Jakeman75 Samba Member
Joined: November 11, 2014 Posts: 18 Location: Somerset, Kentucky
Posted: Tue Jan 16, 2018 11:31 am Post subject: Experimenting with boost |
Hey guys I have decided to try a little boost on my California speedster. I was curious as to how much is safe on a 1600 |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Tue Jan 16, 2018 11:36 am Post subject: Re: Experimenting with boost |
You have to give some type of supporting information to get a real answer. Some people (Clonebug) are pushing mid 20lbs right now. If you don't have an intercooler and means of keeping IATs down, 8lbs is about all you can do. We need more info. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Posted: Tue Jan 16, 2018 12:20 pm Post subject: Re: Experimenting with boost |
I’m running a stock rebuilt 1600 dp and plan on putting an amr 500 on the motor that came off a friend of mines subaru |
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Tue Jan 16, 2018 1:44 pm Post subject: Re: Experimenting with boost |
I’ve not got a whole lot of miles on my stock 1600 single port but it sees 5-8 psi with the gt15 turbo.
I am not locked on the timing. I have a boost retard box. |
Posted: Tue Jan 16, 2018 2:19 pm Post subject: Re: Experimenting with boost |
Jakeman75 wrote: |
I don't know what kind of boost the AMR can put out, but with forged 85.5mm pistons and cylinders, you should be able to do above 20 lbs. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-18 GTI SE
Posted: Tue Jan 16, 2018 3:31 pm Post subject: Re: Experimenting with boost |
All I plan on is 5-8 pounds nothing over 10 for sure because this is my first supercharger I’ve ever dealt with and I don’t want to go too crazy with it. I figure if this goes ok I can move up and try bigger things |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Tue Jan 16, 2018 4:14 pm Post subject: Re: Experimenting with boost |
Jakeman75 wrote: |
I just happen to know someone who is working on the same thing. I saw it in the design stage but he now has it running for the first time.
He is using Fuel Injection but the mounting system and how it all ties together is quite impressive.
He has a video of the first startup.
Take a look at his FaceBook page......Mario at "thedubshop"
https://www.facebook.com/thedubshop/ _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Jan 16, 2018 5:37 pm Post subject: Re: Experimenting with boost |
one main weak point is going to be the 4 dowel crank/flywheel. Stock cast pistons too. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
mark tucker Samba Member
Posted: Tue Jan 16, 2018 8:20 pm Post subject: Re: Experimenting with boost |
[email protected] wrote: |
one main weak point is going to be the 4 dowel crank/flywheel. Stock cast pistons too. |
now thats using your thinking cap.....just remember superchargers like a lot of main jet. |
modok Samba Member
Posted: Wed Jan 17, 2018 12:04 am Post subject: Re: Experimenting with boost |
Scat gland nut, 350 ft-lbs
It'll work.
I'd gear it for for 6-8 lbs
Try it, if you don't like it then try something else. All you can do. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Wed Jan 17, 2018 2:11 am Post subject: Re: Experimenting with boost |
I ran a Toyota supercharger on a stock 1600, 8psi seemed to be it's happy limit, i did have it up to 10psi for a while but I wouldn't run over that if you want it to last _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Wed Jan 17, 2018 7:12 am Post subject: Re: Experimenting with boost |
Joel wrote: |
I ran a Toyota supercharger on a stock 1600, 8psi seemed to be it's happy limit, i did have it up to 10psi for a while but I wouldn't run over that if you want it to last |
What were your IAT's on boost with the supercharger???? _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Wed Jan 17, 2018 7:16 am Post subject: Re: Experimenting with boost |
Should I put a blow off or intercooler on it and a friend of mine has a turbo with a carb on it but it’s on an old mg |
Posted: Thu Jan 18, 2018 9:31 am Post subject: Re: Experimenting with boost |
How do I find the compression after boost for an engine |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Thu Jan 18, 2018 9:40 pm Post subject: Re: Experimenting with boost |
I don't think there is a way to measure that. I suspect it is a theoretical value done with a calculator. |
Posted: Thu Jan 18, 2018 10:00 pm Post subject: Re: Experimenting with boost |
oprn wrote: |
Here's a calculator for ya......it's just a little math....
http://www.rbracing-rsr.com/compression.htm _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
pondervwmike Samba Member
Joined: June 16, 2017 Posts: 373 Location: Ponder(Dallas) Texas USA
nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Sun Jan 21, 2018 5:29 am Post subject: Re: Experimenting with boost |
Im running 7psi on a stock 1600 DP (Mahle pistons and chevy valve springs are only mods) with a t3 50 trim. No issues so far. Keep in mind, I converted to EFI which keeps AFRs perfecltly at 12.8:1 under boost.
-Nick- _________________ -Why buy it when you can BUILD it?- |
oprn Samba Member
Posted: Sun Jan 21, 2018 7:33 am Post subject: Re: Experimenting with boost |
It all fits under the lid! Nice, I like that. |
Mavelotta Samba Member
Joined: March 27, 2006 Posts: 50 Location: Monroe, Wa.
Posted: Tue Feb 13, 2018 7:13 am Post subject: Re: Experimenting with boost |
I'm still developing this, but I am really happy with everything so far. Even though I love turbos the added torque from a supercharger is pretty great. Once I have the platform all ironed out, I would like to add a turbo in addition to the supercharger A couple weeks after this video I put on my small pulley to see what kind of boost I could achieve. My goal has been 1bar. Although I am not sure I can get there right now I was able to make 9psi at 2000rpms. It makes for a 1600 that drives like a 2L The new problem is heat management at this boost level. I will be going back up in pulley size to lower the heat output of the supercharger to find that happy medium of power and efficiency without additional cooling.
_________________ The Dub Shop
[email protected]
Facebook-Tech-Store |
