Hardwood Samba Member
Joined: February 02, 2017 Posts: 29 Location: NE Colorado
Posted: Mon Jan 15, 2018 7:16 pm Post subject: Non stock engine |
I saw this picture in an ad for a 1977 convertible. It’s obviously not stock thdoes anybody know what’s going on here? Is it a red flag?
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Mon Jan 15, 2018 7:48 pm Post subject: Re: Non stock engine |
where to start? original injected car converted to carb...30/31 with an adapter to fit dual port manifold...cheap k&n style air filter...009 centrifugal distributor...cant see if it has the correct cylinder covers to match the F.I. engine compartment...no idea whats going on with the patch pop rivited onto the fan housing by the coil...has a fuel pump mount so its not the original block...so did they convert the F.I. engine or just stuff in a used carb engine ( reason for the cylinder cover comment)...the fact that the fire hazard fuel filter has been installed backwards doesnt say much for the level of expertise involved |
Danwvw Samba Member
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1606 Location: Central Pennsylvania
Posted: Mon Jan 15, 2018 8:59 pm Post subject: Re: Non stock engine |
I wouldn't call it a red flag. That engine may be from the early '70's and might run fine. Check the serial number on the block below the alternator stand to confirm the year (first two letters will tell you everything). If the car is solid and complete, then the engine can be updated in any way you want. Most used bugs out there have engines that don't match - it's the norm not the exception.
The worst things that you should change immediately for low cost include the air filter (with pre-warmed hose), the coil, and the fuel filter (although the coil might be fine). The carb and distributor work together and are fine unless you want total stock look. The tin appears good.
Not a red flag unless you want a total '79 set up. _________________ '91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight= |
Posted: Tue Jan 16, 2018 6:58 am Post subject: Re: Non stock engine |
Thanks for your time and expertise. I knew for sure it was not stock, but other than that I had no idea.
thanks
George |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Jan 16, 2018 8:36 am Post subject: Re: Non stock engine |
volksworld wrote: |
That is NOT an FI engine that has been converted. FI cases do not have a hole for a stock fuel pump, which this one obviously has. Aftermarket distributor (009), aftermarket air cleaner. Not sure what is going on under the coil, it appears there is a plate bolted to the shroud in that location. |
