cocopuffsman Samba Member
Posted: Sun Jan 21, 2018 3:09 am Post subject: electric fuel pump |
I have a porsche 32ndix centermount carburetor on a 1835cc vw dual port and electronic ignition instead of points
the problem ive been having is when at idle my rpms seem to rise 1k and when I give it gas the idle goes back down for a second and slowly raises back +1k rpm, Ive noticed that when I turn my electric fuel pump on and off that fixes the issue of raising 1k till the carburetor runs out of gas.
from what I could gather, there must be too much pressure from the fuel pump causing the carb to get too much fuel and idle up till I give the car some gas and releasing the pressure for a second.
the first thing I did from there was buy a new 42s ELECTRIC FUEL PUMP (MICRO) - 2 PSI / 3.5 PSI - 28 GPH - GASOLINE - FOR CARBURETOR, made by mr. gasket.
the issue was not solved by that, could it still be getting too much pressure? _________________ https://www.youtube.com/watch?v=z5HSYpTKrUg
https://youtu.be/z5yDe0MKzYw
https://youtu.be/MpJoZYZNLLI
https://youtu.be/m8-rsKIvbos
https://youtu.be/bfYDA3-N0fg |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Mon Jan 22, 2018 5:26 am Post subject: Re: electric fuel pump |
cocopuffsman wrote: |
Looks like the fuel level in the bowl is too high. I don't know how the float bowl /needle valve of NDIX carb works, but there must be a way to adjust it. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Mon Jan 22, 2018 5:36 am Post subject: Re: electric fuel pump |
How are you measuring the fuel pressure? The cheap round pressure gauges are usually close, but not always. You can never just trust what a dial like that says, assuming that is what you are using.
And I agree that is does sound like fuel level is too high in the carb.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Mon Jan 22, 2018 5:40 am Post subject: Re: electric fuel pump |
add washer shims under the float valve. The shims have a 1:4 effect on the float height; a .25mm washer will lower the fuel level 1mm. Also check that the float hasn't partially failed..
https://porsche356registry.org/article/46 _________________ modok wrote:
