ricaroo Samba Member
Posted: Wed Jul 05, 2017 12:06 pm Post subject: Manual/ Auto starter |
I think I read somewhere on the forum that you Can replace a manual transmission starter with an automatic Transmission starter so you don't need to deal with the bushing, is that accurate?
1971 Standard Beetle Manual Transmission (1600dp)
Thx
Rick |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Jul 05, 2017 12:16 pm Post subject: Re: Manual/ Auto starter |
Yes, you can. The auto-stick starter is actually a little more powerful. Fit well, but they are a tad heavier.
I put one in my 1974 Super Beetle a couple years ago. It was a Bosch remanufactured from Napa Auto Parts. It cost about fifty more dollars than a manual starter, but since I didn't have to fool with the bushing, I as okay with that.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
johnnyniceguy Samba Member
Posted: Mon Feb 05, 2018 8:00 pm Post subject: Re: Manual/ Auto starter |
Does the self supporting starter (SR17) have a specific Solenoid? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76936 Location: Sneaking up behind you
Posted: Mon Feb 05, 2018 8:03 pm Post subject: Re: Manual/ Auto starter |
SR15 is for "manual"
SR17 is for autostick
Yes, you can use the SR17 on a 4 speed. And Yes, they do have more torque which is good for high horse power engines. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 05, 2018 8:14 pm Post subject: Re: Manual/ Auto starter |
Glen, Is the solenoid different on the 17? |
Glenn Mr. 010
Posted: Mon Feb 05, 2018 8:22 pm Post subject: Re: Manual/ Auto starter |
Looks to be the same, but i'm not 100% sure. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 05, 2018 8:53 pm Post subject: Re: Manual/ Auto starter |
I see one listed specifically for automatic in the classifieds. Thats why I asked.
Going to track down part number. Thanks for the replies. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26320 Location: Douglas, WY
Posted: Mon Feb 05, 2018 9:41 pm Post subject: Re: Manual/ Auto starter |
NO, the solenoid is NOT the same between the two. And Autostick solenoids have a higher failure rate than the ones on normal starters. _________________ Andy T.
Posted: Mon Feb 05, 2018 10:02 pm Post subject: Re: Manual/ Auto starter |
Any chance of a part# |
Posted: Mon Feb 05, 2018 10:37 pm Post subject: Re: Manual/ Auto starter |
As per the 1971 Bosch Catalog I have in front of me:
0331302032 for Automatic (short number 31 062 as per a different book)
0331302011 for Standard. (short number 31 073 in that same book)
I've ran Autostick starters on my Baja Bug for decades and back when I drove it a lot I had a couple of those solenoids fail on me. I also saw a handful of them fail when I worked at the VW parts/service shop. Eventually I found one that seems to want to keep working for me. However it was a South Africa part under 0331302097:
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Tue Feb 06, 2018 6:47 am Post subject: Re: Manual/ Auto starter |
I simply replaced my starter bushing last year when I had my engine out. The rebuilt-by-Bosch starter I'd installed a few decades before came with a new bushing, and I kept it all those years.
I figured at 260K it was time for a new bushing there. New v. old.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Feb 06, 2018 8:46 am Post subject: Re: Manual/ Auto starter |
Thank you Glutamodo and friends. It amazes me the resources this site's members have at their finger tips. This is my first SR17 in 50 years. Never would have guessed the solenoid was different. Hope many others learn from this post. |
Posted: Sat Feb 10, 2018 7:03 pm Post subject: Re: Manual/ Auto starter |
Hello again! I purchased a rebuilt self supported starter with out solenoid.
Found a NOS Solenoid to fit. Now, I think the bolts/screws I have in stock to mount solenoid to starter are too short. Are the bolts for a solenoid for a starter for an Automatic longer?? Anyone have a Part# ? Bosch starter and solenoid. |
Glenn Mr. 010
Posted: Sat Feb 10, 2018 7:09 pm Post subject: Re: Manual/ Auto starter |
I never bought a starter without one already installed. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Feb 10, 2018 7:22 pm Post subject: Re: Manual/ Auto starter |
Stumbled on a good deal. Rebuilt starter on shelf. Solenoid had been robbed. Found NOS solenoid. Didn't even think about the bolts. Found both in the Samba classifieds. Learned that solenoid is specific to auto starter. Kind of makes sense the bolts would be different in length. |
sb001 Samba Member
Posted: Sun Feb 11, 2018 8:28 am Post subject: Re: Manual/ Auto starter |
johnnyniceguy wrote: |
I can't believe it would be too difficult to find the correct bolts at the local Home Depot. Do the shorter bolts you have thread correctly, but are just not long enough? If so just take them with you and match up the thread pattern to longer bolts _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Cusser Samba Member
Posted: Sun Feb 11, 2018 8:58 am Post subject: Re: Manual/ Auto starter |
sb001 wrote: |
I can't believe it would be too difficult to find the correct bolts at the local Home Depot. Do the shorter bolts you have thread correctly, but are just not long enough? If so just take them with you and match up the thread pattern to longer bolts |
Usually more metric stuff at Ace Hardware. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
Posted: Sun Feb 11, 2018 9:24 am Post subject: Re: Manual/ Auto starter |
Cusser wrote: |
sb001 wrote: |
Usually more metric stuff at Ace Hardware. |
ACE is my go to for hardware. _________________ Glenn
Member #1009
#BlueSquare |
bluebus86 Banned
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun Feb 11, 2018 10:35 am Post subject: Re: Manual/ Auto starter |
Small hardware stores like ACE are franchised, and whoever manages the hardware section writes the hardware order. So if he or she is a muscle car dude, expect to have little metric selection. If he or she's a VW enthusiast, expect to see a large metric selection. (See: TrueValue in Portland!)
I'm not sure how the big box stores manage their hardware orders, but sometimes they have exactly what we need and sometimes they don't.
Aren't the three solenoid bolts counter-sunk? Last set I removed was Torx head too, though the head isn't important unless you're on Pebble Beach.
www.airschooled.com |
