding the grease inside.
I would uninstall this tie rod end and fix it.
drive your split.
sled
sled is offline
PostPosted: Fri Mar 02, 2018 8:46 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
also, here is an option but they are not the best quality
http://www.kaefer-nostalgie.com/content/trunk-liner-1952
drive your split.
ConcreteAce
PostPosted: Fri Mar 02, 2018 8:52 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
[quote="sled"]
ConcreteAce wrote:
awesome progress!!
I did not mean to post that picture I actually used it in another thread https://www.thesamba.com/vw/forum/viewtopic.php?t=695127&highlight= , I had installed them just like I took them off. The spring was behind the washers, I have put them on correctly now.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
ConcreteAce
PostPosted: Fri Mar 02, 2018 8:58 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
I did not realize he carried them. Hmm seems a lot of money if the quality is not so good.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
René R.
René R. is offline
PostPosted: Sat Mar 03, 2018 9:16 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
Just FYI, they don't come riveted or stapled from KN.
Page 4 of 9
