Cold Start Valve compatibility question.
Xevin Premium Member
Xevin is offline
PostPosted: Wed Jan 10, 2018 2:05 pm    Post subject: Cold Start Valve compatibility question. Reply with quote
Can a Type 3 CSV (311 906 171 B ) Be used in a late bay?
Guilty of not searching forum Shocked
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
aeromech
aeromech is offline
PostPosted: Wed Jan 10, 2018 3:06 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
I'm guessing it could. Is there a reason why you'd rather use one than the correct part?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Xevin is offline
PostPosted: Wed Jan 10, 2018 3:16 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Found a NOS type 3. Just curious if I should grab it for a spare.
Keep on Busin'
SGKent wrote:
aeromech
aeromech is offline
PostPosted: Wed Jan 10, 2018 3:21 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
It looks very similar in the pictures. If the bolt pattern is the same I'd guess it would work.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Jan 10, 2018 4:22 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
I have no honest idea, but the fuel pressures of D-Jet and L-Jet are close enough, that the valve would likely work just fine. There is only an inlet though, no outlet, so you would have to add a T to the system near where the stock CSV would act as a coupler.
Note, that “work just fine” and “be technically identical in every way” are different. Wink
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
aeromech
aeromech is offline
PostPosted: Wed Jan 10, 2018 4:26 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Ha, I didn't even notice the T
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
airschooled
Air-Schooled
PostPosted: Wed Jan 10, 2018 4:28 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Neither did KentPS’ smog tech when we bypassed it completely.....
Robbie
www.airschooled.com
furgo
furgo is offline
PostPosted: Wed Jan 10, 2018 4:40 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Exactly. That and the fact that the connector is a D-Jetronic one and not an L-Jetronic one on the Type 3 CSV, will make it a non-plug-and-play option.
The nozzle is also considerably longer than the CSV on the bus, but I don't think that would make much of a difference once the fuel is sprayed into the plenum.
It would probably work, but before using it you'll have to:
- Couple the single inlet with a T to provide a return for the bus fuel rail
- Either modify the harness or build an adapter to connect from L-Jetronic (harness) to D-Jetronic style (CSV).
Specs
Type 3 CSV:
• Bosch 0 280 170 015 (*)
• Flow rate: N/A
• Spray angle: N/A
Bus CSV:
• Bosch 0 280 170 026
• Flow rate: 85 cm3/min
• Spray angle: 80°
(*) or alternatively:
- Standard Motor Products: CJ8
- Beck Arnley: 158-0086
They are all originally the same Bosch part, just rebranded.
'79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
Bleyseng
Bleyseng is offline
PostPosted: Thu Jan 11, 2018 9:31 am    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Just leave it off and block off the fuel line to it. It really doesn't do that much.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
Xevin is offline
PostPosted: Thu Jan 11, 2018 10:23 am    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Thanks for the input guys. Good to know. I do know many guys block it off but just wondering if the type 3 an alternative solution. And now I know Very Happy
Keep on Busin'
SGKent wrote:
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jan 11, 2018 1:48 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
there are a lot of similar CSV for sale with one nipple. The length of the injector has to do with the thickness of the manifold. I'd go for one with the shortest injector to reduce shadowing of incoming air, but since the fuel is injected downstream at the ports - even if only 3 cylinders fired on starting the other ones would catch in a second or two.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
raygreenwood
raygreenwood is offline
PostPosted: Thu Jan 11, 2018 5:46 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Specs
Type 3 CSV:
• Flow rate: N/A
• Spray angle: N/A
Bus CSV:
• Spray angle: 80°
Actually an L-jet plug housing can be made to fit the D-jet valve nearly perfectly in about five minutes.
Or...if you want to sample some other D-jet parts...you can use the 022 906 171 A.....if you can find one.
This is identical to the D-jet valve in the picture except that it has an inlet and outlet just like the 022 906 171 B used on L-jet.
That is the difference in the TYPE 4 D-jet cold start valve versus a type 3 model cold start valve.
On all type 4 fuel injected engines whether the were D-jet or L-jet...the cold start valve was a through feed valve that was part of the loop and not a Tee style valve like type 3. Ray
popuppopdog
popuppopdog is offline
PostPosted: Thu Jan 11, 2018 8:59 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
I am not an expert but talked to Ed at Car Craft in Riverside , CA today, holder of the world speed record of VW at Bonneville on vw under 2000cc to date, he basically said the CSV really never worked right and he wouldn't worry about even having one. I have heard this a couple of times from my injector rebuilder and Ed, he said when he worked for VW USA 40 years ago Vw had a flyer to give to folks to help folks start their engines in cold weather cause their system did not work well. A story, I dont know, he also mentioned that at higher RPM engine noise they devised a way for the radio to increase in volume because people complained they could hear their radios at high RPM...love the VW stories
KentABQ Premium Member
KentABQ is offline
PostPosted: Thu Jan 11, 2018 9:16 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
That's good to hear, and I hope it's true. When I refreshed my engine last spring, I installed the CSV, but didn't connect fuel or connector to it. And it starts fine. Although I live in a desert where cold weather is rarely a problem...
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
raygreenwood
PostPosted: Thu Jan 11, 2018 9:19 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
The CSV actually does work well.....but only when its really cold.
On a well tuned engine in good shape with good cranking speed.....I hsve never seen a need for it above about 25 F.
Ray
SGKent is offline
PostPosted: Wed Feb 07, 2018 2:43 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
my CSV works great and I think I have a NOS one around too. $550 buys it if I can find it. Otherwise Google and fleabay "CJ8 - Cold Start" and find either a CJ-8 csv or one like it but make your own tee. Owning a late bus is a challenge. That comes with the turf.
Gregg in the 603
Gregg in the 603 is offline
PostPosted: Wed Feb 07, 2018 6:42 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
You joking? That's crazy talk!
My CSV kicks ass in the cold. 10 degrees out, it pumps fuel right where I need it and the motor fires up great.
1979 Mexico Beige Westy auto
Dirty Dover, NH
Wildthings
Wildthings is offline
PostPosted: Wed Feb 07, 2018 7:05 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Ray
The TTS set point is something like 110°F. I personally think this is too high. I have seen a lot of problems with these engines not being able to start when on the cold side because they are getting too much fuel. At 6000' or above a guy gets to his rig and fires it up, after a minute or so he shuts it off so he can use his key to open the back hatch. He then tries to restart the engine, but it floods and will not restart because no heat has reached the TTS switch yet and the CSV is thus staying open too long pouring in excess fuel.
Amskeptic
Amskeptic is offline
PostPosted: Wed Feb 07, 2018 8:09 pm    Post subject: Re: Cold Start Valve compatibility question. Reply with quote
Ray
I have had enough issues with cold starting amongst my customers along the northern latitudes to really appreciate the critical assist that the cold start valve provides. If you map the fuel mixture from dead cold to operating temperature, you will find that the L-Jet engines really dump in the fuel for the initial start, allow a stinky rich three-to-five warm up and then lean out for operating temperature.
When I richened the factory L-Jet original engine to survive the desert highway driving, I noticed right away that my cold starts, though the engine would light instantly, would give me a rich lopey idle during the three to five minute warm up. If I set the mixture to factory .7% CO, the cold start and warm up were delightfully lovely, but my head temps would scare me.
The factory specs on the TTS are:
11 seconds grounding at 0* F
1/2 second grounding at 52* (early)
1/2 second grounding at 95* (late)
Remember, cold start valve only operates during starter. If you are experiencing rich running after you have let go of the key, chances are good that you should look elsewhere for causes of rich running.
Colin
www.itinerant-air-cooled.com
