xcortes Samba Member
Posted: Tue Feb 13, 2018 9:46 am Post subject: How’s this part called and where to get a replacement? |
Hello, I want to replace this black plastic part (film?) but don’t know how it’s called, how to search for it or where to source it. I’m assuming is just some plastic film but I’m sure there’s a better answer. Any help will be appreciated.
Xavier
Posted: Tue Feb 13, 2018 10:08 am Post subject: Re: How’s this part called and where to get a replacement? |
Search the classifieds under "panel". There are a couple of different vendors who supply such. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Feb 13, 2018 10:20 am Post subject: Re: How’s this part called and where to get a replacement? |
I think he's pointing to the vinyl that is not part of the panel, per se.
This should be just black vinyl. Perhaps Sewfine or TMI would be willing to sell you some of the vinyl by itself, and you could fashion it into a piece to cover the metal there. If not, you might find something at a local upholstery shop or fabric store. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Tue Feb 13, 2018 10:31 am Post subject: Re: How’s this part called and where to get a replacement? |
jtauxe wrote: |
This should be just black vinyl. Perhaps Sewfine or TMI would be willing to sell you some of the vinyl by itself, and you could fashion it into a piece to cover the metal there. If not, you might find something at a local upholstery shop or fabric store. |
Any place that does boat or automotive upholstery should have vinyl. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Tue Feb 13, 2018 10:32 am Post subject: Re: How’s this part called and where to get a replacement? |
jtauxe wrote: |
I think you are correct.
I am not saying this is exact for the bus.....but jn many beetles, 411 and 412.....the A, B and C pillar sheathing was essentially the same as the headliner material without the perforations.
I would take a scrap to q headliner shop and see what they have. Ray |
jtauxe Samba Member
Posted: Tue Feb 13, 2018 3:09 pm Post subject: Re: How’s this part called and where to get a replacement? |
I have original buses that have the headliner material in that location as well.
So, to the OP: IF you are restoring to original, you probably want headliner material there and around the lower parts of the window frames, too. But if you want black vinyl, go for it. _________________ John
http://vw.tauxe.net
Posted: Wed Feb 14, 2018 6:03 am Post subject: Re: How’s this part called and where to get a replacement? |
Thanks so much! |
Posted: Wed Feb 14, 2018 8:30 am Post subject: Re: How’s this part called and where to get a replacement? |
Be careful with black vinyl.
If you live in a hot place....that vinyl with easily get to be 30° or more hotter than white vinyl.
What that causes is fast and exceasive shrinkage. In applications shere I have seen black vinyl like that....mostly custom upholstered and Anerican cars from the 1970s.....in uot climates.....in just a couple of years....the vinyl either pulled loose as it shrank....or it cracked if it cannot pull loose.
Vinyl starts shrinking the day its born. The more heat....the faster it shrinks.
If you want to stay with black vinyl.....you need to pre-shrink it. Ray |
