Yellow & Tan '56 Subhatch Westy - 20-147419
Page: Previous  1, 2, 3 ... 9, 10, 11, 12  Next
campingbox Premium Member
campingbox is offline
PostPosted: Sat Jan 27, 2018 7:47 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Braukuche wrote:
campingbox wrote:
BarryL wrote:
Intriguing. How do you check run out without the pilot bearing?
The mainshaft bearings are in place. That is where the input shaft seal goes. It doesn't support anything.
BarryL wrote:
Nice pattern. Is the grease with the more forward mark the decelerate side?
I forget. I would have to look at it again and watch things move. That's the first time I've ever set up a new R&P. I'm sure someone who does this every day can answer that question better.
Never done that work, I though I was being ballsy pulling the center section out of my 356 and taking it in to be inspected. Impressive work Greg.
Thanks, it was a lot of fun. I'm sure I'll do it again next time. Reading through the book the first time gave me a headache. Now it makes sense. It's just all basic algebra, measure a ton of pieces and write out the formula and figure out what shims to use. Or do it all by feel which is how our buddy Gary likes to do it because he can get the job done faster that way. I think the grease contact pattern is really only used when setting up a new ring and pinion, and that is because the measurements will only get you in the ballpark, you really gotta see how the two gears talk to each other.
AS350driver
AS350driver is offline
PostPosted: Sat Jan 27, 2018 9:21 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Hopefully, this is all a sign it will be rolling soon, and you’ll post pics of it or even a video of it running around. Waiting not so patiently here Smile
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Sun Jan 28, 2018 10:28 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Keep up the good work Greg I think I have reread your build several times and it's always like the first time, a refreshing look at my favorite year.
Greg what is the build date?
Best factory color combo ever.
American Red Cross Safe And Well link:
https://safeandwell.communityos.org/cms/index.php?...OSmeUzh8l4
Maui Roadsters VW Logo
www.mauiroadsters.com
Lind wrote:
BarryL Premium Member
BarryL is offline
PostPosted: Sun Jan 28, 2018 10:49 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
campingbox wrote:
BarryL wrote:
I hear ya but I meant the flywheel pilot bearing. I thought that part of the mainshaft unscrewed with the sliding sleeve and was separate and dangly.
That wobbly thing with the little screw and sleeve started with the tunnel type transmissions. Maybe to reduce noise? Those are a lot easier and faster to take apart and rebuild.
The splitcase transmissions are one solid shaft end to end:
https://www.thesamba.com/vw/gallery/pix/1708104.jpg
If first gear or second gear gets chewed up (they almost always are) you have to replace that whole piece to fix it.
Dang me, take a rope and hang me! Thanks for straightening me out (pun intended).
I checked the http://oacdp.org to see wtf before I posted first and it showed, "tunnel case gears", "synchromesh gears", as the same solid shaft so I figured they just didn't draw it in. "Fully synchronized gears" shows it which makes sense.
Carry on with the bitchen' build.
PostPosted: Sun Jan 28, 2018 4:46 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Thanks!
October 7th 1955 according to the birth certificate from the auto museum.
PostPosted: Thu Feb 01, 2018 10:31 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Your twin?
http://www.benpon.nl/index.php/line-up
Lind wrote:
[email protected]
jmp@ncounty.net is offline
PostPosted: Thu Feb 01, 2018 4:05 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
nice
PostPosted: Thu Feb 01, 2018 4:56 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
LAGrunthaner wrote:
Your twin?
Cool photo!
That particular bus started out as a double door panel.
Windows, subhatch, etc, are all more recent additions. It has a '59-61 So-23 kit in it now.
I would expect my bus or Jim's bus is where he got the inspiration for the colors.
Clara Premium Member
Clara is offline
PostPosted: Sat Feb 03, 2018 3:37 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
PeteSC
PeteSC is offline
PostPosted: Sat Feb 03, 2018 7:40 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Shocked
Nice update! I think I saw on Joe Ruiz’s site....there’s an Okrasa motor for this, correct?
Touch Nicks Thing
Touch Nicks Thing is offline
PostPosted: Sun Feb 04, 2018 5:46 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Oh boy, here we go!! Thanks for the update!
PostPosted: Sun Feb 04, 2018 8:11 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Thanks a ton Clara! Stunning absolutely stunning and super cool not to show the entire bus so we can continue eating popcorn for this show. Popcorn
PostPosted: Sun Feb 04, 2018 9:13 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
I'd been saving these VW logo axle boots for this project:
One of them split during install. That's a bit of a downer. I ended up using one of the NOS ones and one new one from WW. Wonder which one will leak first?
PostPosted: Sun Feb 04, 2018 9:18 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Got the trans mostly together on the stand.
PostPosted: Sun Feb 04, 2018 9:21 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
And then my buddy Alex (50ate) helped me stuff it into the bus. Bumper off, shift rod in, trans in.
sled
sled is offline
PostPosted: Sun Feb 04, 2018 9:42 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
gunna be awesome when you go flying through your first huge mud puddle on the Shasta snow trip!!
drive your split.
easy e
easy e is offline
PostPosted: Sun Feb 04, 2018 11:49 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Looks great! I love this build.
At least the boot split now... and not 20 miles down the road.
aka: Evan
BarryL is offline
PostPosted: Sun Feb 04, 2018 12:56 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
You Small Nut guys make me jealous on the RGB install part.
StockNazi
StockNazi is offline
PostPosted: Sun Feb 04, 2018 3:16 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Are the plates necessary to hold the axles out for a split-case transmission?
WANTED:
Westfalia privy tent poles(silver painted / pre-59)
58 Westfalia roof rack and cabinet knobs
PostPosted: Sun Feb 04, 2018 8:01 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Axles in you mean? No, as far as I know the fulcrum plates can't slip behind on a splitcase.
Page 10 of 12
