99' EVC instrument panel
Forum Index -> Eurovan Share: Facebook Twitter
Brian Shea
Brian Shea is offline
PostPosted: Wed Feb 14, 2018 11:12 am    Post subject: 99' EVC instrument panel Reply with quote
Need some help to figure out why all the gauges start showing crazy readings. Usually happens after I shut the van off and restart it. If I disconnect the battery all the gauges reset themselves and I can go a few days then it happens again. Any help will be appreciated
Stripped66
Stripped66 is offline
PostPosted: Wed Feb 14, 2018 11:55 am    Post subject: Re: 99' EVC instrument panel Reply with quote
Your instrument panel is toast. This is not an uncommon failure. Find a replacement on eBay, or find somebody online who refurbishes instrument clusters.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
Joshwa
Joshwa is offline
PostPosted: Wed Feb 14, 2018 3:09 pm    Post subject: Re: 99' EVC instrument panel Reply with quote
Chub's Auto Repair
605 S Cheyenne St Taylorville, IL 62568-2600
(217) 824-3954
Iíve used this shop for cluster repair a few times. Very reasonably priced. You could call and talk to Derek and see if he hasany advice on whatís going on with the cluster. Then otherwise send it to him to fix if he thinks it is related to the cluster. Probably should make sure all your grounds are good on the engine harness before calling.
93 Weekender TDI conversion#1
93 MV TDI conversion #2
Weekender rear cot
Late model cabin air filter on 93
www.wetwesties.org
Stripped66
PostPosted: Wed Feb 14, 2018 7:46 pm    Post subject: Re: 99' EVC instrument panel Reply with quote
This is located on the side of the timing cover, towards the back of the coil pack.
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
