BRM Gasburners
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
gitchesum
gitchesum is offline
PostPosted: Mon Jan 15, 2018 8:58 am    Post subject: BRM Gasburners Reply with quote
I've had a new set of these for about 10 years...waiting for something to put them on...now I'm
thinking about doing this,machining required.....any thoughts?
Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go...
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jan 15, 2018 9:05 am    Post subject: Re: BRM Gasburners Reply with quote
Huh?
Glenn
Member #1009
#BlueSquare
EmpiGT
EmpiGT is offline
PostPosted: Mon Jan 15, 2018 4:51 pm    Post subject: Re: BRM Gasburners Reply with quote
I looked at the pic for a bit before seeing the difference. They look good and may not notice unless told.
Is this a set done or photo shopped?
gitchesum
PostPosted: Mon Jan 15, 2018 5:27 pm    Post subject: Re: BRM Gasburners Reply with quote
It's a done set. Talked to one machinist a while back, and checking with another when time permits.
57 SC
61 356B
GMC SLT 4x4 Dmax
motofly196
motofly196 is offline
PostPosted: Mon Jan 15, 2018 7:48 pm    Post subject: Re: BRM Gasburners Reply with quote
I don't think I'd be machining a wheel that heavily. That's taking a ton of meat out of a structural area. I wouldn't use it...
ssx
ssx is offline
PostPosted: Wed Jan 17, 2018 1:25 pm    Post subject: Re: BRM Gasburners Reply with quote
Looks awesome! As mentioned above, not sure how much of the structure is compromised tough?
1956 Oval/Ragtop
ach60 Premium Member
ach60 is offline
PostPosted: Mon Jan 22, 2018 10:59 pm    Post subject: Re: BRM Gasburners Reply with quote
Cut windows in the 5 spokes with nice radius at corners, likely caused little structural weakness.
A Plumber cuts a 2" hole in a 10" beam causes no issue, a hack cuts a 2" notch out of a 10" beam, and you got a problem.
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
motofly196
PostPosted: Tue Jan 23, 2018 6:58 am    Post subject: Re: BRM Gasburners Reply with quote
A 10" Wooden beam doesn't have to endure extreme dynamic forces exerted at 30+ MPH supporting 2500 lbs of weight. The beam only supports dynamic and static weights. Apples and oranges. They are your wheels....do what you want, I know there's no way I'd even consider doing this to my wheels.
jason
jason is offline
PostPosted: Wed Jan 24, 2018 2:37 pm    Post subject: Re: BRM Gasburners Reply with quote
It had 5 spokes, now it has 10. It’s probably stronger. Very Happy
chickengeorge
chickengeorge is offline
PostPosted: Thu Jan 25, 2018 4:33 pm    Post subject: Re: BRM Gasburners Reply with quote
It never ceases to amaze me what holds together as far as a wheel goes. I hang around a lot on import tuner sites. Not the B18 swap Civic-type sites, but Speedhunters and G35driver.com and whatnot. Some of the high-end wheels out there, don't look like they'd be able to hold the car up while standing still, much less moving.
Like the three-piece wheels below. How?
ach60 is offline
PostPosted: Wed May 05, 2021 1:15 pm    Post subject: Re: BRM Gasburners Reply with quote
Funny I came across this thread again, and found my post.
motofly196" has a good point, and also years ago when they made BRM reproduction wheels for New Beetles.
I showed them to a Automotive Engineer and his gut reaction was they looked weak.
So I didn't buy them, and bought stock 17" Aluminum VW wheels instead.
They were heavy, and slowed the car down.
Good Luck
Al
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
