How to split a stubborn case?
dennis 356
dennis 356 is offline
PostPosted: Sat Jan 06, 2018 5:38 am    Post subject: How to split a stubborn case? Reply with quote
Can anyone give advice on how to split a very, very stubborn case (after the third piece has been removed of course)? Have checked numerous times for all the bolts being out, incl. the long one that goes through the block and of course don´t want to pry into it with anything sharp, so the only resort was a careful banging a little here and there with a wooden block inbetween, but that was naive, sits as a rock.
Is there some special tool (pressing?) available?
Dennis
PD41
PD41 is offline
PostPosted: Sat Jan 06, 2018 7:47 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Maybe try some heat to warm up the block (to soften the sealant)
A thin screwdriver at the top above the flywheel and a hammer.
Or try this guys method.
https://www.youtube.com/watch?v=jMP05Gtca38
Jacks
Jacks is offline
PostPosted: Sat Jan 06, 2018 9:08 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Did you take off the flywheel?
Jack Staggs
Actual name
dennis 356
PostPosted: Sun Jan 07, 2018 4:25 am    Post subject: Re: How to split a stubborn case? Reply with quote
I tried heating up the case, for the same reason you mention, but had only a hair drier and don´t think it generated enough heat.
I´ve seen that Youtube video and it was far too easy.
dennis 356
PostPosted: Sun Jan 07, 2018 4:28 am    Post subject: Re: How to split a stubborn case? Reply with quote
Of course, its just a bare case with crank and rods inside.
Dennis
ensys
ensys is offline
PostPosted: Wed Jan 17, 2018 10:21 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Mr. Dennis 356:
You should understand that among the reasons it may be difficult to separate the halves. it might be that the case has become deformed, which would produce the same result.
Proceed with caution.
Keep 'em flying...
S.J.Szabo
dennis 356
PostPosted: Thu Jan 18, 2018 5:44 am    Post subject: Re: How to split a stubborn case? Reply with quote
ensys wrote:
Mr. Dennis 356:
Thanks for the heads up ensys. Checked the case and it doesn´t appear warped, problem is instead someone back in the day smudged on what appears far more glue than necessary and now it sits solid. But I´m going to device some simple expanding tools to place across the sump apperture, between the two sturdy studs bellow the flywheel and additional two studs threaded through the holes above the flywheel, would be surprised if that didn´t have any effect. At a same time knocking carefully on the case of course while expanding the tools.
Starbucket
Starbucket is offline
PostPosted: Thu Jan 18, 2018 4:49 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Look for a heat gun from a tool supply store or a tool rental company. They will get it hot e`nuff to soften the sealant. They are like a hair drier but so much hotter.
dennis 356
PostPosted: Thu Jan 18, 2018 6:25 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Hi,
I have a heat gun in a garage out in the country side and am already planning to go there this upcomming weekend to get both the gun, a treaded rod, pipes and some hardware to fabricate the small expanders.
Jacks
Jacks is offline
PostPosted: Thu Jan 18, 2018 7:44 pm    Post subject: Re: How to split a stubborn case? Reply with quote
On early cases, the 6 main case bolts used copper sealing washers that can become deformed and lock on the threads. In those conditions, you will have to pry them off to separate the case halves. On later engines, a steel washer with a bevel on the back side to allow use of a small rubber sealing ring. The sealing rings can get forced in the stud bore, making the case stuck. Be sure to remove them before separating the halves.
Is there any movement at all? Just above the crankshaft gears on the split line of the case halves, there is a place where a screwdriver can be wedged in between two bosses to help start separation. Did you remove the two nuts behind the flywheel at the cam bore? No wavy washers stuck on any of the small studs? Idea
Jack Staggs
Actual name
dennis 356
PostPosted: Thu Jan 18, 2018 8:09 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Jack,
This case is about 1960 with the bevelled washers and I made sure all are off, including the bolts/washers behind the flywheel. There´s no movement whatsoever in the case, but it is interesting what you pointed out about the spot for a screwdriver, will test tomorrow. Other than that I think when I´ll be done with those small expanding tools and placing them than in different spots on the case, it will give way....
dennis 356
PostPosted: Fri Jan 19, 2018 10:21 am    Post subject: Re: How to split a stubborn case? Reply with quote
[quote="dennis 356"]
Jack,
Odd Jack, went down to my cellar today to check the slot in the case for the screwdriver you´ve mentioned and there´s none. Have two 1960 cases (already split by others when I bought them) and both have them, so this one can´t be 1960 and maybe a couple of years up, but rather earlier (although still can´t say as the third piece wasn´t correct).
With the slot in place I can imagen it being relatively easy peasy to split it, to big help anyway......
Dennis
Envious
Envious is offline
PostPosted: Mon Jan 22, 2018 2:36 pm    Post subject: Re: How to split a stubborn case? Reply with quote
I struggled with this last week as well. I'm a long time VW guy with my trusting oil pump case splitting tool that never fails me. I really wanted a reliable tool for 356 so I didn't have to go through all of the suggested voodoo I've read about on various posts. Long story short, I made a couple of really simple expansion tools with some threaded rod and bolted them to the case where the transmission bolts up. A little pressure to the expansion tools and a few taps on the case is all it took. Good luck.
71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225
dennis 356
PostPosted: Mon Jan 22, 2018 3:23 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Thanks Envious, good to hear this approach works. I haven´t got around making the expansion tools yet, but will during this week.
dennis 356
PostPosted: Sat Jan 27, 2018 4:30 am    Post subject: Re: How to split a stubborn case? Reply with quote
Case split now with the help of my little friends (see pics), easy and very effective without any need for tapping, prying, heating etc on the case.
After taken off the cam gear, it finally revealed the case being from 8/59 so there´s a clear transition in third pieces between 1959 and 1960 (case has later third piece), but surely many of you already knew that, I didnt.
Dennis
Starbucket
PostPosted: Sat Jan 27, 2018 8:06 am    Post subject: Re: How to split a stubborn case? Reply with quote
The correct sealant for the case split is Loctite 574 and will allow the splitting the case easy.
dennis 356
PostPosted: Sat Jan 27, 2018 8:23 am    Post subject: Re: How to split a stubborn case? Reply with quote
Thanks for the tips Starbucket, will use it when resealing again, but who knows how many handled the case over the years, not that I´m any pro either...... Wink
Dennis
speedstahguy
speedstahguy is offline
PostPosted: Mon Feb 12, 2018 1:33 pm    Post subject: Re: How to split a stubborn case? Reply with quote
This tool has always worked well for me:
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26%2D000%2D121
Pull the oil pump out, put this gizmo in and expand it. Never fails to pop the case.
Envious
Envious is offline
PostPosted: Mon Feb 12, 2018 1:44 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Doesn't work on a Porsche case. It's 3 pieces.
71 Type 1302 Custom
64 Type 151
64 Porsche 356c
52 BSA C11G
Danwvw
Danwvw is offline
PostPosted: Mon Feb 12, 2018 2:16 pm    Post subject: Re: How to split a stubborn case? Reply with quote
Very Smart you made that too. My bet was on the cam bolts behind the flywheel though. I remember them on some engines. Not sure if VW did it too?
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
