MidWesty79 Samba Member
Joined: October 19, 2011 Posts: 485 Location: Milwaukee Wisconsin, US
Posted: Mon Feb 12, 2018 9:12 am Post subject: 27" tires. Will it cause overheating issues?!? |
Hello all, I have looked through the Tire sticky and since the BF Goodrich KOs are no longer available, I am considering the General Grabber AT2 27X8.50R14LT. People seem to be quite happy with them overall.
My concern is possible overheating. I have a '79 Westy that I enjoy taking on long road trips. Last year I covered roughly 5000 miles through the Rockies and across the plains. And this year I hope to have the opportunity to double that.
My concern is what I believe to be a 5.5% decrease in tire RPMs (vs the 195/75/14 tires currently on the bus,) which would lead to a 5.5% decrease in engine RPM with the larger tires. My bus runs hot as it is. It always has. I would like to have the added ground clearance and offroad traction provided by something like the Grabber, but I am somewhat concerned about the power and overheating effects of long days at highway speed.
Anyone have any experience with engine temps effected by these, or other larger diameter tires?
Thanks!! _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Posted: Mon Feb 12, 2018 10:05 am Post subject: Re: 27" tires. Will it cause overheating issues?!? |
I have General Grabbers in my '77, but I had a tranny built to match. So my highway rpm didn't change very much, while my lower gears are still a bit shorter than stock.
I did run an 091 tranny coupled with my 1800 for two decades and 215/70r14 (25.9") tires and it was just fine, so I doubt you will have much of a problem with an 091 tranny, a 2.0L engine, and 27x8.5r14 (26.8") tires.
I am very happy with the Grabbers at this point in time. |
Randy in Maine Samba Member
Posted: Mon Feb 12, 2018 11:24 am Post subject: Re: 27" tires. Will it cause overheating issues?!? |
Really one for the "tires thread" but stock size is 185R14 or about 25.66" tall or ~786 revs per mile. A 27x8.50x14 is about 27" tall and about 747 revs per mile.
Do you run a good CHT and that allows you to monitor the temps? Might be worth having. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12686 Location: on a bike ride somewhere
Posted: Mon Feb 12, 2018 11:39 am Post subject: Re: 27" tires. Will it cause overheating issues?!? |
Crossing the Rocky Mountains and you're making your effective gear ratio taller?
The engine doesn't care what the load is, be it a hill, headwind, taller tire, or seven humans onboard… An increase in load will increase stress on the engine.
Can you find someone nearby to trade wheels with for a day or so?
www.airschooled.com |
airkooledchris Samba Member
Posted: Mon Feb 12, 2018 2:15 pm Post subject: Re: 27" tires. Will it cause overheating issues?!? |
Every setup is so far from stock these days it's hard to say we are ever comparing apples to apples - but in my 79 I found it was better to have the lower revs and higher load when it came to head temps.
My oil was getting really hot on long slow hill climbs, with taller tires, where my head temps went up slightly when I switched to the BFG's (which are slightly shorter than stock I believe.)
I switched back and forth and hit the same hill a few different times and in the end, there didn't seem to be enough of a difference between the 27x8.5R14's and the BFGs to warrant wanting to switch one way or the other. When my current BFG's run their course, ill prob switch back to 27's again. |
Posted: Mon Feb 12, 2018 3:23 pm Post subject: Re: 27" tires. Will it cause overheating issues?!? |
I have a dakota digital CHT gauge. I run well over 400 degrees cruising on the hwy. Generally 415 or so. I try to keep it under 420, though there are days that even that becomes very difficult. I have posted for years about my high head temps with no real solution presented. I have tried all sorts of things to no avail. I have driven with these head temps for 30K miles or so and *knock on wood* have seen no ill effects.
airkooledchris- Interesting that you saw no negative change with the taller tires and subsequent lower RPMs.
It'd be great to find someone with some taller tires to do some testing. I'll have to look around. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 398 Location: New Hampshire, USA
Posted: Mon Feb 12, 2018 5:27 pm Post subject: Re: 27" tires. Will it cause overheating issues?!? |
Quote: |
I run well over 400 degrees cruising on the hwy. Generally 415 or so. I try to keep it under 420 |
Many here would say you're nuts for running at those temps! Others (SGKent) will say that's normal. I'm going to agree with him, those temps are normal for 65-70 mph. My temps are very similar to yours, and I'm done being nervous about them. Run it!
I do have a potentiometer installed in series with the TSII so I can richen the mixture when I need to, just to get the temps down when absoulutely necessary.
The tremendous improvement in guages over the years has given us so much information. I'm going to say too much. What did they do back in the day, before we had guages to obsess over? Oh that's right, they enjoyed the ride.
Get the Grabbers and let us know how it goes. I love those tires and would love to run them future. _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Shaun Murray Samba Member
Joined: December 23, 2008 Posts: 587 Location: Far from the city lights
Posted: Mon Feb 12, 2018 6:09 pm Post subject: Re: 27" tires. Will it cause overheating issues?!? |
I ran the 27'' Grabbers on my '79 Westy I sold a few years back. I drove it daily for over a year, and then took it on a cross country trip with them. Drove all over the Rockies loaded heavy with 5 people on board and didn't have any problems related to the tires. I loved them. I currently getting ready to "unlower" my '72 and I'm pretty sure I'll be investing in another set of these once I get it raised back up. _________________ "Cross Country Trip" http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight= |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3296 Location: Wasilla Alaska
Posted: Mon Feb 12, 2018 8:05 pm Post subject: Re: 27" tires. Will it cause overheating issues?!? |
My 81 Vanagon runs at 350 to 400 no matter hills cold or hot even in Alaska winter it still at 325/350 it's the oil temp I have to watch.
Last summer I was climbing out of Dawson city Yukon at 100F for 8 miles clean out of the tree line and it still stayed at 400F but my oil temp went to the moon about 225/230 when I got to the top at tick over the oil light was flickering now this was the rebuilt engine first run I mean I stuffed the engine in the day before and hit the road for a 1000 mile run.
When I got home I did it first oil change and went to 20W50 mobile 1 and that brought the temp right on down and the pressure never again dropped that low at tick over. _________________ where its cold and snowy |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2065 Location: Bulli Klinik, Colorado Springs
Posted: Tue Feb 13, 2018 7:59 am Post subject: Re: 27" tires. Will it cause overheating issues?!? |
I ran 15" wheels and BFG's on my Dormobile for years. The idea of driving through the mighty Rockies vs the reality is something altogether different. If you are really in the mountains, you are constantly changing gears regardless of tire size to go up, downshift, make turns, etc... I really like the bigger tire (28's) because it allowed me to run in third up the passes at 50-55. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Tue Feb 13, 2018 2:08 pm Post subject: Re: 27" tires. Will it cause overheating issues?!? |
Gregg in the 603 wrote: |
Get the Grabbers and let us know how it goes. I love those tires and would love to run them future. |
I have always ran those temps in my current bus, but like Gregg I also run a potentiometer up on the dash and toggle over to that and adjust the mixture as needed - if needed. I actually run pretty lean most of the time now, and just hit the switch and go rich when I need to hit the highway for a while. |
Posted: Wed Feb 14, 2018 7:39 am Post subject: Re: 27" tires. Will it cause overheating issues?!? |
I have seen mention of the potentiometer trick in the past. Anyone have a link to the install? I'm thinking it would be a very handy add on for me. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Posted: Wed Feb 14, 2018 5:26 pm Post subject: Re: 27" tires. Will it cause overheating issues?!? |
Quote: |
I'm thinking it would be a very handy add on for me |
Game changer. A/C Chris shared this idea with me, you'll see in the link.
This hack takes the fear of highway speeds and huge CHT's away. _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Thu Feb 15, 2018 7:30 am Post subject: Re: 27" tires. Will it cause overheating issues?!? |
Thanks! I'll definitely have to give this a go! _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
