My 73
wv181
wv181 is offline
PostPosted: Sat Jan 27, 2018 2:03 pm    Post subject: Re: My 73 Reply with quote
After a little adjust here is a new video. Sounds nice to me!
https://youtu.be/U8NS0ZPtlq0
1973 Super Beetle - sold
1973 Thing - running project
Buggeee
Buggeee is offline
PostPosted: Sat Jan 27, 2018 9:13 pm    Post subject: Re: My 73 Reply with quote
Sounds great. Gorgeous build. Cool
1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote:
Every setback is an opportunity to learn stuff and to buy new tools.
wv181
wv181 is offline
PostPosted: Sun Jan 28, 2018 12:07 pm    Post subject: Re: My 73 Reply with quote
While waiting for the body I have lots to work on. I have figured out that since I opted to go full flow I can't mount the rear "skid plate". It won't clear the port on the oil pump.
Skid Plate
Oil pump
Also does anyone know where this piece of tin goes?
Cant find it in the parts manual.
Al Capulco
Al Capulco is offline
PostPosted: Sun Jan 28, 2018 6:55 pm    Post subject: Re: My 73 Reply with quote
Air deflector plate rear right. Page 12 item 8A. Not shown on the page, same as item 8 but is on the right hand side.
wv181
wv181 is offline
PostPosted: Sun Jan 28, 2018 11:56 pm    Post subject: Re: My 73 Reply with quote
Thanks Al. I am missing the other side so I will have to see if Ican find one.
wv181
wv181 is offline
PostPosted: Wed Jan 31, 2018 6:20 pm    Post subject: Re: My 73 Reply with quote
I have my clutch tube bracket installed but I have this other bracket that looks the same but different. Any clues?
Same but different
EDragnDean
EDragnDean is offline
PostPosted: Sat Feb 03, 2018 9:58 am    Post subject: Re: My 73 Reply with quote
Mine looks like the second one. Same part.
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
Buggeee
Buggeee is offline
PostPosted: Sun Feb 04, 2018 6:53 pm    Post subject: Re: My 73 Reply with quote
wv181
wv181 is offline
PostPosted: Tue Feb 20, 2018 5:22 pm    Post subject: Re: My 73 Reply with quote
Thanks for those pics. I did find that piece from Mike Basso. Fits perfect. As soon as i get it stripped and painted I will post pics.
wv181
wv181 is offline
PostPosted: Mon Apr 23, 2018 6:05 pm    Post subject: Re: My 73 Reply with quote
THE BODY IS BACK FROM PAINT!
I went with an after market orange with a green and gold metallic flake. It looks quite different from different angles around the car. I tried to get some pics that show what I'm talking about.
I'm was debating on whether or not to mount the cut off wader boxes but I think they turned out so nice I'm going to do it.
You can't really tell from the pic but the body man welded a small round rod to the inside of the intake of the boxes to give it more finished look. The ones I had looked at before just used pieces of the door top beading to go around the opening.
wv181
wv181 is offline
PostPosted: Sat Jun 02, 2018 3:03 pm    Post subject: Re: My 73 Reply with quote
The pan is complete and ready for the body.
I had the rear arms lengthened which came with a few challenges. The e-brake cables were a little short so we fabed up some extensions using copper tubing. Should work fine. Also had to drill a hole in the upper gusset, just behind the bump stop, and attach the cable there.
wv181
wv181 is offline
PostPosted: Tue Jul 10, 2018 8:30 am    Post subject: Re: My 73 Reply with quote
OK. So skip ahead a little bit now. Put the body on the pan. I used a body to pan gasket, stuck it down with weatherstrip adhesive. Went on nice and smooth except for no pulling the plug wires. Broke off one of the ends of the wire. Live and learn. The engine bay rubber was a bit of a chore figured out on the bottom gasket to put one edge in all the way then go back and work the other edge in. The top gasket just required a little spray lube and slipped right in.
Mounted the steering column, shifter, nice Vintage Speed unit, wood fat grip steering wheel and new high backs from The Thing Shop.
Then on to the wiring. I won't bore you with the three days of head scratching, cursing and bloody knuckles. What I will say is to take the pdf of the wiring diaragm down to your local Staples or whatever and have them blow it up to at least 18x24 then tape it to the windshield while doing your wiring.
Also new license plate.
Need to mount the doors and front fenders then tackle the heater, but I have taken it for a small drive down the road. Lots of fun just to be able to do that.
JayC
JayC is offline
PostPosted: Tue Jul 10, 2018 9:02 am    Post subject: Re: My 73 Reply with quote
Love the color!
That wiring diagram was a life saver when I was doing mine. Not only did I blow it up, I had it laminated and have it hanging on the wall in the garage!
jay
wv181
wv181 is offline
PostPosted: Mon Jul 30, 2018 4:26 pm    Post subject: Re: My 73 Reply with quote
I have a question? Does anyone know what these wires are for? They are in the head light harness but I dont see them on the wiring diagram.
Bashr52
Bashr52 is offline
PostPosted: Tue Jul 31, 2018 4:28 am    Post subject: Re: My 73 Reply with quote
If I remember correctly, there should be 6 wires in that harness. 3 are for the headlight, 3 are for the turn signal.
wv181
wv181 is offline
PostPosted: Tue Jul 31, 2018 8:29 am    Post subject: Re: My 73 Reply with quote
I have the headlights and turn signals all hooked up and working but these 4 wires remain. I just do not see this color combo anywhere on the wiring diagram.
germanbilly
germanbilly is offline
PostPosted: Tue Jul 31, 2018 9:04 am    Post subject: Re: My 73 Reply with quote
That is if you want to wire in a set of driving lights or fog lights. It was just added in case you want to install them I would guess. Saves time and is a lot cleaner.
GB
Al Capulco
PostPosted: Tue Jul 31, 2018 3:14 pm    Post subject: Re: My 73 Reply with quote
Is the wire harness original or aftermarket? The blk/yellow could be for the horn or something to do with the headlights. The brown is a ground and I can't make out the other color.
wv181
wv181 is offline
PostPosted: Sat Aug 04, 2018 7:50 am    Post subject: Re: My 73 Reply with quote
The one wire is green and comes out in the trunk on the passenger side. The other 3 are black w/ yellow stripe, light blue, brown. I do not have my horn hooked up so i see that the black/yellow and brown go there. So that just leaves a single blue on the left and the single green on the right.
wv181
wv181 is offline
PostPosted: Wed Apr 03, 2019 8:40 am    Post subject: Re: My 73 Reply with quote
Update time. These are the latest pictures. Runs and drives, just some odds and ends to sort out. Very pleased with my results so far.
Page 3 of 4
