VeloMikey Samba Member
Posted: Thu Nov 16, 2017 11:25 pm Post subject: Re: Another fuel sender repair method T2a |
Here it is disassembled. Looks like the wire to the lug broke. Simple soldier job to repair it. Do I need to use special wire or will anything work?
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Nov 17, 2017 8:03 am Post subject: Re: Another fuel sender repair method T2a |
Little tiny winches to tension the hair wire, how cool is that!? They don't make stuff like that anymore.
Yes regular copper wire will do that job fine. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Mon Feb 05, 2018 4:00 pm Post subject: Re: Another fuel sender repair method T2a |
busdaddy wrote: |
Yes regular copper wire will do that job fine. |
Yeah, that’s cool. Tension it with the winch and lock it down with the set screw. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
SGKent Samba Member
Posted: Mon Feb 05, 2018 4:32 pm Post subject: Re: Another fuel sender repair method T2a |
TomWesty wrote: |
busdaddy wrote: |
Yeah, that’s cool. Tension it with the winch and lock it down with the set screw. |
y'all should have been around when we went from stones to copper.... the iron guys who came along behind us didn't have a clue how that stuff worked...... _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1082 Location: wherever my baywindow takes me.
Posted: Mon Feb 12, 2018 9:50 am Post subject: Re: Another fuel sender repair method T2a |
I'm in the process of going through my bus after it's engine gave up the ghost. Along with the rebuild one of the things on the "while I'm in there" list is to get my fuel gauge working again. It has always kind of worked but not too well. whenever I would fill up the gauge would read either full or a little over 3/4 of a tank. It would function ok at first, then the needle would just dive to empty with the tank at least 3/4 full.
So "while I was in there" I pulled my fuel tank to get at the sending unit. With sending unit in hand I started checking the sender out using Telfods exelent repair notes. It tested good. 3.3 ohms full 78.4 ohms empty It's testing good. Give it a bit of a shake a few light taps nothing is fazing the reading on the meter. It's solid.
I was a little confused to discover this. The sending unit seemed fine. So I forged ahead and checked the gauge. When the sending unit wire was grounded the needle on the gauge would not go much past 3/4. Now I am questioning the gauge instead of the sending unit at this point. So I decide to put it down for awhile and work on some thing else.
I ventured to have another look last night and wouldn't you know, the sending unit has now gone jankey on me and is now clearly testing bad. Upon further inspection I deemed it a prime cannadate for Telfords repair method which I will do. (I also have another I can fix as well.) But it is the guage itself that has me tapping the keys today.
Unlike the later models that have a "vibrator" included on the fuel gauge circut to drop voltage to the gauge. The early bays do not have this component. The Bently shows two wires to the fuel gauge on my '71 bus. One from the sending unit and another from the #15 terminal on the fuse block. This is a strait 12 volt tap through the ignition switch. (key'd hot.) There is nothing before the gauge to drop voltage to it. So either it is not required or is internal to the gauge I don't know which.
So here is where I am at with this. I need to effect a repair of the sending unit. Hopefully that will stop the guage from suddenly dropping off to empty. But what to do about the gauge not going all the way to full? Obviously a voltage check of the #15 wire to the gauge is in order as well as checking and cleaning any grounds I come across under the dash. if the voltage test to the guage is good what else short of replacing the gauge outright need to be checked beyond what I have already listed?
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3547 Location: San Diego (Encinitas)
Posted: Mon Feb 12, 2018 9:59 am Post subject: Re: Another fuel sender repair method T2a |
Your tests are correct. Open circuit at the sender should read empty. Short to ground should read full. Check all of the connections in the sender circuit (including the fuse).
Early Bays have no voltage regulator. 12 volts direct to the indicator. Indicator to sender. Sender to ground.
Senders tend to either work or not work. As a sanity check, check your meter probes. Sometimes it helps to take a ScotchBrite pad to the probe tips, which get oxidized over time and give you bad readings. Short the tips together and verify that you read less than 1 ohm. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Mon Feb 12, 2018 10:50 am Post subject: Re: Another fuel sender repair method T2a |
telford dorr wrote: |
Senders tend to either work or not work. As a sanity check, check your meter probes. Sometimes it helps to take a ScotchBrite pad to the probe tips, which get oxidized over time and give you bad readings. Short the tips together and verify that you read less than 1 ohm. |
Thanks for the confermation Telford. Looks like a voltage drop test is what is next up in the process. Just to see if the gauge is getting everything it needs. |
Posted: Mon Feb 12, 2018 11:10 am Post subject: Re: Another fuel sender repair method T2a |
sodbuster wrote: |
But what to do about the gauge not going all the way to full? Obviously a voltage check of the #15 wire to the gauge is in order as well as checking and cleaning any grounds I come across under the dash. if the voltage test to the guage is good what else short of replacing the gauge outright need to be checked beyond what I have already listed? |
Mine did that for years until it finally died last year (the almost full thing, mine didn't drop randomly), after repairing the sender ground and soldering the G wire side of the circuit on both the wet and top side of the rivet it now reads full like one would expect it to. It's not just the ground connection that gets weak.
Soldering the G side is a little tricky, linger too long with the iron and you'll melt the plastic ferrule it goes through, you can rehammer the rivet to tighten it up, but bucking it in a vice and holding it as you hammer requires maximum pucker, that hair wire is always in the danger zone. An alternate fix would be run a second wire through the lid for the G and seal it just like the ground. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Feb 13, 2018 2:46 pm Post subject: Re: Another fuel sender repair method T2a |
busdaddy wrote: |
sodbuster wrote: |
Soldering the G side is a little tricky, linger too long with the iron and you'll melt the plastic ferrule it goes through, you can rehammer the rivet to tighten it up, but bucking it in a vice and holding it as you hammer requires maximum pucker, that hair wire is always in the danger zone. An alternate fix would be run a second wire through the lid for the G and seal it just like the ground. |
Looks like the path of least resistince at this point. I'm gonna let that sleeping dog of a gauge lay. Though I did take my sending unit in with me to work where I have access to better quality soldering tools and equipment.
I'll instal it and put the tank back in when I get home today.
By the way. That final OHM test to check the repair was sweet sweet victory. |
sloans265 Samba Member
Posted: Mon Aug 20, 2018 9:05 pm Post subject: Re: Another fuel sender repair method T2a |
So I rebuilt my sending unit but it appears I still have a problem with it(?) Empty the sender is reading @ 75 resistance and 2.8 resistance FULL. However when I hooked it up to the gauge for testing the gauge went straight to FULL.
I got another “tested” gauge and still same result Gauge says full when sender is at empty. HOWEVER when you move float on sender up to full you can see needle just barely move up itself..
For what it’s worth I did hook it up to a beetle speedo/fuel gauge I had laying around and that gauge did respond.
Is there something I’m overlooking? The performed the only “test” I found for the gauge and it passed. I’m not going through harness, I’m using gauge/sender/battery
Thanks for any help! _________________ 1970 Lotus White Panel
In search of any Pensacola Fla dealership items |
Kiwi1966 Samba Member
Joined: August 18, 2009 Posts: 168 Location: Ohoka New Zealand
Posted: Fri Aug 30, 2019 3:16 am Post subject: Re: Another fuel sender repair method T2a |
Hi just to add to this post , I did the upgrade as per the previous posts but the little nichrome wire broke on me when reasembling.Measured the old wire and it measured out at 0.08 mm which eqyates to 40 awg.Ended going to a local vape store and getting this 40 gauge nichrome 80 wire, cheap as for a 300 foot roll which should do a few senders
Posted: Fri Aug 30, 2019 6:37 am Post subject: Re: Another fuel sender repair method T2a |
Cool thanks for passing that along, I assume the OHM's remain in the ballpark with the new wire? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Sep 02, 2019 1:25 am Post subject: Re: Another fuel sender repair method T2a |
Yes 67 ohms per foot, sender is 3 ohms full and 82 ohms empty. |
hillsfield Samba Member
Posted: Wed Mar 25, 2020 9:15 pm Post subject: Re: Another fuel sender repair method T2a |
Thanks Telford dorr for putting together this repair 'how to'. Just followed step by step for my 69 Ghia and it worked perfectly. Simple fix. thanks again |
Posted: Thu Mar 26, 2020 1:17 pm Post subject: Re: Another fuel sender repair method T2a |
Glad it worked out. Consider yourself saved from the curse of replacement chinese junk...
Note: original website URL changed: http://telforddorr.com/FuelSenderRepair/ _________________ '71 panel, now with FI
Elle_VW1972Microbus Samba Member
Joined: March 12, 2020 Posts: 12 Location: United States
Posted: Wed Aug 19, 2020 9:15 am Post subject: Re: Another fuel sender repair method T2a |
Thanks so much to Telford Dorr for posting his guide with amazing photos. Today I successfully repaired the sender in a VW Bay Window Bus (date of manufacture, 9/72). Its sending unit is the tubular (internal float) design, but the top of the sending unit is slightly different from Telford Dorr's. The different design allowed modification as follows:An inexpensive Harbor Freight 1/16-inch drill bit worked fine to drill the hole. The drill bits are sold in packs of half a dozen or so for a couple dollars. The copper wire is 20 gauge. A few more photos:
Part number 211919051 and date of manufacture 7 / 71 appears on top of this sending unit:
Last edited by Elle_VW1972Microbus on Wed Aug 19, 2020 5:37 pm; edited 1 time in total |
bnam Samba Member
Joined: July 02, 2006 Posts: 2931 Location: El Dorado Hills CA/ Bangalore, India
Posted: Wed Nov 25, 2020 9:34 am Post subject: Re: Another fuel sender repair method T2a |
I just did a repair on a sender for a friend. Was the first one of this type I had tried to repair. I had not yet read this post.
I too discovered the corrosion problem between the tensioner and the cover. But, my solution was different. I cleaned up the under side of the plate. The tensioner was pretty clean, but I cleaned up the upper side (side closer to the cover) a bit more. I had some thick copper wire handy. I cut a small 1/2" length and wedged it between the tensioner and the cover - close to the rivet where the gap between the tensioner and the cover is small. This seems to have done the trick. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Sat Mar 06, 2021 2:28 pm Post subject: Re: Another fuel sender repair method T2a |
I'd also like to say thank you for showing this. I have repaired my similar 72 Ghia sender this way. I cleaned as much as I could, and I just soldered the spiral and the base together in 2 sturdy points. I also cleand and lightly soldered other connections, and now it's working perfectly
So thanks again, for showing what's to be done
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Alois66 Samba Member
Joined: April 08, 2019 Posts: 22 Location: Germany Bavaria
Posted: Sun Mar 07, 2021 1:32 pm Post subject: Re: Another fuel sender repair method T2a |
Dear Ghia friends,
I successfully performed the repair of my fuel sender unit which showed the typical problem of a corroded mass contact of the wire tensioning spring plate with the lid.
However I did it without soldering and in a servicable mode.
1.) Clean the surface of the lid and the wire tensioning spring at the indicated spot with a fibre glas scratch pencil. Easy job 1 min.
2.) Drill a hole and make a threaded tap.
3.) From the bottom, screw in a screw with an external toothed washer, which overlaps the tensioner spring.
In this position the spring can't be pushed down to far and it is still flexible enough to tension the wire.
Reassemble the sender and install: Voila it works.
All the best and have fun
Max |
Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 245 Location: Cambridge UK
Posted: Sun Apr 11, 2021 9:31 am Post subject: Re: Another fuel sender repair method T2a |
After getting a replacement sender that was reading zero with the float in all positions, I decided to crack open my old sender (Which I actually bought new about a year or so ago) which was just reading higher than empty resistance in all positions. I found the contacts were spread too far apart so I used a small screwdriver to bend them inwards to make a good connection. Tested with multimeter and yes - about 4 ohm full, 90 odd empty.
I was feeling pretty chuffed with myself so you can imagine how gutted I was when I tipped the sender back into the empty position and the momentum of the float snapped the resistance wire at the solder joint
I managed to solder it back on (By bending the flexible springy brass bit up) and then managed to snap the other side. Pretty annoyed with myself at this point, but managed to get the other side soldered back on and everything screwed back together and now I finally have a working fuel gauge in my truck for the first time since I got it which is about 20 years! |
