nacradriver Samba Member
Joined: January 15, 2009 Posts: 760 Location: Ventura, CA
Posted: Sat Jan 27, 2018 6:26 pm Post subject: Pumping Gas |
Has any one else been having problems with pumping gas while having to manually hold the EVP cover back when filling your Vanagon?
The black thing in the pic below..
_________________ Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985 |
jimf909 Samba Member
Posted: Sat Jan 27, 2018 6:44 pm Post subject: Re: Pumping Gas |
I don’t have to hold the evp back, but I do need to hold the nozzle in the fill neck, otherwise the nozzle will eject itself and pump gasoline on the ground.
Are you holding the evp back to keep the pump from shutting off? That may indicate the tanks vent system isn’t working (to vent the air into the charcoal canister while the gas replaces air in the tank). _________________ - Jim
Abscate wrote: |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Sat Jan 27, 2018 7:02 pm Post subject: Re: Pumping Gas |
We had a self-ejecting nozzle at a gas station in Garberville once.
The attendant was unconcerned, but assured me they'd get right on the case.
Good thing it didn't spark along its flight plan. But that's the only such incident on this type of pump and I mostly tend to put it on auto-fill.
The connections never feel all that well-designed, so I've been using more manual-fill when inspired. It can't be a bad idea, unless of course it doesn't shut off when full and there go your killer new Chacos. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sat Jan 27, 2018 7:47 pm Post subject: Re: Pumping Gas |
What's an EVP cover? We have tradewinds.
Aloha
tp |
kaalualu Samba Member
Joined: June 09, 2011 Posts: 274 Location: Big Island, Hawaii
Posted: Sat Jan 27, 2018 8:14 pm Post subject: Re: Pumping Gas |
Ha!! Hana hou!! _________________ '84 Transporter 16" CLK's/LED's/ AT's/Mansi injectors
'86 Wolfey Weekender Westfalia AT's/otherwise stock
Sold-'82 TinTop Diesel |
Abscate Samba Member
Posted: Sat Jan 27, 2018 8:16 pm Post subject: Re: Pumping Gas |
It's a thing the 8th largest economy in the world uses to keep clean air.
God, the air in LA in the 70s was awful, and we took it for granted. Watch an episode of Chips and a highway scene.
Aloha Tom! _________________ .ssS! |
dkoesyncro Samba Member
Posted: Sat Jan 27, 2018 9:07 pm Post subject: Re: Pumping Gas |
In the metro area of Portland and other larger city's we have the evp at the pumps, when on E or time for a fill it usually cuts me short of about 2 gallons compared to the old pump types.
I've also noticed that certain pumps at my favorite local station pump at different speeds and am able to fill desired amount without getting tripped, kinda makes me think that pump speed has gotten faster in recent years compared to the past. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Jan 27, 2018 9:44 pm Post subject: Re: Pumping Gas |
I do not have that problem with my '87 van, but definitely have that problem with my 1973 bus, same with the 1977 bus. Biggest problem I have with the '87 van is when the gas tank is full, it trips the gas pump fill nozzle closed, and that makes the damn thing fall off and splatters gas everywhere as it clatters to the ground.
I think the bigger problem with filling the old bus with those nozzles has more to do with the angle and flow rate. I have to hold the nozzle just right the whole time I fill up. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sat Jan 27, 2018 11:07 pm Post subject: Re: Pumping Gas |
dkoesyncro wrote: |
One of the most irritating things when the "new" unleaded fuel nozzles came out was how long it took to fill a tank!
Fuel all but dribbled out of that tiny spout!
Any old timer will vouch for how quickly fuel flowed from the old school leaded nozzles.
We used to remove those stupid nozzle size restrictors too........ then they started welding them in.
Jersey has those vapor recovery nozzles, what a PITA....... especially when filling cans!
I wonder why we even bother collecting vapors....... considering we are the last to get the West's air and it is simply drifting out into the Atlantic after we are done with it......
On my Van a slow fill at the end is the name of the game. It has a bad habit of rudely burping at the completion of a fill up.
Ghia
Vanagon
Beetle
Posted: Sun Jan 28, 2018 12:32 am Post subject: Re: Pumping Gas |
Abscate wrote: |
... God, the air in LA in the 70s was awful, and we took it for granted. ... |
It was worse in the 50's. We had smog alerts in high school.
I left SoCal in 1957. The air in China is worse, but it is cleansed by 5000 miles of ocean and rain before it reaches Kaneohe.
Aloha
tp |
Posted: Sun Jan 28, 2018 5:08 am Post subject: Re: Pumping Gas |
Tom Powell wrote: |
Abscate wrote: |
Aloha
tp |
I was in the diplomatic corps with pops back then. 😀
The history of the LA smog is amazing.
First LA smog attack was in 1945..people thought it was a Japaneses gas attack
In the 1950s, the auto industry used Stanford Research institute as a surrogate to deny that cars caused pollution. They asserted it was a " natural consequence of the LA basin geography"
Sound familiar to today? 😀
Pollution controls started in the 1960s but it took the cat and the sealed evap system to clean it up, starting in 1975
Ny can thank CA for its clean air by starting the trend and forcing the industry to develop cleaner engines. _________________ .ssS! |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Sun Jan 28, 2018 5:46 am Post subject: Re: Pumping Gas |
There is (or there used to be advertised) a motorcycle accessory that is a collar designed to hold that black bellows back from the spout to help improve the fillup experience. Google just helped me find a product known as McCuff designed to do the same.
I'd also like to take this opportunity to add a haiku I composed some years ago:
Gassing up the van
Fuel pukes from the filler tube.
Two flammable shoes. _________________ '87 Westy in Wolfram Grey Metallic |
mellowslow Samba Member
Joined: July 31, 2009 Posts: 278 Location: Vacationland
Posted: Sun Jan 28, 2018 7:55 am Post subject: Re: Pumping Gas |
Yeah, those spring loaded things require constant holding against the fill tube.
The valve handle locks have been taken off of a lot of pumps around here.
I usually only set to the first notch and watch the pump gallon gauge. Otherwise, gasoline baptism.
When I go to New Jersey it is Full Service Fueling only and the attendants set the nozzle lock and walk away. Splashback every effing time.
Got me a "Jersey girls don't pump gas" bumper sticker when I was down at the shore. _________________ '87 WBWE FAS Gen V |
msinabottle Samba Member
Posted: Thu Feb 01, 2018 5:11 pm Post subject: Re: Pumping Gas (Poetry!) |
Quote: |
Gassing up the van
Two flammable shoes. |
That... was a good haiku. POACHING ON MY PRESERVE, ARE WE? And WELL, too...
I must throw down!
Ten gallons in...
Consequence of overfill dire.
Feeling lucky, Punk?
Posted: Thu Feb 01, 2018 6:58 pm Post subject: Re: Pumping Gas |
Im not going to stay here unless Haiku stays traditional 5-7-5 _________________ .ssS! |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Thu Feb 01, 2018 7:51 pm Post subject: Re: Pumping Gas |
Huh, I was hopeful this thread was about filing up the tank and how gas was better/worse when we were kids.
Tricks I've employed: turn handle upside down 'cause it catches the lip and holds on better somehow, put it on the slowest setting possible, watch the gal./liters closely on the pump while filling and remember just where the gauge was prior to starting, listen near filler neck for sound of gas getting full in tank - the pitch goes up, quick stop. I can't let the auto shutoff try to accomplish the job as inevitably the overflow runs out the top and stinks up my van as the runoff drools all over. Not good for environment, or shoes. And I actually despise the SMELL of gasoline. Its amazing tho, how much worse gas smells in Mexico. Can't remember smelling gas in Canada, maybe its better up there? Never had the opportunity to fill or drive anything anywhere other than north of the Yucatan in the Merikkas. Was too young when we lived in Daegu Korea, and the University had a car/driver take us where we wanted to go anyway. That's where I saw my first Karmann Ghia, a Canary Yellow '72 Coupe'. Brand new, brought there by the US Government fellow that kept tabs on our family. Probably the most influential moment in my awakening to cool looking cars. My brothers called it Mower's Flower Power car. Once in a while, late at night in our little house, while my dad worked late at his desk in the family room, we'd hear him randomly say "F*ck the CIA!" Of course our house was bugged.
Oh, and gas was 25 cents / Gal first time I remember paying, used to fill my '75 Honda XR75, usually took around 15 cents. I think it was $275 on sale in mid '76 'cause it was last years' model. My dad says he remembers 3 cents a Gal. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Sat Feb 03, 2018 8:27 pm Post subject: Re: Pumping Gas |
I pump my gas on half pressure, but it still burps (sprays all over the place) if I don't catch it before it fills up, this seems to be happening more often than it used to. Last time it did it, it got all over my new boots, which seriously ticked me off!
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
joethebeekeeper01 Samba Member
Posted: Sun Feb 04, 2018 12:44 am Post subject: Re: Pumping Gas |
I've had issues with those healy nozzles as well. Although holding the boot allows you to fill up I suspect the root cause is the auto shut off siphon in the nozzle, compressing the bellows by hand just allows you to reposition the tip so the siphon is not tripped prematurely. Which could be a sign of an issue with you vans vapor control system or the station itself.
I have better luck with vst nozzles found on balance gas stations (balance is one of the two types of vapor control tech for gas stations https://goo.gl/images/FycKpe ). Vst nozzles are shaped a little more like a "old school" nozzle which may be why they work better.
Emco nozzles (also found on balance style stations https://goo.gl/images/H2RuhT ) like to spring out of the tank in my experience so I avoid those stations if I have the choice. |
