Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Nov 27, 2017 8:12 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
skills@eurocarsplus wrote: |
either you have a kung fu grip, or that is made of play-dough. the real deal ones don't flex like that |
x2
Aloha
tp |
hometurbine Samba Member
Joined: November 30, 2014 Posts: 157 Location: Cincinnati
Posted: Sun Jan 14, 2018 6:29 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
So...is Vewib a good one?
rayroc, you bought one recently, what's your feedbacK?
Looks like there are some still available through a seller on eBay. _________________ Bill
'75 Westy Bus with Subaru EJ25 engine
GE CT58-100 helicopter gas turbine
Tiernay TT10 APU gas turbine |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Fri Jan 19, 2018 12:38 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
hometurbine wrote: |
Looks like there are some still available through a seller on eBay. |
Yea, looking into buying one as well. How much flex does it have compared the the other ones mentioned on this thread? _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
static Samba Member
Joined: March 22, 2002 Posts: 1830 Location: The High Desert
Posted: Wed Mar 07, 2018 4:54 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Cip1, of all places, has a German coupler on sale right now. Of course, this will only help if you’re reading this prior to March 31, 2018.
Steering Coupler |
Zed999 Samba Member
Posted: Thu Mar 08, 2018 4:44 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I haven't read every post so apologies if it's been said already.
The cheapy bendy ones will eventually tear right off. I had a customer drive from France to UK with his torn off and somehow wrapped around the brake pedal. 180 degrees of free play at the steering wheel but the bolts dangling from the column caught on the steering box part due to the nuts on the end and the spacers that had been part of the coupling. If he'd pulled up on the wheel they wouldn't have. Customer hadn't even looked underneath, he just wanted to get home. A French mechanic had advised him to "take it steady and he'd be ok". The French aren't too fond of Brits! |
sixty9fasty Samba Member
Joined: April 12, 2004 Posts: 1066 Location: crockett, ca
Posted: Mon May 07, 2018 3:05 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Well, count Cip1 "German OEM" out. They are now shipping garbage from bbtvw.com. it's marked Germany, but floppy like a soft taco... for $33 plus shipping, I'm pissed. Off to try again somewhere...
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon May 07, 2018 3:15 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Great! Another piece of shit with that fabulous word Germany on it like that is supposed to imply quality.
FWIW, the steering coupler I mentioned in the link I posted in the previous page of this thread is holding up great. I put the nylon sleeves in it so my horn circuit would work properly. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon May 07, 2018 3:25 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
sixty9fasty wrote: |
Damn. I ordered a pair from them thinking it was the real deal.
Did you contact them and process a return? _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
SGKent Samba Member
Posted: Mon May 07, 2018 3:40 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
what is most important is:
the compression of the puck
longevity
electrical conductivity
Someone with a couple of these could rig a system of testing to see how different ones compress when being turned - how many inch pounds are needed to compress it a set distance.
A nut welded to other side of these will provide someplace to attach a torque wrench. This one was set up for adjusting steering boxes so the nut is on the wrong side.
Once that is done, different brands can be tested. How much they bend is not a realistic test. You want them to twist if you get thrown into the steering wheel, but you don't want them to compress when they are being turned. (I have no idea whether the one here marked OEM is any good or not. Fortunately I bought a bunch of real VW ones when they were still around but they are all sold now so I can guess what it would feel like to have one make sloppy steering.)
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Hoody Samba Member
Posted: Mon May 07, 2018 6:57 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
You guys may as well give up with these. Unless they are NOS forget it. And those are long gone.Germany is not a proprietary name. These “OEM Germany” ones are being sold everywhere in the world. Some company is turning them out as fast as they can. The only good one that I have found is being sold by Bughaus. You can see what it looks like on page 6 of this thread. It’s very well made and has several layers of the webbing or mesh molded into the rubber so that it won’t tear. It does bend slightly but but not much. Just checked their site and it says out of stock. Perhaps try calling and see if he’s getting more in. |
Posted: Mon May 07, 2018 7:19 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
BUSBOSS wrote: |
Did you contact them and process a return? |
Not yet... not sure if be worth the $15 back to them shipping, since it was $30... |
Posted: Mon May 07, 2018 7:25 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Also... just ordered this from notch1500 on eBay.... maybe good🤞🏻
Posted: Mon May 07, 2018 7:41 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Thanks. Let me know how it is.
I ordered a pair from CIP1 so I will initiate a return for sure. Send them an email so they know it's a bad part fron bbtvw and not as good as their previous inventory from vewib. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
Joined: January 01, 2007 Posts: 16801 Location: sticksville, ct.
Posted: Mon May 07, 2018 8:02 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
BUSBOSS wrote: |
I ordered a pair from CIP1 so I will initiate a return for sure. Send them an email so they know it's a bad part fron bbtvw and not as good as their previous inventory from vewib. |
yes, the VEWIB's were great. as hoody stated you could barely bend them. iirc they had the vw emblem ground off of them
I can't believe these fucking vendors can't get such a crucial part right. oh wait...yes I can _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Mon May 07, 2018 8:15 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
BUSBOSS wrote: |
Sent them feedback on their floppy taco of a steering coupler... deaf ears I'm sure |
wcfvw69 Samba Purist
Posted: Tue May 08, 2018 3:49 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Hoody wrote: |
You guys may as well give up with these. Unless they are NOS forget it. And those are long gone. |
The real NOS couplers are out there. I found four at a VW swap meet by chance. And too everyone's point, they are very rigid and don't flex much.
P.S., I kept one for me and the other three were sold to VW bus friends already. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu May 17, 2018 7:46 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Any update on the quality of this part? _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
Esher127 Samba Member
Joined: August 26, 2010 Posts: 607 Location: Staunton, VA
Posted: Thu May 17, 2018 8:53 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I also ordered one of these thinking it was German OEM and got the same bbtvw part you did.
I went ahead and installed it. My old factory coupling was so shot that it's still a huge improvement in steering feel and the horn works fine. I'm satisfied with it.... I guess. _________________ 1970 Westfalia Pop-Top |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3889 Location: Seattle, WA
Posted: Thu May 17, 2018 9:44 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
The word "OEM" actually on the product or it's packaging is a dead giveaway that you're getting third-world crap.
Sometimes the word is used in a product description just to indicate that the part comes from some company/brand that
used to supply the part to VW back in the day. Even there, it's just marketing BS, because company and brand names
live on long after the original concern that used them is gone, and even if there's some continuity in the company,
there is no reason to assume that the product is even close to meeting the specs or quality control that the item met when it was being
supplied to VW. _________________ '67 bug: seized by the authorities
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Thu May 17, 2018 11:33 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I'm still just marveling.....that far too many times.....people are judging the quality of one of theze parts....by comparing its "bend-ability".
While this part should not be floppy......what are you comparing it to? An ancient NOS part?
You DO realize....that these are made from Buna-N for the most part right?....and that Buna-N has a listed shelf life in "hardness" critical parts of 3-5 years right?
While this part is not what I would call hardness CRITICAL.....they list 3-5 years because at room temp....this rubber starts to show considerable hardness increase within that period.
With that same rubber type 15 years is the max shelf life for o-rings and sheet gasket because tbrough natural oxidization they become to hard to properly flex and seal.
Typical hardness increase after 15 years is between 15-20 durometer. With starting durometer of 45-55.....an original coupling made 25 years ago can be close to 75-80 durometer.....which is just about the same as the average NEW urethane control arm bushing.
Think about that hardness comparison for a moment.
Also....molded rubber parts...eapecially reinforced layered rubber parts.....do not have the same strength in all directions. Folding/bending one in half....is not a test of its torsional strength.
If a part is poor and fails quickly....thats one key thing. If one bends one in an axis its never designed to be strong in....and compares its hardness with a 25 year old sample....and then deems it a poor or failed part with no other testing.....thats kind of shortsighted. Ray |
