Danwvw Samba Member
Posted: Mon Feb 05, 2018 4:11 pm Post subject: Re: The Stupid Question Thread |
A good vacuum will hold, till you let up on the brake the first time with the engine stopped. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Feb 05, 2018 4:33 pm Post subject: Re: The Stupid Question Thread |
A Mightyvac can't produce the volume to keep up with a booster in action, if you can get someone to hold the pedal down while you pump the mightyvac you may be able to pull a vacuum on it in the depressed position before your hand cramps up. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
AircooledHome Samba Member
Joined: October 13, 2015 Posts: 273 Location: California
Posted: Mon Feb 05, 2018 5:53 pm Post subject: Re: The Stupid Question Thread |
Ok got it.
Third stupid question of the week, does it matter where the oil filter return hole on the inside of the external oil filter mount is oriented? I ordered the wrong oil filter mount (ports facing wrong way) and had to made a bracket to bolt the thing upside down.. Now I see that the hole for return oil is on the TOP of the bracket, will oil return through it without issue?
_________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Posted: Mon Feb 05, 2018 6:01 pm Post subject: Re: The Stupid Question Thread |
It doesn't matter, the whole cavity is filled with oil when in use.
I would have made the bracket so the filter faced down myself, or faced the filter towards the front. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 05, 2018 6:23 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
I would have made the bracket so the filter faced down myself, or faced the filter towards the front. |
Why's that? Curious.
The filter is tall, it's a Bosch ST3500 It would hang low if it pointed down. _________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Posted: Mon Feb 05, 2018 7:06 pm Post subject: Re: The Stupid Question Thread |
*X*X*X*X* Supply should be on the outside of the element and the return should be up through the nipple in the middle. *X*X*X*X* |
Posted: Mon Feb 05, 2018 7:10 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
Ahhh yes, never looked that closely, from the pump on the outside, to the engine bearings in the middle. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
tonysantacruz Samba Member
Posted: Mon Feb 05, 2018 7:18 pm Post subject: Re: The Stupid Question Thread |
Looking at pictures I noticed that the silver thingy to the right of the swing lever arm, the bottom one, has no wires connected to the push-on connector. Question is: what is connected to the one that has wires and what should be connected to the bottom one (if anything should be). I’ve looked in the wire diagrams and the Muir books and I can’t find it. Heck, took me a while to find the English name for “swing lever.” |
Posted: Mon Feb 05, 2018 7:30 pm Post subject: Re: The Stupid Question Thread |
tonysantacruz wrote: |
That's your brake master cylinder, the silver thingys are the switches to operate the brake lights. Some systems only have 1 switch, when the optional "brake system warning light" is added to the dash 2 switches are required to operate it, does your bus have a small circular red (often yellowed or faded to clear) light on the speedo cluster that's labelled "B" somewhere between the speedo and heater levers? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 05, 2018 7:43 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
That's your brake master cylinder, the silver thingys are the switches to operate the brake lights. Some systems only have 1 switch, when the optional "brake system warning light" is added to the dash 2 switches are required to operate it, does your bus have a small circular red (often yellowed or faded to clear) light on the speedo cluster that's labelled "B" somewhere between the speedo and heater levers? |
It has the hole for what I think could be that, yeah. Cool, that takes care of that question.
Could you help me with another one? What was bolted here, on the arm/base to the left? And what is the middle cilinder abive the disconnected parking brake lever?
Posted: Mon Feb 05, 2018 8:12 pm Post subject: Re: The Stupid Question Thread |
The cylinder directly behind and above the parking brake is the front end of the shifter tube.
The brackets on the inner side of the RH frame rail aren't something you find on German made buses, maybe mounts for the rare optional "La Cucaracha" air horn? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 05, 2018 8:15 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
The brackets on the inner side of the RH frame rail aren't something you find on German made buses, maybe mounts for the rare optional "La Cucaracha" air horn? |
Hee hee. Thanks for helping filling in the gaps. The shifter had some serious play, hopefully the mechanic took care of that. I’m leaning towards a short shifter (?) ‘cause I don’t want to rap my knuckles every tie I shift to third.
Damn, on that bracket, I’ll need to dig deeper. |
Posted: Mon Feb 05, 2018 8:16 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
I don't have that arm/ base on the left. Nothing connected there.
Well, that is where your parking brake lever connects through the floor..
Posted: Mon Feb 05, 2018 9:12 pm Post subject: Re: The Stupid Question Thread |
AircooledHome wrote: |
Looks like my lever is missing the bottom part. |
Posted: Mon Feb 05, 2018 11:29 pm Post subject: Re: The Stupid Question Thread |
Looks like you two have earlier model buses _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Feb 06, 2018 12:59 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Make sure that the coupler between the shift rod and the tranny is good. Don't know what you may have available to you down south, but there are good couplers and cheap worthless couplers being sold up here in the states. You can always bend the shift lever a bit if necessary to keep the knuckles away from the dash/parking brake handle. |
Posted: Tue Feb 06, 2018 8:20 am Post subject: Re: The Stupid Question Thread |
Well, today I learned that there used to be a cover for that bracket that I found.
Apparently, it's pretty rare:
Tolva Cubre-Pedales, known as "pedal-covering funnel/hopper".
Posted: Tue Feb 06, 2018 8:34 am Post subject: Re: The Stupid Question Thread |
Me like. Thanks, busdaddy. So it takes two? One per side? Or is one big enough to cover them? |
Posted: Tue Feb 06, 2018 10:16 am Post subject: Re: The Stupid Question Thread |
These pans have different shape according to the model year. For your Mexican Combi you should find another of the same year and get a picture and some dimensions. Without the cover if you can snag the steering on a rock, fallen tree limb, or other road debris and get your arms ripped apart. |
