Nut removal trick
4118thing
4118thing is offline
PostPosted: Sun Jan 21, 2018 7:32 pm    Post subject: Nut removal trick Reply with quote
I had a nut that connected the muffler to the exhaust port. Rusted and I tried everything I had. PB Blaster, had impact wrench, etc. Didn’t have a torch. The biggest problem was a socket would fit because of the muffler flange, and an open end would round the nut. No turning radius for a vise grip plier.
My solution, for those having a similar problem, was to drill a small dimple, about 1/8”, into the nut outer perimeter, not the face, without going very deep. Then with a nail punch and small hammer strike the nut, in an angle to cause it to turn ccw. Drill another dimple as needed, etc. Keep working around the perimeter as needed.
This won’t work for every problem, but it worked for me. Hope it will help others. (Also doesn’t ruin the nut, other than a few dimples.)
Rev. Scott
Rev. Scott is offline
PostPosted: Mon Jan 22, 2018 7:59 pm    Post subject: Re: Nut removal trick Reply with quote
John Muir has a similar method involving a cold chisel. It works.
"I haven't seen one of those since I was shootin' at 'em!"
Al Capulco
Al Capulco is offline
PostPosted: Mon Jan 22, 2018 11:22 pm    Post subject: Re: Nut removal trick Reply with quote
Next time, you might try a 13mm obstruction wrench and a little Kroil.
4118thing
PostPosted: Tue Jan 23, 2018 8:41 pm    Post subject: Re: Nut removal trick Reply with quote
The obstruction wrench would not work. The problem was there was not enough room to fit a socket or closed end wrench, because the nut was too close to the flange weld. Have no clue how it was tightened, but the open end would fit, but would round the nut when I tried to loosen it.
Al Capulco
PostPosted: Tue Jan 23, 2018 10:16 pm    Post subject: Re: Nut removal trick Reply with quote
Sometimes you have to grind down the wrench a little so it fits, but they do work. Was it a stock exhaust or a header?
scottyrocks
scottyrocks is offline
PostPosted: Wed Jan 24, 2018 6:41 am    Post subject: Re: Nut removal trick Reply with quote
When it was tightened it probably wasn't rusted solid and an open end wrench worked.
– D. Tartt, 'The Goldfinch'
4118thing
PostPosted: Thu Jan 25, 2018 8:32 am    Post subject: Re: Nut removal trick Reply with quote
My thought exactly.
iltis74
iltis74 is offline
PostPosted: Sun Feb 11, 2018 3:41 pm    Post subject: Re: Nut removal trick Reply with quote
There are wrenches that won't. The snappy "flank drive plus" is what I'm familiar with but there may be cheaper versions out. Yes they'll mark your fasteners up, which is something to keep in mind, but they're notched to grip the fastener away from the edges. The open end will break the bolt before it rounds the nut.
65 Beetle
74 Thing
87 Syncro
