airschooled Air-Schooled
Posted: Mon Feb 12, 2018 9:18 pm Post subject: Re: Robbie is building another engine… |
Tram wrote: |
Dammit, Robbie, break something and get this back on track before we get spanked for having fun! |
Eh, too late. Heard a chirp from the right rear today over a speed bump, and pulled the torsion bushings out for inspection. Took one picture during the process.
There's my squeak! Bushings rotated, and Real Talc Powder applied. I'll put new ones in some time this decade.
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Wed Feb 14, 2018 9:41 am Post subject: Re: Robbie is building another engine… |
Im getting tired of all these claims that VW people are cheap..
_________________ .ssS! |
Posted: Wed Feb 14, 2018 11:56 am Post subject: Re: Robbie is building another engine… |
Abscate wrote: |
[img] |
Cheap? Me? Re-use torsion bushings by lathering up with cancer powder? Who told YOU?
Posted: Wed Feb 14, 2018 1:38 pm Post subject: Re: Robbie is building another engine… |
Hey, that jack is no good for that. Even just for the picture. I know you won't go underneath, but fab up some bushings to lift Bernstein Bus up, please. _________________ .ssS! |
timvw7476 Samba Member
Posted: Wed Feb 14, 2018 2:15 pm Post subject: Re: Robbie is building another engine… |
i click on an engine build thread & i get bottle jack bushing hijacked-
miso disappointed. : (
show me more bad engine parts! |
Posted: Wed Feb 14, 2018 2:27 pm Post subject: Re: Robbie is building another engine… |
timvw7476 wrote: |
Here’s some of the “wall of shame” I’ve seen on my travels...
And the Game Winner of them all, the reason for the current engine build!
Those are just the recent engine fail pictures... we’ve got chassis, brake, shifter, and bodywork fails too!
calvinater Samba Member
Joined: September 06, 2014 Posts: 3333 Location: 802 The Pointless Forrest
Posted: Wed Feb 14, 2018 2:37 pm Post subject: Re: Robbie is building another engine… |
any ETA on the live stream engine build? _________________ "Albatross"! |
SGKent Samba Member
Posted: Wed Feb 14, 2018 2:58 pm Post subject: Re: Robbie is building another engine… |
the wall of shame clutch I can understand. it has no snubbers in it. Since the trans and the flywheel have none the clutch plate was the weakest link...
The bent valve may have been a weak valve spring(s) or an over rev.
Now that I see the bent valve I have to wonder if the tappet died the same death as the valve even if different rebuilds.
Cam bearings - hammer on me, weak springs etc., uneven loading and I'd feel worn out too. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Feb 14, 2018 3:58 pm Post subject: Re: Robbie is building another engine… |
calvinater wrote: |
any ETA on the live stream engine build? |
Yes, two weeks. Waiting on a cam delivery from Web at the moment. The short block assembly will be in one segment, about an hour long, and the long block will be the following weekend, about two hours long.
My best guess is that the cam arrives Saturday and I’ll be able to stream on Monday evening. I’ll be using YouTube, so it will work on all devices, it won’t require an account to watch, and it will be archived for future viewing.
I jokingly thought to add a donate button...
SGKent Samba Member
Posted: Wed Feb 14, 2018 4:06 pm Post subject: Re: Robbie is building another engine… |
asiab3 wrote: |
calvinater wrote: |
Robbie |
Just cleaning the parts should take you 2 - 3 hours. Fitting the mains to the case, and assembling the crankshaft / rods should be another hour and a half to two. You have to inspect each rod, each rod bolt, each nut one last time. Getting the peen right on the nuts is 5 minutes alone. If you plasti-gauge the rod bearings and split shells you have one - two hours there because you have to clean up again. Setting the end play on the short block can be a 15 minute or a 30 minute thing. What's with this "hour thing?" _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Brian Samba Moderator
Posted: Wed Feb 14, 2018 4:11 pm Post subject: Re: Robbie is building another engine… |
Shit, am I going to finish my engine before you?
Btw, cheers from New Zealand. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
SGKent Samba Member
Posted: Wed Feb 14, 2018 4:25 pm Post subject: Re: Robbie is building another engine… |
Brian wrote: |
Btw, cheers from New Zealand. |
never happen, the packa rat-roos will steal all your parts and put them 10' underground.
Posted: Wed Feb 14, 2018 6:48 pm Post subject: Re: Robbie is building another engine… |
Every single part has already been ruthlessly cleaned, measured, and cleaned again. The only thing I have left to do is measure cam bearing clearance, gear mesh, and cam end play. Once the cam clearances are all set and cam is re-cleaned, I’ll practically be assembling a Lego set.
I’ve assembled the complete short block two or three times on the bench to measure everything and test fit. (I wanted to be absolutely sure the counterweighted crank addition won’t cause any clearance issues, even if the end play were to open up beyond spec.) End play is already set, but the flywheel won’t be installed because I live on the fourth floor and have to carry the engine down as a longblock to get it to ground level... Also missing from the short block will be the oil pump, since it’s in the current engine in the work parking lot right now.
Don’t get me wrong, I will NOT be rushing anything, and there’s always the possibility that I’ll have to call it off mid-build and reschedule, but enough people sent me messages asking to watch the process, that I will appease them and MAYBE create an educational resource in the process. If nothing else, I’ll screw up on record so we can have a discussion about better shop practices for future engine builders!
wcfvw69 Samba Purist
Posted: Wed Feb 14, 2018 8:06 pm Post subject: Re: Robbie is building another engine… |
asiab3 wrote: |
Robbie |
Any chance Colin will joining the festivities and watching the build? I wonder if he'd blow your phone up mid-build asking WTH are you doing that Robbie!??! _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Feb 14, 2018 8:16 pm Post subject: Re: Robbie is building another engine… |
wcfvw69 wrote: |
Any chance Colin will joining the festivities and watching the build? I wonder if he'd blow your phone up mid-build asking WTH are you doing that Robbie!??! |
Ha! It will be online for posterity, but I hope anyone watching will feel inclined to chime in and leave real time comments!
My phone will be turned off though… I can't handle the interruptions.
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Thu Feb 15, 2018 8:30 am Post subject: Re: Robbie is building another engine… |
asiab3 wrote: |
wcfvw69 wrote: |
Robbie |
Robbie . . .
. . . that squeak you reported up above?
Not the bushing. That is not the worst bushing I have seen. The squeak is evident in the end of the spring plate retainer. The torsion bar is slightly out. A few mighty thwacks with a hammer against a big spacer (socket) will drive the torsion bar in 1/4" or so, and then it won't contact the retainer plate any more.
ColinOnTheRoadToMiami
_________________ www.itinerant-air-cooled.com |
SGKent Samba Member
Posted: Thu Feb 15, 2018 8:35 am Post subject: Re: Robbie is building another engine… |
Robbie - be sure you cover in the video the things you have already done to prepare for putting the parts together. IMHO - Prep, right machine work, including a clean work area is 70% of a build. The parts are 20% and the build is 10%. All have to mesh. The video is only going to cover the 10% unless you mention those things in it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Packaroos - great picture, Steve
That is also a great picture of the rare 12 valve air cooled engine, its a Type 3 part, of course. _________________ .ssS! |
Posted: Thu Feb 15, 2018 10:04 am Post subject: Re: Robbie is building another engine… |
Funny, the right side torsion bar was absolutely seated all the way. And that was the side the chirp was coming from! Judicious talc did solve the squeak, but I’ll go back into the left side today and send that bar home.
It was nice to scrub the bottom of the wheel wells and reapply undercoat, but the majority of my time was spent cleaning out 49 years of road detritus from the bump stop drain holes. I easily spent an hour on each side, and my HOA will be sending me a letter about the mess, I’m sure.
Steve, you bet I’ll be talking about the specs, tolerances, cleanliness factors, and measuring. I didn’t spend the last few months rejecting part after part just to give people the impression that they could build this in an afternoon... And it absolutely Will Not be a step by step tutorial! By describing what I’m doing out loud, it will force me to think more consciously about what I’m doing, so I don’t do shit like put the distributor drive pinion in 180* out like I did in Colorado. But hey, if that was the biggest mistake I made building the short block without a book....
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Thu Feb 15, 2018 7:48 pm Post subject: Re: Robbie is building another engine… |
asiab3 wrote: |
Robbie |
Friends don’t let friends assemble drunk.... JK _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
