Terry Gaudet Samba Member
Joined: March 11, 2004 Posts: 399 Location: New Brunswick, Canada
Posted: Fri Jan 05, 2018 9:04 am Post subject: Split rear shock conversion - other brackets |
Hey there,
I have recently acquired a bunch of old split parts and found these brackets in the bottom of a box. I know the ones on the left are conversion brackets to eliminate lever shocks, but does anyone know what the two brackets are on the right?
_________________ Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab |
sled Samba Member
Posted: Fri Jan 05, 2018 9:15 am Post subject: Re: Split rear shock conversion - other brackets |
those are the other brackets required to mount telescopic shocks. lever shock cars had no upper shock mount, so these brackets create one. _________________ drive your split. |
Posted: Fri Jan 05, 2018 10:30 am Post subject: Re: Split rear shock conversion - other brackets |
Thanks Sled. Really appreciate it. _________________ Terry Gaudet
1965 Double Cab |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Fri Jan 05, 2018 1:11 pm Post subject: Re: Split rear shock conversion - other brackets |
Terry, I also had (maybe still have) some of those brackets. As far as I am aware they were a genuine item created to convert from lever to telescopic shock absorbers as I seem to remember that the first ones that I saw had part number labels on them.
I have also seen a different type of bracket assembly to do the same job, the origin of those I do not know. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
roll Samba Member
Posted: Thu Feb 01, 2018 8:04 am Post subject: Re: Split rear shock conversion - other brackets |
Hi,
Do you know where I can purchase the conversion brackets to eliminate the lever shocks? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69801 Location: Phoenix Metro
roll Samba Member
Posted: Fri Feb 02, 2018 3:24 pm Post subject: Re: Split rear shock conversion - other brackets |
I contacted Greg and was able to purchase a set of the rear shock conversion brackets for my Split.
Thank you Everett! |
Posted: Sun Feb 04, 2018 3:16 am Post subject: Re: Split rear shock conversion - other brackets |
Hi Roll,
How much did you pay for the new set of brackets? _________________ Terry Gaudet
1965 Double Cab |
roll Samba Member
Posted: Mon Feb 05, 2018 4:54 am Post subject: Re: Split rear shock conversion - other brackets |
Hi Terry,
The cost was $275.00 plus shipping ($20.00 Priority Mail) for the complete set of two upper mounts and two lower mounts.
Contact info:
Greg Banfill
[email protected]
707-291-7606 |
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
