WWII era Beetle
geneL3c
geneL3c is offline
PostPosted: Sat Feb 10, 2018 9:18 am    Post subject: Re: WWII era Beetle Reply with quote
I'll try Sam Steel again on Monday, he doesn't seem to respond with anything other than a pre-programmed message unless you e-mail him during Spanish work hours, taking into consideration the different time zone. I think there is a 5-hour difference to EST. Gene
geneL3c
geneL3c is offline
PostPosted: Sat Feb 10, 2018 9:20 am    Post subject: Re: WWII era Beetle Reply with quote
fifty-eight rag, the ambulance sounds like a really cool project, but I believe it also was on the Kublewagen chassis ? Gene
Fifty-Eight Rag
Fifty-Eight Rag is offline
PostPosted: Sat Feb 10, 2018 9:21 am    Post subject: Re: WWII era Beetle Reply with quote
bakersam wrote:
Regardless, the ambulance idea sounds easier, more fun, and less expensive as no one knows much about the ambulance version save the few period photos. By all means have fun with it, but don't dig yourself into a hole you can't afford to lose when it comes time to move it along. Replicas are great, but at the end of the day they're still just that.
Oh I agree completely...it's just a 50s era Bug converted.
Actually I am way ahead of the game since my base vehicle body is a Frankenstein of 4 vehicles to make one. I love challenges with metal repair...welding wire is cheap enough. Very Happy
1956 Oval
and a barn full of VW parts
1956 Oval build thread
1962 Single Cab Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?p=7959298#7959298
1967 Beetle Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=495269&highlight=larrys
Fifty-Eight Rag
PostPosted: Sat Feb 10, 2018 9:24 am    Post subject: Re: WWII era Beetle Reply with quote
Yes...best I have found was it's an 82e converted to ambulance duty.
1956 Oval
geneL3c
geneL3c is offline
PostPosted: Sat Feb 10, 2018 9:36 am    Post subject: Re: WWII era Beetle Reply with quote
fifty-eight rag, Just went through your Oval window build thread, very impressive work, you should have no problem doing your Ambulance ! Gene
Fifty-Eight Rag
PostPosted: Sat Feb 10, 2018 10:12 am    Post subject: Re: WWII era Beetle Reply with quote
Thank you.
This particular project car has been all over the map throughout the almost 10 years I've been messing with it.
Started out to just be a street driven 58 sliding rag, then morphed into an oval build...now thinking VERY seriously about the 82e ambulance. It seems like the perfect platform for a replica...relatively early body, pieced together like a patchwork quilt...no real value to it.
What I'll probably do is set aside all my good "oval" parts for the future. I want to eventually do a correct nut and bolt restoration to an oval window that has matching numbers.
1956 Oval
geneL3c
geneL3c is offline
PostPosted: Sat Feb 10, 2018 10:23 am    Post subject: Re: WWII era Beetle Reply with quote
I sympathize with you about long term projects. My Typ 87 started as a Typ82e many years ago and I am just now in a position to put it on the front burner. I have had too many project ideas pulling me in different directions with the result that none of them really got the attention needed to complete even the simplest. Now that I'm focused on one, it seems to be finally moving forward with a practical plan for completion. It took me many years to even find the proper donor car because, as you mentioned, you didn't want to " violate " a good original. Even my '50 Split Window sits awaiting installation of one of John Henry's amazing wiring harnesses to get it back on the road. Gene
bakersam
bakersam is offline
PostPosted: Sat Feb 10, 2018 10:32 am    Post subject: Re: WWII era Beetle Reply with quote
Gene, Regarding Steel. I'd written them last month regarding availability of a specific part (one of their repro "T" air cleaners). They quickly responded that they'd be available in February. I received an email earlier this week that they now had them if I was still interested. I responded "Yes" (then got their out of office message in response), and paid. I got the tracking number a day or two later...all since this past Monday. I think more than one person picks up the email on their end, and this has more to do with their responsiveness (or lack thereof) than anything else I can deduce. I've done significant business with Steel over the years, and always got a response...sometimes sooner...sometimes later.
geneL3c
geneL3c is offline
PostPosted: Sat Feb 10, 2018 11:55 am    Post subject: Re: WWII era Beetle Reply with quote
bakersam, Thanks for the hopeful update, I will keep trying until he accepts my order, since obviously SOMEONE is awake there ! Gene
Fifty-Eight Rag
PostPosted: Sun Feb 11, 2018 12:25 pm    Post subject: Re: WWII era Beetle Reply with quote
Stumbled across this. What an amazing restoration of a 1943 82e this is.
I can use this as reference for my replica.
http://ww2vw.com/galleries/kdf-beetle-type-82e-1943/
1956 Oval
geneL3c
geneL3c is offline
PostPosted: Sun Feb 11, 2018 12:33 pm    Post subject: Re: WWII era Beetle Reply with quote
No doubt it's a perfect museum quality restoration, but somehow I don't think they looked that good new from the factory ! Having said that, it certainly is the yardstick for accuracy. The other gallery has some very interesting original condition artifacts. Gene
geneL3c
geneL3c is offline
PostPosted: Sun Feb 11, 2018 5:55 pm    Post subject: Re: WWII era Beetle Reply with quote
Larry, If you haven't already found it, the Ambulance appears to be a Typ 83
" Kastenwagen ". Google search for " images " has some interesting photos. Gene
Fifty-Eight Rag
PostPosted: Sun Feb 11, 2018 9:18 pm    Post subject: Re: WWII era Beetle Reply with quote
I do remember seeing some listed as type 83s...but also some listed as type 82e's. Wonder which is correct? It does appear to have more listed as 83s.
By the way, it seems that folks regularly mistake my name for Larry. I guess it's the couple build threads I have listed for the vehicles I've restored/restoring for a buddy of mine named Larry.
My name is Mike Very Happy
1956 Oval
Fifty-Eight Rag
PostPosted: Sun Feb 11, 2018 9:37 pm    Post subject: Re: WWII era Beetle Reply with quote
There is a Wiki page for the Kubelwagen and it's many variants, but a Type 83 isn't listed.
The "Kastenwagen" ambulance does appear to me to be riding high as if it's on a Kubelwagen chassis. Could it be an 82e that was modified for this purpose?
https://en.wikipedia.org/wiki/Volkswagen_Kubelwagen
1956 Oval
geneL3c
geneL3c is offline
PostPosted: Mon Feb 12, 2018 7:34 am    Post subject: Re: WWII era Beetle Reply with quote
Mike, That would be my guess, wartime needs would probably be more important than perfect records ? Gene
Fifty-Eight Rag
PostPosted: Mon Feb 12, 2018 8:26 am    Post subject: Re: WWII era Beetle Reply with quote
Agreed
I will continue with my research, but I am leaning towards your understanding...that they were 83's.
VW/KDF seemed to issue a new type number for any differences between the vehicles and a big box on the back would qualify as a difference. Laughing
1956 Oval
geneL3c
geneL3c is offline
PostPosted: Mon Feb 12, 2018 10:08 am    Post subject: Re: WWII era Beetle Reply with quote
Mike, I got a couple of 1:35 model kits made by CMK in Czechoslovacia that have really good detail, I think I saw one for the ambulance when I Googled the Typ 83. Gene
Fifty-Eight Rag
PostPosted: Mon Feb 12, 2018 10:13 am    Post subject: Re: WWII era Beetle Reply with quote
Yep...I ordered one a couple days ago.
Great minds think alike Cool
1956 Oval
Second Air Force
Second Air Force is offline
PostPosted: Wed Feb 14, 2018 4:15 am    Post subject: Re: WWII era Beetle Reply with quote
Here's a photo of Typ numbers when the British had control. I nipped this from Etzold's volume 2 of Beetle Chronicles. (It does say 83 when you see the image in person, sorta looks like 85 in the photo).
1956 Standard Sedan
geneL3c
geneL3c is offline
PostPosted: Thu Feb 15, 2018 9:18 am    Post subject: Re: WWII era Beetle Reply with quote
Mike, Well here we go again, sent an order in to Sam Steel and not surprising I got back the standard response, " not taking orders, try again in March " ! Some way to run a business. I'm starting to think maybe he just doesn't like Americans ? Sad Shocked Gene
Page 2 of 4
