oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Sat Jan 20, 2018 6:07 am Post subject: Re: disc brakes - ftw |
Good thread!
All too often the focus is on going faster in our outdated cars without near enough thought given to getting it all to stop. The conditions out there on the road have changed drastically since these cars were new! In the mid '60s the main highway north/south here in Alberta between the 2 biggest cities had one lane each way and a speed limit of 45 mph. It was the highest speed road in all of the province. That is what our drum brakes were designed for!
No one dies from not having enough power, tens of thousands have died because they couldn't get stopped fast enough.
My only concern with upgrading brakes is keeping the correct front/rear balance. |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Sat Jan 20, 2018 7:22 am Post subject: Re: disc brakes - ftw |
Could have just been my combination of calipers. Four piston wilwoods and two piston strange, but this is what was required to get the pedal feel I was used too. However, a local shop said the squishy pedal is common, and I'd assume they have assembled multiple combinations.
Here is my setup. Prior to this switch I tried multiple combinations of residual pressure valves. The real problem was to move enough volume to engage the rear pads required too much travel with a 20.6mm bore. The 1-1/16" bore resolved that.
_________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Sat Jan 20, 2018 10:01 pm Post subject: Re: disc brakes - ftw |
madmike wrote: |
Just getting rid of them Rubber flex line and switching to Braided Stainless steel helps too |
Had all braided stainless brake lines with all drum set-up but threaded area of stainless line wasn't long enough to seat correctly on the new calipers, used rubber brake lines that came in disc brake kit and kept braided ss lines on back.
Just put all new wheel cylinders, shoes, hoses and a dual circuit master cylinder on my sister in laws 1964 bug that sat for 30 years. Forgot how much fun realigning the steel hard lines to the bigger dual circuit master and cutting /flaring new steel line was. |
terryly Samba Member
Posted: Sat Jan 20, 2018 11:36 pm Post subject: Re: disc brakes - ftw |
Here is a guy who upgraded his Empi disc brakes I copied him works great
oops forgot link here ya go
_________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Calgary Alberta Canada
Terry Lytle
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Sun Jan 21, 2018 4:19 am Post subject: Re: disc brakes - ftw |
oprn, If you are concerned about "balance" of the brakes front/rear, all I can say is try it first with disk front and rear at the same time so, this does not throw you while using your original master. Why I say this, is I think this whole "Balancing" act is year and car dependent. I have heard now for years and numerious on both accounts, and yes, i run disk, and this is on a a 74 Super. Disk work great like everyone else's but I was able to keep my master. And , yes, I have had some "Racers" in the drivers seat and they said there was no issues with the brakes nor the rest of the car, friends...
But yea, Disk sure do look cool..... RB
_________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
anobii Samba Member
Joined: October 15, 2015 Posts: 59 Location: Franklin Co VA
Posted: Sun Jan 21, 2018 10:12 pm Post subject: Re: disc brakes - ftw |
Something that might help someone out with master cylinder size. I just recently did 4 pot wilwood dynalites up front and 7/8 bore wheel cylinders in the drums out back. I calculated the master cylinder bore by the surface area of the caliper pistons and wheel cylinder and ended up needing a 1" bore MC. By a stroke of chance i discovered a Mitsubishi outlander has a 1" bore with outlets in roughly the same orientation as a vw dual Master. They are even 10mm iso bubble flare. It even is a remote resivoir. Take a look.
https://www.autopartswarehouse.com/sku/Centric/Brake_Master_Cylinder/CE130-dot-46526.html
Pay no attention to the two other masters that are shown, it was the best link i could find |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Mon Jan 22, 2018 9:24 am Post subject: Re: disc brakes - ftw |
I’m close to completing a brake upgrade on my 67 beetle which consists of factory Porsche 996 calipers and rotors using the CBPerf 2”dropped spindles.
The rears are Porsche 914, but I may consider going with one of the standard rear kits available that use Golf rear calipers later if I think it will be an upgrade over the older used 914 stuff.
Has anyone tried the 23.8mm MC from Coolrydes they use on there brake upgrades. Bolts in everything lines up for $150.
https://www.coolrydescustoms.com/coolstop-brakes.html |
jismay Samba Member
Joined: February 02, 2010 Posts: 219 Location: Norco, CA
Posted: Mon Jan 22, 2018 5:40 pm Post subject: Re: disc brakes - ftw |
I have the EMPI rear disc conversion on my 1970 Squareback.
I had to extend the parking brake cable tubes at the rear firewall by about 6 inches, but other than that everything was a straight bolt-up.
I still have the original master cylinder from when the car was front-disc/rear-drum.
My understanding is that the EMPI kit is designed to have the correct balance/bias when replacing a stock drum setup.
I have no breaking issues at all, car stops straight and hard.
The pedal feel could be nicer, but it isn't bad. _________________ 1970 Squareback with 1915cc dual 40idf
1979 Beetle Convertible
1980 Vanagon Westfalia
1989 VW Cabriolet |
oprn Samba Member
Posted: Mon Jan 22, 2018 7:30 pm Post subject: Re: disc brakes - ftw |
RailBoy wrote: |
oprn, If you are concerned about "balance" of the brakes front/rear, all I can say is try it first with disk front and rear at the same time so, this does not throw you while using your original master. |
Yes, unless you are an automotive engineer it will be a trial and error process. I suspect though that there may be sites one could go to these days and enter your proposed data and get a close approximation of the outcome.
RailBoy wrote: |
Why I say this, is I think this whole "Balancing" act is year and car dependent. |
Oh ya! These are "custom" cars in the truest sense! Here are a few variables we need to think about:
Tire size - taller decreases brake power, shorter increases it.
Tire compound and construction.
Component placement - fuel tank, battery, radiator if used, seating position, weight changes with drivetrain upgades.
Suspension changes effecting stiffness, weight transfer and cornering.
Just to name a few off the top of my head. These all change what works well on two seemingly identical cars.
Ideally we would swap brakes from a car with a similar weight balance but there are precious few that are tail end heavy like ours these days!
RailBoy wrote: |
But yea, Disk sure do look cool..... RB |
Yes again but that should not be the sole impetus for the change! |
Posted: Mon Jan 22, 2018 11:04 pm Post subject: Re: disc brakes - ftw |
jpaull wrote: |
Remember to get the proper master cylinder that is meant to work with the front/rear disk. |
This dual circuit master cylinder works with drum setup or front disk/rear drum setup. Top picture is 64 bug with all drum setup. Bottom picture is 64 bug with dual master cylinder with front disc/rear drums.
Either way, be safe and get the dual circuit master cylinder.
oprn Samba Member
Posted: Tue Jan 23, 2018 5:45 am Post subject: Re: disc brakes - ftw |
VW used to advertise that their brakes were a dual diagonal system for safety. How do you fellows set them up? |
