dentfreeimage Samba Member
Joined: September 21, 2013 Posts: 292 Location: San Antonio, TX
Posted: Mon Jan 15, 2018 10:56 pm Post subject: Local Part Store Brake Drums 71 Camper Problems! |
Hello everyone, I made a mistake and purchased a set of drums for my 71 camper and after replacing bearings, wheel cylinders, brakes etc the drums are rubbing on the backside of the plates. The plates have not been replaced and are the original parts. I used the old spacers with the new bearings.
Here are the specs of the drums I bought at O'reilly auto parts:
Part # 9153DGS (Made in China) = Main Problem!
Outside Diameter (In): 11.1 Inch
Overall Height (In): 2.800 Inch
Bolt Pattern: 5 On 112mm
Discard Diameter (In): 9.980 Inch
Nominal Diameter (In): 9.930 Inch
Number Of Bolt Holes: 5
Bolt Circle Diameter (mm): 112mm
Surface Depth (In): 2.53 Inch
I have a few original used drums in storage and will see if any of them are worth cutting. Will appreciate if anyone can steer me in the right direction as far as which aftermarket drums to get. I will be taking these back to the parts store to get my $$.
I am also looking for a retaining clip to hold the parking brake cable in place inside the backing plate. I had one of them brake when I took things apart and I can not find a replacement in any store online or off line.
I greatly appreciate everyone's advice!
Manfred58sc Samba Member
Posted: Tue Jan 16, 2018 12:49 am Post subject: Re: Local Part Store Brake Drums 71 Camper Problems! |
When you return them , the store will put them right back on the shelf. Good OE drums are still to be had and the best way to go. _________________ Fat chick owner/operator |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Tue Jan 16, 2018 11:13 am Post subject: Re: Local Part Store Brake Drums 71 Camper Problems! |
Find a really hard shim to place between the drum and your spacer. This will give your backing plates the clearance they need.
On the parking cable retainer. A pair of tin snips and some sheet metal should do the trick.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Tue Jan 16, 2018 2:37 pm Post subject: Re: Local Part Store Brake Drums 71 Camper Problems! |
Stock '71 bus parking brake cable did not use, and did not need any retaining clip.
Where is the drum rubbing? Shimming the bearing stack may not fix the issue if it's rubbing because the Chinese decided that
Vanagon drums are good enough for the earlier Bay busses, just like they decided that Vanagon brake shoes are good enough
for the Bays. See thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=643031 _________________ '67 bug: seized by the authorities
Posted: Tue Jan 16, 2018 7:48 pm Post subject: Re: Local Part Store Brake Drums 71 Camper Problems! |
Thank you guys for the advice. kreemoweet made me think and go to the garage and snap some pictures. I am going to say that they are rubbing because they are not the correct drum for it as the link on his post suggests.
The pics show clearly the larger lip on the drum rubbing against the backing plate. Before I order the correct drums, I will stop by the storage and get the stock ones I removed and make sure they are not rubbing.
After doing some searching here I found that the OMC brand drums will be a good fit and will order them online and returning these back to the local parts store.
By the way the parking brake retaining clips seem to be very old, this is my first bus and my thoughts were that it was part of the bus. They seemed like they were there from the factory (long time) I installed one clip and was searching for the other one. But I will remove it if they are not needed.
Thanks again for the great advice!
