Another fuel sender repair method T2a
VeloMikey
VeloMikey is offline
PostPosted: Thu Nov 16, 2017 11:25 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Here it is disassembled. Looks like the wire to the lug broke. Simple soldier job to repair it. Do I need to use special wire or will anything work?
'58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748
busdaddy
busdaddy is online now
PostPosted: Fri Nov 17, 2017 8:03 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Little tiny winches to tension the hair wire, how cool is that!? They don't make stuff like that anymore. Cool
Yes regular copper wire will do that job fine.
Слава Україні!
TomWesty
TomWesty is offline
PostPosted: Mon Feb 05, 2018 4:00 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Yeah, that’s cool. Tension it with the winch and lock it down with the set screw.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Feb 05, 2018 4:32 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
y'all should have been around when we went from stones to copper.... the iron guys who came along behind us didn't have a clue how that stuff worked......
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
sodbuster
sodbuster is offline
PostPosted: Mon Feb 12, 2018 9:50 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
I'm in the process of going through my bus after it's engine gave up the ghost. Along with the rebuild one of the things on the "while I'm in there" list is to get my fuel gauge working again. It has always kind of worked but not too well. whenever I would fill up the gauge would read either full or a little over 3/4 of a tank. It would function ok at first, then the needle would just dive to empty with the tank at least 3/4 full.
So "while I was in there" I pulled my fuel tank to get at the sending unit. With sending unit in hand I started checking the sender out using Telfods exelent repair notes. It tested good. 3.3 ohms full 78.4 ohms empty It's testing good. Give it a bit of a shake a few light taps nothing is fazing the reading on the meter. It's solid.
I was a little confused to discover this. The sending unit seemed fine. So I forged ahead and checked the gauge. When the sending unit wire was grounded the needle on the gauge would not go much past 3/4. Now I am questioning the gauge instead of the sending unit at this point. So I decide to put it down for awhile and work on some thing else.
I ventured to have another look last night and wouldn't you know, the sending unit has now gone jankey on me and is now clearly testing bad. Upon further inspection I deemed it a prime cannadate for Telfords repair method which I will do. (I also have another I can fix as well.) But it is the guage itself that has me tapping the keys today.
Unlike the later models that have a "vibrator" included on the fuel gauge circut to drop voltage to the gauge. The early bays do not have this component. The Bently shows two wires to the fuel gauge on my '71 bus. One from the sending unit and another from the #15 terminal on the fuse block. This is a strait 12 volt tap through the ignition switch. (key'd hot.) There is nothing before the gauge to drop voltage to it. So either it is not required or is internal to the gauge I don't know which.
So here is where I am at with this. I need to effect a repair of the sending unit. Hopefully that will stop the guage from suddenly dropping off to empty. But what to do about the gauge not going all the way to full? Obviously a voltage check of the #15 wire to the gauge is in order as well as checking and cleaning any grounds I come across under the dash. if the voltage test to the guage is good what else short of replacing the gauge outright need to be checked beyond what I have already listed?
telford dorr
telford dorr is offline
PostPosted: Mon Feb 12, 2018 9:59 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Your tests are correct. Open circuit at the sender should read empty. Short to ground should read full. Check all of the connections in the sender circuit (including the fuse).
Early Bays have no voltage regulator. 12 volts direct to the indicator. Indicator to sender. Sender to ground.
Senders tend to either work or not work. As a sanity check, check your meter probes. Sometimes it helps to take a ScotchBrite pad to the probe tips, which get oxidized over time and give you bad readings. Short the tips together and verify that you read less than 1 ohm.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
sodbuster
PostPosted: Mon Feb 12, 2018 10:50 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Thanks for the confermation Telford. Looks like a voltage drop test is what is next up in the process. Just to see if the gauge is getting everything it needs.
busdaddy
PostPosted: Mon Feb 12, 2018 11:10 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Mine did that for years until it finally died last year (the almost full thing, mine didn't drop randomly), after repairing the sender ground and soldering the G wire side of the circuit on both the wet and top side of the rivet it now reads full like one would expect it to. It's not just the ground connection that gets weak.
Soldering the G side is a little tricky, linger too long with the iron and you'll melt the plastic ferrule it goes through, you can rehammer the rivet to tighten it up, but bucking it in a vice and holding it as you hammer requires maximum pucker, that hair wire is always in the danger zone. An alternate fix would be run a second wire through the lid for the G and seal it just like the ground.
Слава Україні!
sodbuster
PostPosted: Tue Feb 13, 2018 2:46 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Looks like the path of least resistince at this point. I'm gonna let that sleeping dog of a gauge lay. Though I did take my sending unit in with me to work where I have access to better quality soldering tools and equipment.
I'll instal it and put the tank back in when I get home today. Very Happy
By the way. That final OHM test to check the repair was sweet sweet victory. Wink
sloans265
sloans265 is offline
PostPosted: Mon Aug 20, 2018 9:05 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
So I rebuilt my sending unit but it appears I still have a problem with it(?) Empty the sender is reading @ 75 resistance and 2.8 resistance FULL. However when I hooked it up to the gauge for testing the gauge went straight to FULL.
I got another “tested” gauge and still same result Gauge says full when sender is at empty. HOWEVER when you move float on sender up to full you can see needle just barely move up itself..
For what it’s worth I did hook it up to a beetle speedo/fuel gauge I had laying around and that gauge did respond.
Is there something I’m overlooking? The performed the only “test” I found for the gauge and it passed. I’m not going through harness, I’m using gauge/sender/battery
Thanks for any help!
1970 Lotus White Panel
In search of any Pensacola Fla dealership items
Kiwi1966
Kiwi1966 is offline
PostPosted: Fri Aug 30, 2019 3:16 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Hi just to add to this post , I did the upgrade as per the previous posts but the little nichrome wire broke on me when reasembling.Measured the old wire and it measured out at 0.08 mm which eqyates to 40 awg.Ended going to a local vape store and getting this 40 gauge nichrome 80 wire, cheap as for a 300 foot roll which should do a few senders Very Happy
busdaddy
PostPosted: Fri Aug 30, 2019 6:37 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Cool Cool thanks for passing that along, I assume the OHM's remain in the ballpark with the new wire?
Слава Україні!
Kiwi1966
Kiwi1966 is offline
PostPosted: Mon Sep 02, 2019 1:25 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Yes 67 ohms per foot, sender is 3 ohms full and 82 ohms empty.
hillsfield
hillsfield is offline
PostPosted: Wed Mar 25, 2020 9:15 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Thanks Telford dorr for putting together this repair 'how to'. Just followed step by step for my 69 Ghia and it worked perfectly. Simple fix. thanks again
telford dorr
PostPosted: Thu Mar 26, 2020 1:17 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Glad it worked out. Consider yourself saved from the curse of replacement chinese junk...
Note: original website URL changed: http://telforddorr.com/FuelSenderRepair/
Elle_VW1972Microbus
Elle_VW1972Microbus is offline
PostPosted: Wed Aug 19, 2020 9:15 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Thanks so much to Telford Dorr for posting his guide with amazing photos. Today I successfully repaired the sender in a VW Bay Window Bus (date of manufacture, 9/72). Its sending unit is the tubular (internal float) design, but the top of the sending unit is slightly different from Telford Dorr's. The different design allowed modification as follows:
An inexpensive Harbor Freight 1/16-inch drill bit worked fine to drill the hole. The drill bits are sold in packs of half a dozen or so for a couple dollars. The copper wire is 20 gauge. A few more photos:
Part number 211919051 and date of manufacture 7 / 71 appears on top of this sending unit:
Last edited by Elle_VW1972Microbus on Wed Aug 19, 2020 5:37 pm; edited 1 time in total
bnam
bnam is offline
PostPosted: Wed Nov 25, 2020 9:34 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
I just did a repair on a sender for a friend. Was the first one of this type I had tried to repair. I had not yet read this post.
I too discovered the corrosion problem between the tensioner and the cover. But, my solution was different. I cleaned up the under side of the plate. The tensioner was pretty clean, but I cleaned up the upper side (side closer to the cover) a bit more. I had some thick copper wire handy. I cut a small 1/2" length and wedged it between the tensioner and the cover - close to the rivet where the gap between the tensioner and the cover is small. This seems to have done the trick.
Click to view image
1952 Citroen TA 11BL
Vladiiiii
Vladiiiii is offline
PostPosted: Sat Mar 06, 2021 2:28 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
I'd also like to say thank you for showing this. I have repaired my similar 72 Ghia sender this way. I cleaned as much as I could, and I just soldered the spiral and the base together in 2 sturdy points. I also cleand and lightly soldered other connections, and now it's working perfectly Very Happy Shocked
So thanks again, for showing what's to be done Cool
Vlad
Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746
Alois66
Alois66 is offline
PostPosted: Sun Mar 07, 2021 1:32 pm    Post subject: Re: Another fuel sender repair method T2a Reply with quote
Dear Ghia friends,
I successfully performed the repair of my fuel sender unit which showed the typical problem of a corroded mass contact of the wire tensioning spring plate with the lid.
However I did it without soldering and in a servicable mode.
1.) Clean the surface of the lid and the wire tensioning spring at the indicated spot with a fibre glas scratch pencil. Easy job 1 min.
2.) Drill a hole and make a threaded tap.
3.) From the bottom, screw in a screw with an external toothed washer, which overlaps the tensioner spring.
In this position the spring can't be pushed down to far and it is still flexible enough to tension the wire.
Reassemble the sender and install: Voila it works.
All the best and have fun
Max
Mr Margaret Scratcher
Mr Margaret Scratcher is offline
PostPosted: Sun Apr 11, 2021 9:31 am    Post subject: Re: Another fuel sender repair method T2a Reply with quote
After getting a replacement sender that was reading zero with the float in all positions, I decided to crack open my old sender (Which I actually bought new about a year or so ago) which was just reading higher than empty resistance in all positions. I found the contacts were spread too far apart so I used a small screwdriver to bend them inwards to make a good connection. Tested with multimeter and yes - about 4 ohm full, 90 odd empty.
I was feeling pretty chuffed with myself so you can imagine how gutted I was when I tipped the sender back into the empty position and the momentum of the float snapped the resistance wire at the solder joint Embarassed
I managed to solder it back on (By bending the flexible springy brass bit up) and then managed to snap the other side. Pretty annoyed with myself at this point, but managed to get the other side soldered back on and everything screwed back together and now I finally have a working fuel gauge in my truck for the first time since I got it which is about 20 years! Very Happy
Page 4 of 6
