The Stupid Question Thread
Page: Previous  1, 2, 3 ... , 356, 357, 358  Next
xnorm
xnorm is offline
PostPosted: Tue Feb 06, 2018 12:11 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hi guys,
can anyone tell me if the drop gates for type2 49-67 doublecab truck are the same size as the drop gates for the type2 68-79 doublecab truck?
This is for my 69 doublecab...I am seeing lots of gates for sale for the earlier model, but none for the later model. So just wondering if they are swap-able and will fit on both models.
Thanks Xnorm
busdaddy
busdaddy is offline
PostPosted: Tue Feb 06, 2018 1:14 pm    Post subject: Re: The Stupid Question Thread Reply with quote
xnorm wrote:
Hi guys,
Thanks Xnorm
No, not without serious work, splitty gates are 2 or 3 inches shorter than bay gates. The tailgates interchange as is but lack the holes for the tail lights.
xnorm
xnorm is offline
PostPosted: Tue Feb 06, 2018 1:25 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks Busdaddy! That what needed to know!
Take it easy!
Hikelite
Hikelite is offline
PostPosted: Fri Feb 09, 2018 12:46 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I'm pretty sure this question is stupid enough Smile
My Bus is 50 years years old now. I parked her in 2001.
As I begin the process to get her back to road worthy condition, I am concerned about the wiring. Do I need to be worried?
Working on and troubleshooting electrical and wiring don't worry me, but 50 yo insulation does. The bus is getting repainted, so while it's all apart, I'm wondering if it might be prudent to replace the old wiring?
If the answer is yes, can I still count on Wolfsburg West? They have a good reputation with me, but that was formed in the 90's. :p
~Kevin
My 1968 Campmobile
busdaddy
busdaddy is offline
PostPosted: Fri Feb 09, 2018 1:50 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Unless its suffered some catastrophic melt down in the past don't worry about it, the insulation seems to last forever. You will want to clean some of the terminals to remove 50 years of corrosion of course.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Feb 10, 2018 7:03 am    Post subject: Re: The Stupid Question Thread Reply with quote
I agree 100% with Busdaddy. The only issues I've seen on VW's with the insulation is in the engine compartment where it experiences heat cycles. The rest of the harness through the VW is usually perfect w/the exceptions of removing the corrosion off the terminals. Of course, bonus points for throwing out any cheap Autozone type butt connectors and replacing them with the correct barrel ones.
Bill
My 1970 bus refresh thread- http://www.thesamba.com/vw/forum/viewtopic.php?t=598191
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
cv66seabear
cv66seabear is offline
PostPosted: Sat Feb 10, 2018 8:19 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks for posting this thread - I've been wondering if I should do a wiring harness, just on general purposes. Robbie told me not to do it until it had been checked over, which he and I hope to do in May.
Thanks again!
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
2015 Passat 1.8T "Rudy"
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Feb 10, 2018 2:33 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks again!
Very few VW's have their harnesses replaced unless they were hacked to oblivion by previous owners or are being pan off restored. My 67 and 70' bus have the original harnesses in them. I cleaned all the connection and removed any butt connector. I also replaced many connectors that were weak or damaged with new, correct barrel connectors.
Bill
1970 Westfalia Bus
1967 Standard Bug
Hikelite
Hikelite is offline
PostPosted: Mon Feb 12, 2018 2:25 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Back in my youth, I rewired my 1970 bug that had an electrical fire under the hood. I don't recall who made the harness. I bought it at the local shop in Riverside, CA. What I DO recall is how bad it was. I had a wiring diagram, but this harness did not match it exactly. I got it running and most things working, but since it was in an accident a few months later, I can't recall what specific issues it had.
Anyway... my bus DID have an engine fire about a year before it was parked. It was a very minor (lucky) fire, so the wiring still worked, but it has definitely heated up.
With these 2 experiences in mind, it got me considering a rewire.
I appreciate the input and will take the advise. I'll just evaluate the wiring in the engine bay and replace as needed. Yes, I will use the original style connectors. The goal with this mild restore is to be as original as possible.
The harness is NOT hacked. I'm the 2nd owner, and took great pains to ensure it wasn't hacked up. Specifically, when my 9 prong box stopped working in the 90's, I was too poor to afford a new one. A local shop offered to rewire it to use a cheaper relay, but I would have lost my flashers. I declined and decided to wait until I could afford the gold plated flasher relay (it must have had gold in there based on the prices). I never did find a functioning used one in my junk yard tours (oohhhh how I miss strolling through the VW section of the socal junkyards in the 80's and 90's), so it still has the broken one.
Which leads me to another stupid question... (or maybe less stupid, but either way here it is)
Is this product https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211953227BWW
a replacement? Did Wolfsburg West figure out how to make it without all the gold plating?
I seem to recall WW had good stuff back when I was still driving the bus. I hope that's still the case.
~Kevin
My 1968 Campmobile
busdaddy
busdaddy is offline
PostPosted: Mon Feb 12, 2018 3:20 pm    Post subject: Re: The Stupid Question Thread Reply with quote
WW's site seems to be down.
If it's the 2 relay setup they offer in place of the 12 volt 9 pin relay then yes it works fine.
Another option is to find a 9 pin hazard switch and rewire the system to the mid 69-71 style which uses a regular flasher relay.
Hikelite
Hikelite is offline
PostPosted: Mon Feb 12, 2018 4:11 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Link worked for me before I posted and again now.
It looks like a blue version of the thing I have under teh dash. I'll be at the bus on Wednesday adn will pull it out and compare.
I have the pages about how to build my own bookmarked. I'm pretty handy with a soldering iron, but this thing looks like it plugs in like the original. I can paint it black if the color is bothersome Wink
~Kevin
My 1968 Campmobile
Terminatez
Terminatez is offline
PostPosted: Sun Feb 18, 2018 6:09 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Are there any repair or pats for fixing up the locking mechanism inside the ignition key housing?
For some reason my wheel locks as it should.. but even with the correct key it doesn't unlock. I spent about 30 minutes trying different methods to get it loose per the samba but no success.
Last time I had it apart I did notice the nylon tab and the metal U shaped tab inside seemed a bit damage. Wondering if those can be fix or if I need a whole new housing.
1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote:
I don't think I've ever seen an engine in worse shape.
awreed Premium Member
awreed is offline
PostPosted: Mon Feb 19, 2018 10:04 am    Post subject: Re: The Stupid Question Thread Reply with quote
I'm selling an EMPI westy rack. Someone asked me if it would fit on a 73' turtle top bus. My initial reaction was definitely not. Am I correct?
How's that for a stupid question.
white74westy
white74westy is offline
PostPosted: Mon Feb 19, 2018 5:47 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Leak down test. Should the engine be cold or warm? Or, should you test it both ways? Any and all help welcome.
Thanks in advance!
a.
busdaddy
busdaddy is offline
PostPosted: Mon Feb 19, 2018 5:53 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks in advance!
a.
Do the test warm, same deal as a compression test, crack the plugs loose and warm it up, then proceed with the leakdown. No need for a cold test, it won't tell you much unless you already have serious problems.
white74westy
PostPosted: Mon Feb 19, 2018 5:56 pm    Post subject: Re: The Stupid Question Thread Reply with quote
As always, thanks busdaddy! Not sure if I have severe problems yet or not? I fear I may. Cold leak down test wasn't all that great. I'll give it another go, in the hopes that things improve.
Cheers
a.
busdaddy
busdaddy is offline
PostPosted: Mon Feb 19, 2018 5:58 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Unless the legs are 3 feet long it's going to be a challenge to mount, there's no driprail up near the top and it's narrower than a regular bus drip rail up there to boot.
There's adaptors that bolt on to mount modern racks, but they usually only work with modern racks, sounds like you are SOL on that sale.
busdaddy
busdaddy is offline
PostPosted: Mon Feb 19, 2018 6:00 pm    Post subject: Re: The Stupid Question Thread Reply with quote
No parts available that I know of, and I've had little sucess repairing damaged stuff in there, a donor steering lock from the classifieds sounds like your best option.
tonysantacruz
tonysantacruz is offline
PostPosted: Tue Feb 20, 2018 8:49 am    Post subject: Re: The Stupid Question Thread Reply with quote
I just purchased this and I don't think it has the screws. Which ones can I use?
Could they be available at Home Depot?
1970's ignition housing.
tonysantacruz
PostPosted: Wed Feb 21, 2018 12:31 pm    Post subject: Re: The Stupid Question Thread Reply with quote
another question: can I use
instead of
I'm trying to purchase the 1974 part from a guy, but he's not answering (methinks he's not too keen on international shipping), so a guy the eBay-like MercadoLibre is selling the second one. He claims it works with my 1974 bus (I have that same thing in my Bug). Question is, can those parts be swapped without any inconvenience? Or should I wait and get the actual canister?
Page 357 of 358
