busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jan 27, 2018 7:22 pm Post subject: Re: The Stupid Question Thread |
The 3 dot thing is a vent for sure, it's been too long since I've been close to an 003 so the other appendage isn't familiar, but it's likely a vent as well. Probably one for the trans and the dotty one for the final drive. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jan 27, 2018 9:03 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Probably one for the trans and the dotty one for the final drive. |
I think you have that backwards, you can see them both clearly in this picture:
stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Posted: Sat Jan 27, 2018 9:14 pm Post subject: Re: The Stupid Question Thread |
Hmm in that picture they are both the metal three dot versions. On mine one of them is a rubber tube, I'm scared to pull it off since it is a bit brittle but perhaps the three dot part is underneath?
Any idea where I might source the part (or even just good search terms to use)? _________________ 1974 Westfalia, automatic, dual-carb |
Posted: Sat Jan 27, 2018 10:32 pm Post subject: Re: The Stupid Question Thread |
stwesty wrote: |
Any idea where I might source the part (or even just good search terms to use)? |
The rubber may have just run up to a higher location, really lack knowledge of Bay Window Transporters with auto boxes. I would think the vents could be found readily enough. You might check at a local transmission shop or jobber. Surely a place like German Transaxle should have a source for them. I would think they would be call "vent valves" or "vent check valves" or something similar. You just need one with the correct thread, as a GUESS I would say that the thread is a M10x1 but really do not know. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
tonysantacruz Samba Member
Posted: Wed Jan 31, 2018 10:24 am Post subject: Re: The Stupid Question Thread |
For my 74 bus, I have the possibility of buying either of the air cleaner filter. Type 1 engine, looks just like the bug one.
Filter and part number. This one is from a 1600 bus (like mine)
Other filters:
From a Ghia:
From another 1600 bus.
Which one of these would work best?
And, I still need the charcoal canister, no? |
Posted: Wed Jan 31, 2018 10:56 am Post subject: Re: The Stupid Question Thread |
tonysantacruz wrote: |
For my 74 bus, I have the possibility of buying either of the air cleaner filter. Which one of these would work best?
Add this to your exisiting thread for better answers: https://www.thesamba.com/vw/forum/viewtopic.php?t=693334&highlight=
They are all good filters, the oil bath never needs any replacement elements but still needs regular maintenance, I'm not sure if any of those will fit the brackets in your bus. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
AircooledHome Samba Member
Joined: October 13, 2015 Posts: 273 Location: California
Posted: Fri Feb 02, 2018 10:17 pm Post subject: Re: The Stupid Question Thread |
I've got a good one..
Im finalizing my 1776.. Just installing my intake manifolds and test fitting the carbs, I realize that one carb linkage connection contacts the fan shroud, and one is an inch or so away from the shroud..
Are these empi / redline style drla intakes supposed to be mirror or identical??
I have two identical...
From this image they looks identical:
This image SEEMS like they are mirror:
My issue:
_________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Posted: Sat Feb 03, 2018 1:37 pm Post subject: Re: The Stupid Question Thread |
AircooledHome wrote: |
My issue:
Helllooo duuuhh
Two different base plates
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Sat Feb 03, 2018 10:22 pm Post subject: Re: The Stupid Question Thread |
Extra Stupid Question: Where do you find screws and nuts, I have limited access to metric hardware, so I'd like to know if there is an online source you use.
Thanks,
Kent (Wisconsin) _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy" |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sun Feb 04, 2018 10:43 am Post subject: Re: The Stupid Question Thread |
cv66seabear wrote: |
Thanks,
Kent (Wisconsin) |
A lot of hardware stores carry a pretty good variety of metric nuts and bolts in all the little trays in the fastener section. They will often have washer head bolts that are grade 10.9.
Danwvw Samba Member
Posted: Sun Feb 04, 2018 10:50 am Post subject: Re: The Stupid Question Thread |
Mine uses SAE 10X24 Wing Nuts for the two air cleaner post which are just 10X24 All thread. They are available at any local hardware store or lumber store. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
airschooled Air-Schooled
Posted: Mon Feb 05, 2018 2:32 am Post subject: Re: The Stupid Question Thread |
I love those guys.
I've also had good luck asking the folks at my local hardware store to stock more metric stuff. Once they do, I make a point to buy it, and they always seem to stock more after that.
www.airschooled.com |
Posted: Mon Feb 05, 2018 7:37 am Post subject: Re: The Stupid Question Thread |
Thanks everyone! _________________ "Not all who wander are lost." JRR Tolkien
Passat Wagon "Wolf"
Posted: Mon Feb 05, 2018 12:19 pm Post subject: Re: The Stupid Question Thread |
Would you guys consider a Vaccum leak of 2 hg over 40 minutes on a 1971 brake booster to be bad enough to worry?
I pumped the booster up to 17 hg with a Mityvac and it's holding above 15hg for quite some time. _________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Danwvw Samba Member
Posted: Mon Feb 05, 2018 1:28 pm Post subject: Re: The Stupid Question Thread |
Danwvw wrote: |
No that is hardly any vacuum leak for a booster. |
Cool. Follow up question :
If I have Mityvac hooked up in engine bay and pumped to 15 hg, when I press the brake pedal, the Mityvac drops to 0.
Engine not running, it's not fully installed yet.
Is that normal? _________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
