westyman1 Samba Member
Posted: Mon Aug 11, 2003 2:58 pm Post subject: Hard to shift into gear |
Hello everyone have a good question about a 76 manual trans,
was shifting fine for about 300 of a 600 mile trip and is it now is almost impossile to find first or second...
clutch feels fine third fourth and reverse all work ok no popping out of gear on hills
I just got bus about 2 months ago and wanted to post this for at least a starting point.
Thanks
JB |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Mon Aug 11, 2003 3:01 pm Post subject: |
you got linkage issues. sounds like there may be a worn bushing or two. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
AlaskaWesty Samba Member
Joined: August 10, 2003 Posts: 81 Location: The End of the Road
Posted: Mon Aug 11, 2003 3:54 pm Post subject: |
Try adjusting your shift plate first on the floor there. 13mm wrench. Just follow the steps either in the Bentley or on old posts. That may help temporarily but I agree probably your bushings. They are easier and cheaper to replace than your tranny! Try those first. _________________ '78 CEII Westy - RIP |
NuggJugg Samba Member
Joined: July 27, 2003 Posts: 84 Location: Bay Village, Ohio
Posted: Mon Aug 11, 2003 7:35 pm Post subject: |
Check your clutch cable. If it was new it may have stretched out considerably. There is a wing nut in the back on tranny that you can adjust. _________________ My Shows:
http://db.etree.org/nugg_jugg
1971 Westfalia 1600 DP
1972 Campmobile 2.0 Liter
1975 Beetle
1990 Jetta GL 5 speed manual 190,000 miles and still smokes! |
chillz1 Samba Member
Joined: August 03, 2002 Posts: 869 Location: Where You Least Expect
Posted: Mon Aug 11, 2003 8:26 pm Post subject: |
bljones wrote: |
you got linkage issues. sounds like there may be a worn bushing or two. |
Agreed. Shift coupler and shift rod bushing issues. If it had happened AFTER you had happened to mess with the shifter adjustment, then that could be suspect, but this doesn't appear to be the case. |
Posted: Mon Aug 11, 2003 10:18 pm Post subject: Thanks... |
thanks everyone....
will look in the daylght...
any shop manuals online for this? |
Posted: Tue Aug 12, 2003 12:22 am Post subject: Re: Thanks... |
westyman1 wrote: |
thanks everyone....
Something tells me you might find something at www.type2.com |
Posted: Tue Aug 12, 2003 7:21 pm Post subject: Thanks All |
Purchas new bushinging and have have duped my buudy who is authentic tech!! to help me replace tommorow.
Any helpful hints ...
Guy at bugshop said was not to hard...
Book says remove trans can this be done with out taking it out? |
