calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Fri Feb 02, 2018 7:08 pm Post subject: Re: Engine noise when not under load. |
Well my Tom Joad Grapes of Wrath motor came together really nice. Drove it around a bit today and discovered that the rattle is indeed the transmission. At least I have a motor that doesn’t leak all over the place, and it’s nice and clean when I pull it to do the old crash box....a little tired of that noisy thing...
Any suggestions on an upgrade that would work with the stock 36hp? |
Posted: Fri Feb 09, 2018 10:59 am Post subject: Re: Engine noise when not under load. |
AZOffTheWall wrote: |
What was making Noise? it wasn't that Teflon button and those wrist pins look fine. Did you at least pull the rods off and check the bearings? You should be able to get to them through the cylinder opening if you afraid to split this this all the way open. |
Should have done this!!! I pushed my luck with that eBay motor, I was confident it was fine in the block, only to find after complete installation that rod bearings are indeed in need of replacement. Same problem with the other block as well. Transmission is fine. So I’ve come full circle, and starting all over again. I’ve learned a lot. I’ll be doing the rings as well, she was running a little smokey...here is a photo I took yesterday before I started tearing it all down again...
Posted: Tue Feb 13, 2018 7:18 pm Post subject: Re: Engine noise when not under load. |
So I got the eBay motor open. The offending noise is a worn rod bearing. The original motor I will open tomorrow, but I’m sure it’s offending noise comes from how loose the crank is. What’s interesting to me is how similar these two motors sounded in their signals that something was definitely wrong, this is what lead me to believe that it was transmission noises.
My question now is, do I replace the rod and bearing? Or would replacing just the bearing be enough. |
Posted: Tue Feb 13, 2018 7:23 pm Post subject: Re: Engine noise when not under load. |
Also noted that this motor seems to have 0 endplay.
Posted: Wed Feb 14, 2018 5:21 pm Post subject: Re: Engine noise when not under load. |
So this is what my engine noise looks like.
And this was interesting...a homemade rod shim...
Posted: Fri Feb 16, 2018 1:52 pm Post subject: Re: Engine noise when not under load. |
...and this what the other engine noise looks like...hence the too much overplay...
Correction, I thought there were only two shims, turns out two were oil stuck, so there were three.
this the eBay motor case
Posted: Fri Feb 16, 2018 3:20 pm Post subject: Re: Engine noise when not under load. |
So my plan now is to use eBay motor case, replace rings, rod and main bearings...
Anything else? Should I use the rods from the old motor since the wear on the bearings is even? They are lighter than the eBay rods.
Any advice would be appreciated. Thanks. |
