ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Mon Sep 11, 2017 12:13 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
KTPhil wrote: |
Well, to adjust the Bowden tube bend you have to release the wingnut on the cable anyway, so you'll be adjusting the pedal after the tube. Keep tension on that cable as you remove the wingnut and Bowden tube or you may have to remove the pedal cluster to re-hook it on the clutch pedal.
Has anyone figured out of there is enough room to reach an arm into the tunnel after removing the cover, should it come unhooked? I've never done it that way. |
If the eye of the clutch cable at the pedal end comes off of the hook on the pedal assembly - it will 'go back' about an inch or two before it stops on the end of the tube. |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Tue Sep 12, 2017 5:16 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Gave the car a quick wash last night and started cleaning out the interior. Here's a few photos.
The car has for sure been repainted, but it is an older repaint and seems to be single stage. The paint is chipping in some spots and you can clearly see the OG paint below. I believe the black on the hatch is actually primer above the OG paint... Might try stripping some of the black off to see if there's clean pearl white underneath.
Removed the super ratty carpet and the degraded cardboard in the rear cargo area. I've got some surface rust back there, so a couple quick questions in treating it:
What grit of sandpaper should I hit it with? Or should I use a wire wheel?
Is there a rattle can close to pearl white I can find at my local hardware store?
This area will eventually be fully cleaned up and covered in acoustic/thermal deadener, so the paint doesn't need to be a dead on match. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com |
czykvw Samba Member
Joined: June 11, 2009 Posts: 304 Location: Fullerton, CA
Posted: Fri Sep 15, 2017 12:04 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Congrats, nice find.
Whats the story behind the wisconsin plates?
Surprised a T3 would ever survive in that state.
G/L w/ the build _________________ '67 Squareback
OCT3 - Orange County Type 3's |
Posted: Fri Sep 15, 2017 10:18 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
czykvw wrote: |
G/L w/ the build |
Thanks! Story goes that it was originally purchased by a man in Alameda, CA. His service notes (with dates) are all in the original owners manual that I've got. He eventually gave the car to his daughter, who was driving it cross country (around 2000) when it broke down in Wisconsin. She took it to a german auto repair shop and ended up selling the car to the mechanic. The car was then purchased locally, and the guy I bought it from ended up purchasing it from the local owner. So it wasn't in WI for too long, maybe a year. It does have some rust, so it's not super clean, but it is a solid foundation for sure. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Tue Sep 19, 2017 9:13 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Took my tail lights out to clean all the contacts last night and discovered a ton of dirt, sediment, and dead bugs at the bottom rear of my fenders. Is there an easy way to get all this out without taking off the entire fender? _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Tue Sep 19, 2017 9:59 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
OhHerrooo wrote: |
Took my tail lights out to clean all the contacts last night and discovered a ton of dirt, sediment, and dead bugs at the bottom rear of my fenders. Is there an easy way to get all this out without taking off the entire fender? |
Would it be possible to remove the lower fender bolts, place something to act as a spacer, then drum up something attached to a rod/broomstick to break up and loosen the sediment and flush that out as much as you can then rinse the rest out with a blast from the water hose? There's not much room to work with unless that fender comes off. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Tue Sep 19, 2017 10:08 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
OhHerrooo wrote: |
If there's a bunch of stuff down there - it likely means that you may need to replace the seal that goes around the wheel well - which means that you'll have to pull the fender. |
Posted: Tue Sep 19, 2017 10:29 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
ataraxia wrote: |
Yeah there's a bunch of junk in there. Good call, I'll look into replacing the fender seal.
MonT3 wrote: |
Would it be possible to remove the lower fender bolts, place something to act as a spacer, then drum up something attached to a rod/broomstick to break up and loosen the sediment and flush that out as much as you can then rinse the rest out with a blast from the water hose? There's not much room to work with unless that fender comes off. |
I think I'll try this tonight and see what happens. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Sep 19, 2017 6:59 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
How rare is this, to see a pre-restoration Type 3 on which the front bumper does not droop down at the ends due to a slight tap?
Posted: Tue Sep 19, 2017 7:38 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Rome wrote: |
Yeah the front bumper is super straight! The rear, unfortunately, has been tapped and is drooping _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Tue Sep 19, 2017 7:51 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Well today I got the bug to see how good of shape the OG paint was beneath this respray. In a bunch of spots all over the car, the top coat has been flaking off (super easily) of the OG paint below, with the OG paint showing no signs of sanding or any primer in between coats.
I bought a pack of razor blades, a can of Goof Off Graffiti Remover, and some 0000 steel wool and got to work. I started on a small corner of the hatch, since it would be getting paint work regardless of the condition of the OG paint. Turns out there was some slight rust in the black area which was sanded, converted, primered and painted. But as I moved away from this uglier zone, I was rewarded with super pristine, clean, unscratched OG pearl white paint. I haven't yet really dialed in my timing/technique with the paint removal, but the results I've been getting have been worth the time (and hand cramps). The respray is super close to the OG color, so it is kinda hard to tell in the pics, but you'll get the idea.
In the first photo I've stripped the left third of the hatch below the window in addition to the flat area around the license plate (mostly). I've also started on the bottom of the hatch on the right hand side above the lower break line.
In the second photo I just wanted to give you an idea of the color difference and how clean the OG paint is. I had a couple knicks here and there, but nothing that I'm super upset about.
Once I'm done stripping the OG paint on the rest of the hatch, I'll have a shop match the bottom left corner to the OG pearl white.
I really like OG paint cars, and this one will be a bit of a project but will for sure be worth it once complete. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Sun Sep 24, 2017 6:11 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Got the entire hatch stripped and it looks great. Installed my '66 rear view mirror today, scrubbed the engine, cleaned the rear trunk to prep for touch up paint / sound deadener, and adjusted my clutch cable. There is about .75" of free play before there's tension (bowden tube looks good) but the clutch still doesn't engage until much further in the pedal travel. I still have shudder as the clutch is grabbing and going into first gear when the car is cold.
Potential oil leak between engine and trans so clutch is getting oily? Or clutch/flywheel issues? _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Sat Oct 28, 2017 8:04 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Time for a quick update. Turns out there were a few other issues hiding below the surface. Took the car to a friend's shop to have the battery tray welded up, motor gone though, etc. Ended up with a solid battery tray, but needing a full rebuild on the motor. Both heads were toast, around 80% leakdown per cylinder. The case was salvageable, it was .040 over but didn't need to be align bored... so we're going with a mild 1776 on the existing case. Obviously new pistons, cylinders, cam, heads, etc.
For the shuddering... turns out my mounts were all completely toast and the clutch lever return spring was busted. Neither of which where helping things. I've been hoarding a bunch of parts like new wheels/tires, a bunch of new rubber, carpet, etc. to get back to work on the car as soon as I get it back from the shop. All the tins are heading to powdercoating on Monday and my case should be back from the machine shop by (hopefully) the end of the week.
The car is still very solid, and I'm really excited to get it back home and on the road.
New floor!
'69 Squareback
'68 Westfalia
'68 Squareback
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Fri Jan 19, 2018 4:51 pm Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Been slowly chipping away at the car over the last few weeks. Driving it every day. Installed a new (to me) rear bumper, a ton of seals (hood, trunk, engine lid, front + rear signal + reflector seals), some amber tail lights, new reflectors + used turn signal lenses, hatch hinge covers, and stainless trim. I've got a bunch of other parts (ISP tach, fresh air box seals, pop out refresh kit, speaker panels + stereo) waiting and ready to go in.
I lowered my front end 2 inner splines and will be lowering the rear 1 inner in the coming weeks (with new inner + outer torsion bushings).
I also recently prepped my interior for carpet by wire wheeling all the surface rust + dirt off my pans and applied 3 coats of Master Coat followed by 2 layers of Noico sound deadener. Carpet will be going in this weekend. Here's a few photos.
Pre-trim, post lowering.
Not sure if I'll be keeping the sprint stars. They do rub a bit - so I'll either get repop cosmics (with better offset) or some oldspeed narrowed arms + short axles in back. Will likely have the tranny rebuilt when the short axles go in. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Sat Jan 20, 2018 5:06 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Started fitting the TMI carpet kit earlier tonight - really stoked to finally see some carpet in this car.
What's the order to installing the glued in carpet pieces? Rockers, then front corners, front firewall, rear bulkhead, then the main floor pieces? _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Sat Jan 20, 2018 8:43 am Post subject: Re: OhHerrooo's Pearl White 1967 Squareback |
Did you get the correct carpet or the one where the heater outlets are completely wrong? My friend can't get a response on his shit TMI carpet. We know they know about it... _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
