The Stupid Question Thread
Page: Previous  1, 2, 3 ... 354, 355, 356 ... 513, 514, 515  Next
busdaddy
busdaddy is offline
PostPosted: Sat Jan 27, 2018 7:22 pm    Post subject: Re: The Stupid Question Thread Reply with quote
The 3 dot thing is a vent for sure, it's been too long since I've been close to an 003 so the other appendage isn't familiar, but it's likely a vent as well. Probably one for the trans and the dotty one for the final drive.
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Sat Jan 27, 2018 9:03 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I think you have that backwards, you can see them both clearly in this picture:
stwesty
stwesty is offline
PostPosted: Sat Jan 27, 2018 9:14 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hmm in that picture they are both the metal three dot versions. On mine one of them is a rubber tube, I'm scared to pull it off since it is a bit brittle but perhaps the three dot part is underneath?
Any idea where I might source the part (or even just good search terms to use)?
1974 Westfalia, automatic, dual-carb
Wildthings
PostPosted: Sat Jan 27, 2018 10:32 pm    Post subject: Re: The Stupid Question Thread Reply with quote
The rubber may have just run up to a higher location, really lack knowledge of Bay Window Transporters with auto boxes. I would think the vents could be found readily enough. You might check at a local transmission shop or jobber. Surely a place like German Transaxle should have a source for them. I would think they would be call "vent valves" or "vent check valves" or something similar. You just need one with the correct thread, as a GUESS I would say that the thread is a M10x1 but really do not know.
stwesty
stwesty is offline
PostPosted: Sat Jan 27, 2018 11:40 pm    Post subject: Re: The Stupid Question Thread Reply with quote
This thread has a comment suggesting you can fill the gear oil through the side vent.
https://www.thesamba.com/vw/forum/viewtopic.php?p=5907590
Edit: looks like the three dots version might be an aftermarket item similar to this:
https://www.currieenterprises.com/ce-9028
lil-jinx
lil-jinx is offline
PostPosted: Sun Jan 28, 2018 6:54 pm    Post subject: Re: The Stupid Question Thread Reply with quote
That rubber may be a duckbill vent,they are used to allow air out and block air from going in,just google duckbill vent.
1968 Dune Buggy
1974 parts bus
tonysantacruz
tonysantacruz is offline
PostPosted: Wed Jan 31, 2018 10:24 am    Post subject: Re: The Stupid Question Thread Reply with quote
For my 74 bus, I have the possibility of buying either of the air cleaner filter. Type 1 engine, looks just like the bug one.
Filter and part number. This one is from a 1600 bus (like mine)
Other filters:
From a Ghia:
From another 1600 bus.
Which one of these would work best?
And, I still need the charcoal canister, no?
busdaddy
busdaddy is offline
PostPosted: Wed Jan 31, 2018 10:56 am    Post subject: Re: The Stupid Question Thread Reply with quote
tonysantacruz wrote:
For my 74 bus, I have the possibility of buying either of the air cleaner filter. Which one of these would work best?
Add this to your exisiting thread for better answers: https://www.thesamba.com/vw/forum/viewtopic.php?t=693334&highlight=
They are all good filters, the oil bath never needs any replacement elements but still needs regular maintenance, I'm not sure if any of those will fit the brackets in your bus.
Слава Україні!
AircooledHome
AircooledHome is offline
PostPosted: Fri Feb 02, 2018 10:17 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I've got a good one..
Im finalizing my 1776.. Just installing my intake manifolds and test fitting the carbs, I realize that one carb linkage connection contacts the fan shroud, and one is an inch or so away from the shroud..
Are these empi / redline style drla intakes supposed to be mirror or identical??
I have two identical...
From this image they looks identical:
This image SEEMS like they are mirror:
My issue:
'71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight=
AircooledHome
PostPosted: Sat Feb 03, 2018 1:37 pm    Post subject: Re: The Stupid Question Thread Reply with quote
My issue:
Helllooo duuuhh
Two different base plates
cv66seabear
cv66seabear is offline
PostPosted: Sat Feb 03, 2018 10:22 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Extra Stupid Question: Where do you find screws and nuts, I have limited access to metric hardware, so I'd like to know if there is an online source you use.
Thanks,
Kent (Wisconsin)
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
busdaddy
busdaddy is offline
PostPosted: Sat Feb 03, 2018 11:18 pm    Post subject: Re: The Stupid Question Thread Reply with quote
www.mcmaster.com
Слава Україні!
kreemoweet
kreemoweet is offline
PostPosted: Sun Feb 04, 2018 9:13 am    Post subject: Re: The Stupid Question Thread Reply with quote
cv66seabear wrote:
... screws and nuts ... online source ...
https://www.belmetric.com/
'67 bug: seized by the authorities
Wildthings
PostPosted: Sun Feb 04, 2018 10:43 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks,
Kent (Wisconsin)
A lot of hardware stores carry a pretty good variety of metric nuts and bolts in all the little trays in the fastener section. They will often have washer head bolts that are grade 10.9.
Danwvw
Danwvw is offline
PostPosted: Sun Feb 04, 2018 10:50 am    Post subject: Re: The Stupid Question Thread Reply with quote
Mine uses SAE 10X24 Wing Nuts for the two air cleaner post which are just 10X24 All thread. They are available at any local hardware store or lumber store.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Feb 05, 2018 2:32 am    Post subject: Re: The Stupid Question Thread Reply with quote
I love those guys.
I've also had good luck asking the folks at my local hardware store to stock more metric stuff. Once they do, I make a point to buy it, and they always seem to stock more after that. Smile
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
cv66seabear
PostPosted: Mon Feb 05, 2018 7:37 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks everyone!
Passat Wagon "Wolf"
AircooledHome
PostPosted: Mon Feb 05, 2018 12:19 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Would you guys consider a Vaccum leak of 2 hg over 40 minutes on a 1971 brake booster to be bad enough to worry?
I pumped the booster up to 17 hg with a Mityvac and it's holding above 15hg for quite some time.
Danwvw
Danwvw is offline
PostPosted: Mon Feb 05, 2018 12:27 pm    Post subject: Re: The Stupid Question Thread Reply with quote
No that is hardly any vacuum leak for a booster.
AircooledHome
PostPosted: Mon Feb 05, 2018 1:28 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Cool. Follow up question :
If I have Mityvac hooked up in engine bay and pumped to 15 hg, when I press the brake pedal, the Mityvac drops to 0.
Engine not running, it's not fully installed yet.
Is that normal?
Page 355 of 515
