Barn Find THING, Full Restoration, 27,000 Original Miles.
Page: Previous  1, 2, 3 ... 10, 11, 12
randybriscoe
randybriscoe is offline
PostPosted: Sun Aug 28, 2016 11:08 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
Lots of different size O.E. German hoses. Pricey!
Mounting the electric engine fuel pump. We used the gas heater bracket for this. Maybe we can use this pump for the heater also?
Here's the fuel flow schematic. Click on it to see the red arrows. Fuel filters are used to change from domestic size hose, to metric. The filter is "stepped up", so it has both sizes. Very clever...
Sideview of fuel lines, under the gas tank, from the right front fender. Proves plenty of clearance for pump & lines.
randybriscoe
PostPosted: Mon Sep 05, 2016 10:22 am    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
Test fitting the new Thing Shop top last night. Perfect fit, very impressed.
Check out how nice this angle lines up with the windshield.
frogman_94
frogman_94 is offline
PostPosted: Tue Sep 06, 2016 12:10 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
The pump for the heater is a solenoid type pump and operates by contacts in the fan.
randybriscoe
PostPosted: Tue Sep 06, 2016 5:52 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
So what you're saying is...install the "T" fitting, we're good to go!
madster
madster is offline
PostPosted: Tue Jan 10, 2017 9:39 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
Popcorn Popcorn Popcorn Popcorn
1966 BEETLE
Chitty1
Chitty1 is offline
PostPosted: Thu Jan 26, 2017 7:11 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
[quote="randybriscoe"]IT's Fuel Tank Time
[img]
Did you not use any gaskets either side of the plastic filter, or are you counting on the filter flange to seal both leak paths? I bought the same kit from cip1 and it recommended gaskets be used with this filter. Also, did you use the loose washer under the nut?
Great job on the restoration and the step-by-step posts.
1963 Bug, 1600DP, 12V alternator conversion
2012 Mustang GT
1998 New Beetle (wife's)
Plus 2 other non-descript DD's
madster
madster is offline
PostPosted: Mon May 29, 2017 8:36 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
Popcorn Popcorn Popcorn Popcorn Popcorn Popcorn Popcorn Popcorn
1966 BEETLE
77kafer
77kafer is offline
PostPosted: Tue May 30, 2017 4:30 am    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
madster, you will be eating a lot of pop-corn.
Since Randy found the thing facebook page a few months ago, he has not been back here to finish up.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
zohami
zohami is offline
PostPosted: Thu Jun 01, 2017 9:45 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
Just read all 12 pages, took a few days. Killer project!
Which Facebook page; not finding it?
Sold the Doka, now it's a '74 Thing Smile
77kafer
77kafer is offline
PostPosted: Fri Jun 02, 2017 4:22 am    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
people who drive a vw thing (type 181/182)
it is not a build thread, he is just posting that it is together, and that it drives. short videos of test drives etc.
Now if you want to read through an interesting one on here, check this one out (all 18 pages): https://www.thesamba.com/vw/forum/viewtopic.php?t=389726&highlight=schwimmer
madster
madster is offline
PostPosted: Fri Sep 22, 2017 9:29 am    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
1966 BEETLE
randybriscoe
PostPosted: Sun Jan 07, 2018 11:26 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
Well we're back...here's the first test fitting of the controversial 82 x 94 stock head engine.
randybriscoe
PostPosted: Thu Feb 08, 2018 10:52 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
A little out of sequence...revisiting the steering assemble. A sketch I made of the steering column assemble on the steering wheel end. We added a plastic spacer in place of the felt to help keep the anti rattle bushing in place.
Mike Basso at Thing Parts hooked us up with all the original steering column hardeware
Test fitting the steering column
Inserting the horn ground wire through the steering wheel
Through trial and error we finally got a good gap/spacing on the steering column assemble. A lot of small variables at play here, both top and bottom
randybriscoe
PostPosted: Thu Feb 08, 2018 11:06 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
The new solid state voltage regulator. Lots of fun cleaning and installing the original wiring harness
randybriscoe
PostPosted: Thu Feb 08, 2018 11:08 pm    Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. Reply with quote
Some wire bundles we heated up a little so they would lay in place
Page 12 of 12
